opinion on 1 MT122 + 4 HD15
Forum Name: Feedback Forum
Forum Description: How Your Projects Perform
URL: https://forum.speakerplans.com/forum_posts.asp?TID=107286
Printed Date: 26 March 2026 at 6:55pm
Topic: opinion on 1 MT122 + 4 HD15
Posted By: 1ManSoundsystem
Subject: opinion on 1 MT122 + 4 HD15
Date Posted: 15 August 2022 at 2:59am
hi !
im planning to use
1 MT122 (2x B&C 12NDL76, 1x beyma CP800TI)
with
4x HD15 (PD 154) 2x2 on top of each other, curves open to the sides,
together as a monostack on a 4 day outdoorevent.
routing via ultradrive, amps crown /qsc.
since the HD15s specs say, that they go as low as 52HZ
im thinking about, if it could lack some bass.
music played: EDM, psy, dnb, reggae, metal, pop, rock
volumes 70% conversationlevel, 30% pedal to the metal.
what do you think? will there be enough satisfying bass or
should we add a hogscoop and use only 2 HD15?
i read, that if hornmouth are combined from several horns together,
they could play a little deeper than a single horn.
thx !
Posted By: Contour
Date Posted: 15 August 2022 at 4:57am
Perhaps build W-Bins or Eliminator style? Stack of 4x martin 115 would produce brutal bass.
Date Posted: 15 August 2022 at 5:08am
i have 4 hogs /1851, more brutal with 4x18 is hard.
but hogs are heavy so we pick 4x HD15. even though that was not my question.
Posted By: luton_soundman
Date Posted: 15 August 2022 at 7:08am
As you said they wont be playing anything below 50z so alot will be missing. But then the 51 isnt suited to the hog and alot of lower frequencies will also be lost due to the tight chamber and throat not being optimum for a 51.
Posted By: bob4
Date Posted: 15 August 2022 at 8:06am
Depending on crowd size, 4 hd 15 PD loaded should be fine. Of course it won't create earthquakes, but a stack of four is not bad at all. When I started out, I had 4 x HD15 loaded with wimpy kappa 15LF. Played loads of reggae and jungle, was perfectly fine. Stack of 4 will definitely drop below 50 Hz, it will just be a bit less loud. If you play at moderate levels and not all out, you can even dial in a bit subbass with eq. But be careful though, long festival days will put a strain on ypur system. Make sure it gets a bit of rest once in a while.....
Posted By: levyte357-
Date Posted: 15 August 2022 at 8:58am
HD15s on sub, will never be fine for Reggae, DnB.
Even as a Mid bass cab, compared to others, HD15 is not impressive..
Freq resp of HD15.
Good luck trying to get enough sub out of that, to play DnB/Reggae, to discerning listeners, outside.
Also, Beyma CP800TI is a dreadful sounding comp, above 10khz, Beyma CP750TI is much better, and great outside, even on budget, large format horn, like Paudio PH-4525.
Playing outside is completely different to playing in small venue, mediocre system will embarrass you and your crew, and blown drivers, due to pushing system beyond it's limits will cause further loss of reputation.
If you don't have the budget to build system suitable for purpose, maybe better you hire in 3x 1850 Horns and  3x MT121s.
Will have to run the 1850 horns upto 160hz, but will still sound better than HD15s.
Posted By: bob4
Date Posted: 15 August 2022 at 9:31am
Anyway, it largely depends on crowd size, and other factors. Without knowing the crowd size it's a bit pointless to give advice. Depending on context, Levyte's advice could be true, but under other circumstances you could be perfectly fine with the proposed setup.
1mansoundsystem, you need to provide a bit more information. How big is the crowd, etc.
Date Posted: 15 August 2022 at 1:17pm
To go with your Hogs, build 4x ES18s, and 4x MT121s.
As long has all cabs powered suitably, with decent LMS setup, Industrial strength outside system, right there.
I have a video somewhere, of 4x Scoops, with 4x Boke kick cabs, and 4x MT121 tops outside.
Unintentionally, that 1x stack, drew a crowd of around 1200 people outside, and had them dancing past midnight.
Date Posted: 15 August 2022 at 1:23pm
damn......
crowd is 9 people. this is a paintballevent and we play for ourselves at campground,
maybe growing some people in the night. no crowd, no audience etc.
this the first time i can play the HD15 outside, so thats why i chose them over a 2.1 pa.
and bcuz i love horns.
i could add a hog or more HD15 but that wont make sense, bcuz our transporter has to carry a shitload of pb-equipment for 3 people and people want to chat in the evenings or in between. so just a slightly bigger festival-rack at the campground.
my question was all about, if the 4x HD15 can bring up a reasonable amount of bass or if it sounds
weird bcuz of a lack of subbass. now i got a first impressions and thats cool.
CP800TI vs 750TI: the 800 doesnt look too good over 10 khz, yep.
im not on a budget, would you recommend exchanging them for 750s, or hitting it with the EQ at ~15khz and ~17khz ?
i got 4 MT122s so that means exchange 4 CPs.
which kickbins would be better for that purpose of solely kickbass? my descision to build these was
bcuz i listened to them live and was blown away by that combo (4 hogs and 4 HD15, couldnt get to know which drivers they have been loaded with)
Date Posted: 15 August 2022 at 1:31pm
damn......
2x Hogs, 2x HD15s, 1x MT122 would be great.
For the future, 2x MT121s, sound better than 1x MT122, and easier to transport/stack.
Date Posted: 15 August 2022 at 2:00pm
Also, you are far more likely to get away with a stack of 4x ES18s on sub down to 50hz, as opposed to HD15s.
