Paraflex in reggae
Category: Other Chat
Forum Name: Roots n Culture Forum
Forum Description: Talk about speaker box with other sounds here
URL: https://forum.speakerplans.com/forum_posts.asp?TID=107327
Printed Date: 26 March 2026 at 9:48pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Paraflex in reggae
Posted By: BigSoundNorthWest
Subject: Paraflex in reggae
Date Posted: 04 September 2022 at 10:25am
Been hearing some good things about paraflex bins and tops. Who else, apart from Sinai and Volcano, are running paraflex, in dub n reggae. I heard Volcano at NHC.
Posted By: JamesH
Date Posted: 08 September 2022 at 7:49am
have u checked the facebook page?
Posted By: vibes92
Date Posted: 23 November 2022 at 3:25pm
Posted By: levyte357-
Date Posted: 23 November 2022 at 5:02pm
So forgetting about sims and plots, how does 1x21" paraflex, compare with a decent 21" Full Scoop, 32hz - 100hz !?
------------- Global Depopulation - Alive and Killing.
Posted By: bob4
Date Posted: 23 November 2022 at 6:58pm
Wasn't there a post here on speakerplans from a person that replaced 18" scoops with altcon 15" paraflex loaded with 15ds115 (yes, those exist, that's not a typo!!). He reported very good initial results.
Iirc it was user "noud", in a thread about a top build.
EDIT: found it!
https://Forum.speakerplans.com/2x10-vented-horn-idea_topic100997_page8.html" rel="nofollow - https://Forum.speakerplans.com/2x10-vented-horn-idea_topic100997_page8.html
Edit 2: scoop was apparently fane 18xb loaded.....
Posted By: bob4
Date Posted: 23 November 2022 at 7:14pm
Noud wrote:
Goodevening Guys,
I Started building some new subwoofers to replace my scoops. so I looked at a lot of different kind of subs like: -th18 xoc1 -cyclops -tham18 -tham 15 -Cubo sub -21 br and finally a paraflex Altcon 15
I wanted to be smaller go just as low or lower en just as loud. (if possible  ) so I started reading and reading and a bit more of reading. until I finally decided to go with the Paraflex Alton 15. the Hornresp sim so a similar output and range as the scoop. so I de build begon and there are some result in the pictures.
Keep in mind the scoop is about 590Liters and the Alton 15 only 312Liters
Green=scoop 18XB Purple=Altcon 15ds115
HPF=34hz LPF=100hz |
Posted By: luton_soundman
Date Posted: 24 November 2022 at 2:58am
Not even comparable to a shutter ply 18" sb with minimal bracing. I wouldnt even use paraflex for pa let alone reggae. Definatly a design that shouldnt have left the work shop imo.
------------- Sound Hire/Sales new/used equipment.
Date Posted: 24 November 2022 at 2:22pm
If I was going to move away from scoop based bass, I think I'd rather go bandpass style , kinda like what Kutty is putting out, rather than paraflex...
Posted By: Sinai Sound
Date Posted: 24 November 2022 at 9:17pm
If you want to come over the Pennines with your boxes, you're welcome to A/B them against mine
Got a warehouse space with 3 phase power where we can run it as loud as you want.
This offer goes for anyone.
Posted By: cookie-dj
Date Posted: 25 November 2022 at 3:04pm
I think I will build 18/21 double bandpass manifold boxes from the 18sound enclosure designs page - if I get bored of my mini scoops. I like their drivers too!
------------- You can't polish a turd!
Date Posted: 25 November 2022 at 3:43pm
luton_soundman wrote:
Not even comparable to a shutter ply 18" sb with minimal bracing. I wouldnt even use paraflex for pa let alone reggae. Definatly a design that shouldnt have left the work shop imo. |
In my universe, a 1x21 paraflex, would need to "Thanos" a 1x21 Full Scoop, 32hz-90hz, to justify it's existence.
Posted By: goodgroove1960
Date Posted: 25 November 2022 at 8:02pm
I have heard a 21" Paraflex a/b with 21" hog , 21" flh and 21" tapped horn all run on same amp , just a listening test ,it was agreed by the 6 people present the paraflex was very impressive over the other cabs , will say it was noted it had a 4r driver but even so in all aspects it suprised us
Date Posted: 25 November 2022 at 9:26pm
Just a strange cab. Big in size but doesnt play very low but also doesnt play the higher end all that great. And the throw/coverage hasnt been good from what ive witnessed. I've put my 21" project on hold for now but that would be the last cab id go for.
