Thanks for pointing me in the right direction guys. it was the Phoenix bit that I was missing. I'm posting all the links to the relevant source sites where I found out what I needed to in case anyone else needs it in the future.
The 3 way input connectors were quite easy to locate as Phoenix part ID MSTB 2,5/ 3-STZ-5,08 (1776168) as defined here: https://www.phoenixcontact.com/en-gb/products/pcb-plug-mstb-25-3-stz-508-1776168" rel="nofollow - https://www.phoenixcontact.com/en-gb/products/pcb-plug-mstb-25-3-stz-508-1776168
Mouser link: https://www.mouser.co.uk/ProductDetail/Phoenix-Contact/1776168?qs=BYlwlsDsB%2FqrpMNmIQuoAQ%3D%3D" rel="nofollow - https://www.mouser.co.uk/ProductDetail/Phoenix-Contact/1776168?qs=BYlwlsDsB%2FqrpMNmIQuoAQ%3D%3D
It look a bit longer to work out exactly what the 8 way output connector is, specifically IPC 5/ 8-STF-7,62 (1709212) as shown here: https://www.phoenixcontact.com/en-gb/products/pcb-plug-ipc-5-8-stf-762-1709212" rel="nofollow - https://www.phoenixcontact.com/en-gb/products/pcb-plug-ipc-5-8-stf-762-1709212
Unfortunately these are not readily available to order and are a minimum order quantity of 50! This works out anywhere from 500 to 1000GBP depending on where you get them from and a lead time of many weeks!!!
Thinking around the problem I was hoping to be able to use two 4 way connectors (without the screw lugs) side by side as an interim solution, as these are slightly more readily available in sensible quantities and price. What do you reckon?
Product here: https://www.phoenixcontact.com/en-gb/products/pcb-plug-ipc-5-4-st-762-1709063" rel="nofollow - https://www.phoenixcontact.com/en-gb/products/pcb-plug-ipc-5-4-st-762-1709063
The other option would be to order the kit I showed above direct from QSC spares service and get it shipped to someone in the US, who could then forward it on to me...
------------- They're complaining over there, but it's their fault!