But be aware, strong subby drivers for use in ES18, will not do anything nice over 150hz.
Date Posted: 15 August 2022 at 2:09pm
very unlikely that i dispose of the MT122s bcuz they have been an insane amount of work, ...and.. you know.... but i will keep your recommendation in mind. and yes, the MT122 are a pain in the ass to transport.~75kg a piece. Ouch
-------- a little OT:
our campingground will be ~20x20m 7-8 tents, 4 cars.
last year we had 2.2pa. 2x 12" thomann the box active, and 2x active subs fun generation
(15" 179eur/1pcs). the worst crap there is. i tried to keep them from spending so much money for this junk.... he bought 6 of these subs and is now is in the process to see, that i was right by telling him: save up, buy decent 2.2PA, and to regret but wont admit it, of course, now that he sees, that more and more of his subs causing issues. you know how things go......
the tops were bought used, age and usage unknown, and got a damaged gain-potis both the same night. one sub started to razzle n scratch at certain volume, the laptop couldnt be hooked up to the pioneer-mixer, our dj lost control, and he took one year, to appoint the failure to the software that suddenly wont work together with the mixer anymore. he said.  Stern Smile
thats why i will do the sound this year, my planning, my equipment, and im pretty confidend, we wont have those kind of issues again. i will report back about my impressions on the performance of the setup Thumbs Up
Date Posted: 15 August 2022 at 2:11pm
You will blow CP750TI, trying to get plenty 15-7khz out of them
If budget not an issue,  look at Beyma CP750Nd, with flattening eq between 8-14khz, will be solid upto 16khz, especially in multiples.
Date Posted: 15 August 2022 at 5:08pm
For the space reasons you suggested plus crowd of 9 people just take the 4 hd15s. And put u with the no sub bass. Ive hornloaded 4 es18s a few times without subs and yes it produced a decent enough level of bass for the type of function it didnt have any decent sub whatsoever. If you know the music you are playing and have played it through decent subs you will no whats missing. But for your proposed function id just crack on. Id rather the 1 hog 1 hd15 and 1 midhi combination
Posted By: JulianDA
Date Posted: 15 August 2022 at 5:09pm
damn......
I think 4 HD15 is more than enough for 9 people :D when we first build our 6 HD15 we used them for an outdoor techno/psytrance party with 50-100 people and where really suprised at how nice it sounded despite the measurements saying that it would lack in bass... i mean you won't get trouser flapping lows, but i think you will be happy with it. Maybe use a lowcut (24dB Butterworth) around 40-45Hz and push 50-55Hz (maybe +4-6dB) with an EQ and you will be fine :)
Date Posted: 15 August 2022 at 5:50pm
 I once heard a dude say, "I Have 2x ears, so need sound from 2x stacks" !!!
WackoLOL
Date Posted: 15 August 2022 at 6:19pm
thats true, haha. but since transporter space is limited, the 4 hd 15 + 1 mt122 iss all we can fit into it with all the other stuff like pavillon, tents + peripherals, beercrates, fridge, chairs, pb-equip etc.
yeah, 1 hog would kick ass, but since this is not even a music-festival, late-night activities are limited to
some drunkards singing karaoke and vomit in the bushes. 1 hog in addition would be only considered, if feedback here would have shown that hd15 are in no way capable of any bass at all. we had them playing inside a few times, and they blew out some serious sound together with hogs. but as some said, outside is a totally different thing.
levyte357: i was talking about equalizing that weird range from 15khz-17khz of the beyma cp800ti
i really dont wanna blow any of my beloved speakers - they too expensive :/
Posted By: Earplug
Date Posted: 15 August 2022 at 7:09pm
Yes - sometimes the recommendations here are a bit OTT and more directed at large parties & Big Bottom Nutters!
LOL LOL LOL
And down here, some of the systems you see at the attractions at the fiestas can be ridiculous - also OTT overkill.
Which is why I loved these:-
More than adequate for the job they needed to do.  Smile
Posted By: bob4
Date Posted: 15 August 2022 at 8:06pm
+1 Clap
Mono stacked two wide two high will do. I did it many times, outdoor, no problems.
70-80% of the music you will not be missing anything
Date Posted: 15 August 2022 at 10:39pm
awesome, thx for your feedback!
Posted By: monkeypuzzle
Date Posted: 15 August 2022 at 11:53pm
If your wanting small format 15”, I had 4 then 8 HD’s 15 years ago and now absolutely love my THAM 15 cabs, they aren’t mega loud but they sound really nice and work with pretty well any music style I put through them.
Posted By: teeth
Date Posted: 23 August 2022 at 9:43pm
not sure about that... my 4 HD15's didn't do so much with a pair of 218s
that could be because they had fane sovs in them
or they were being measured agains 2 218s
hmm
Date Posted: 23 August 2022 at 11:35pm
i finally had to rearrange the setup to 1 hog, 2 hd15 and 1 MT122.
not bcuz erratic brain, but some dudes requested the hog, they could
remember this foe from 2y back when we had our partyroom and did some 12cm concretewall
cracking with 2 hogs 4 hd15 and some other wildly assembled stuff at full volume.
so they voted for having a hog at the location. at least the question if there is enough bass is gone now. if you interested, i make some videos when all is up and go. i do some funky lighting stuff too, bcuz building cabs and doing lighting/laser/uv-deco are my hobbies
and if you want to join us, we at poland, brozek, scenario big game paintball event, if by any circumstances u be there, come over and have a drink with us (u hear/see us) Thumbs Up