Posted By: turbo7
Date Posted: 17 January 2023 at 12:27pm
A scoop loaded with 18XB can have 14dB less output at 33Hz than a "good" scoop. The 15DS115 is much stronger and shifts more air than the 18XB
Posted By: JamesH
Date Posted: 17 January 2023 at 1:26pm
Date Posted: 17 January 2023 at 3:14pm
turbo7 wrote:
A scoop loaded with 18XB can have 14dB less output at 33Hz than a "good" scoop. The 15DS115 is much stronger and shifts more air than the 18XB |
Yes, a Fane 18XB loaded Scoop, may sound more musical and smooth than many others, but what I class as a "good Scoop", would be a Scoop optimal for PD1851 or 18NLW9601, being powered by K20 or Void Inf8MK2.
That's when you are closing on an ultimate 18" Scoop, worthy of comparison to other cab designs.
Posted By: vibes92
Date Posted: 08 February 2023 at 8:40am
theres a dance coming up in leicester with 3 sounds and they all have paraflex
concrete lion sinai epiphany
Posted By: spongebob
Date Posted: 08 February 2023 at 9:42pm
Probably for the best so no one shows up the other
Posted By: Maze
Date Posted: 09 February 2023 at 6:24am
I've seen sounds go from scoops to paraflex, and not the other way around. What does that mean?
Date Posted: 09 February 2023 at 8:53am
People buy and sell for different reasons, logic cannot always be deduced from it.
Some people don't like Paraflex, some don't like Scoops, some love 2x18 reflex above everything also, some say 2x18 reflex are not efficient enough, Rig owner can do what they want, it's their money.
Posted By: smitske96
Date Posted: 09 February 2023 at 9:05am
Also depends from what you move on. If you go from a scoop loaded with drivers like the Fane XB and go to something with a 18DS115. Chances are big you will get an improvement with any other design with that size.
Posted By: JamesH
Date Posted: 09 February 2023 at 9:30am
This is it, basically. Reggae sounds, they like what they like. People like the "new" thing. Some, like the older ways. And some want to be on the "bleeding edge".
As long as the dance runs nice, it's all good
Posted By: vibes92
Date Posted: 09 February 2023 at 9:47am
i have heard concrete lion at there launch dance, sounded very heavy!
i heard sinai at subdub sounded very heavy
and i heard ital power the other week with new qss 18" scoops very heavy
also jah youth with double 18" sounded very heavy
Posted By: snowflake
Date Posted: 09 February 2023 at 10:01am
paraflex is a new design. notice the number of people NOT switching to paraflex
Date Posted: 09 February 2023 at 10:12am
I'm a well known Scoop lover, but if I were being hired to do NHC carnival floats regularly, I'd probably be using 186 Horns with naughty driver, and neo loaded MT122s on top, easy money.
So as I say, Rig owner choices, don't always follow accepted wisdom.
Posted By: vibes92
Date Posted: 09 February 2023 at 10:52am
me personally, scoop all the way
Posted By: Maze
Date Posted: 09 February 2023 at 1:12pm
snowflake wrote:
paraflex is a new design. notice the number of people NOT switching to paraflex |
People don't buy a new car every time a new model comes out.
I'm running reflex in my humble rig. I'd love to have scoops, because I love how they look. To me it's the best looking sub of all time. I built one to test and I also loved how it sounded on reggae, but could see where it would come short on other genres compared to my reflex. Tbh, I've heard a system in Denmark that played with 8 (Jah Tubby) scoops and to me... that was a bit of a loud mess, very harsh sounding compared to the other sound that was set up that night. The other sound had something a forum member here built. I think it was 21" ported. Very warm and nice sounding bass, but admittedly not as brutal as the scoops, maybe brutal is not what I enjoy at the end of the day, I dunno.
I'm also very curious about Paraflex, and I'd love to hear them when I get the chance. I did built a Paraflex kick bin to try, but never loaded it with a recommended driver. And the whole project fizzled out when Covid hit.
I'm going of a tangent, the point is, a lot goes into the choices we make for sound, such as personal preferences, economy, what crowds we are playing, etc.
I think your argument is a bit of glass half empty kind thing. I see sounds on Facebook that have moved to Type O etc. from scoops and have been very happy with their choice. So I don't see why Paraflex could not be an option for a reggae oriented system.
Date Posted: 09 February 2023 at 2:24pm
everyone in the world making bad decisions think they have made great decisions (done it myself). maybe paraflex are great but without any decent measurements or side by side comparisons it's just hype.
Posted By: KaphaSound
Date Posted: 10 February 2023 at 1:52am
FWIW I posted this in another thread, attended the most recent SubDub which had Iration Steppas, Higher Meditation and Jah Youth going track for track in one room with MCs and Sinai providing sound with DJs going b2b2b and MCs in another larger room, plus a smaller half rig setup in another room. Right off the bat I can say that Sinai needed more headroom based on the content and also had 2 subs a side, whereas each dub system was never mixing 2 tracks at any given point and had 4 subs (I believe) in a single stack, so yet another probably pointless comparison.
Having said that, the dub systems all had that “floaty” feeling where the bass was thick enough to feel like you’re swimming in it and they also overloaded the phone mic until it turned itself off. The paraflex rig as others have mentioned from other gigs just didn’t appear to go as low or as loud, but having said that the energy from the crowd was much rowdier and lively in the Sinai room so to most if not all it wasn’t an issue and still a great show.
It looks like Sinai (Huw) has offered to host a proper shootout anytime, so it would truly be great to have a good faith shootout with a more traditional setup.
One thing I do feel that is worth mentioning is that this skepticism of Paraflex imo is largely brought on by the unnecessary defensiveness in the FB group and community like shadowbanning etc. Just the other day I saw MMJ bashing traditional designs again because you can’t physically touch the magnet to feel how hot they get, and fair enough thermal issues may arise sooner in FLH, but that’s not a real world comparison and feels like cheap marketing to those who don’t know better. So TL;DR what snowflake said.
Posted By: Maze
Date Posted: 10 February 2023 at 2:16am
I've never seen "bashing" of other designs in the Paraflex groups. But there was a very detailed comparison between Iration and Sinai from when they played in the same room one time. You should be able to find it in the FB group. It was written by a fan of both Sinai and Iration and seemed very level headed and unbiased.
I think it's best to just go listen for oneself. I like reading different people's opinions, but it really comes down to personal preference at the end.
Posted By: JamesH
Date Posted: 10 February 2023 at 7:40am
I've messaged Huw about taking my bandpass rig over soon, so I'll post here when I get a date, if anyone fancies bringing some boxes same day?
Posted By: Sypa
Date Posted: 10 February 2023 at 10:15am
I only mentioned scoops in some discussion on MMJ facebook and got banned , was a relief
Posted By: King Simeon
Date Posted: 10 February 2023 at 10:24am
Something else to bare in mind is not all scoops/boxes sound the same, and not all operators will want or shape the sound the same.
A lot of folks could have a clean set, but look to create distortion. It's been quite interesting to see some operators who have come through playing 'raw' more basic boxes changing up and how they either adapt to the newer box tunings/set up, or find a way to create a newer/different presentation. I think that's what has been interesting about the talk on paraflex.
It's never as simple as one box or another, or what single pre amp you use. So many variables, it really does come down to knowing what you want (sound/Freq) and trying to get it.
------------- https://www.facebook.com/KingSimeonSound?ref=stream https://soundcloud.com/king-simeon
Date Posted: 10 February 2023 at 11:07am
King Simeon wrote:
It's never as simple as one box or another, or what single pre amp you use. So many variables, it really does come down to knowing what you want (sound/Freq) and trying to get it. |
Like this.
Also, is the System Engineer, suitably experienced and skilled, to extract optimum performance and sound quality, from what he is using.
Many soundsystems, have given certain sub designs, bad name, by not fulfiling, the above.
Posted By: Maze
Date Posted: 11 February 2023 at 5:36am
Was not my experience at all going into the FB group looking for a kick to put over my scoop at the time. There's quite a dissonance between these type of comments here on sp and my own experience on their site. I get that they don't allow people to critizise their designs on their own site, but that's what we have sp for anyway, a kind of neutral forum for discussing all speaker designs. But that you can't even mention other designs on there..? Lot's of people come on there like I did to find tops, kicks, or subs to combine with whatever other stuff they have or are planning to build. And I know a lot of the members there have lots of love for scoops and other designs.
Posted By: JamesH
Date Posted: 11 February 2023 at 9:21am
"Just the other day I saw MMJ bashing traditional designs again because you can’t physically touch the magnet to feel how hot they get"
Ahhhh yes, lol. For YEARS, folk have been asking him about thermals in his boxes, with him having NO IDEA or response, suddenly, he's posting a tonne on it, and chastising all n sundry, over a thing he's JUST finally seems to have grasped.
Posted By: JamesH
Date Posted: 11 February 2023 at 9:27am
By ALL means, you can discuss other designs, if you plan to put paraflex IN your rig.
But, ask for info, graphs, testing, measurements or comparison, then the salt starts.
Posted By: Maze
Date Posted: 11 February 2023 at 9:34am
If you ask a question here about a scoop in the general forum it gets moved to scoop forum where it belongs, same principle. I don't see how the Paraflex site own it to anyone to deliver anything, you can use what the website has to offer or leave it alone. Simple ting.
Date Posted: 11 February 2023 at 10:51am
yet, in a PARAFLEX page, you ask how a PARAFLEX performs at all (ie, measurement, testing), or how it performs compared to another,m and you get shit for it.. which is WHAT I SAID. also, ask for test or measurements on the scoop forum, you GET them.. ask for the same on paraflex, you get MS Paint drawings and a lack of cohesive results etc.
for the record, you know we have all SEEN the page mate, so telling us 2its not like that" is pointless
Date Posted: 11 February 2023 at 10:56am
"I don't see how the Paraflex site own it to anyone to deliver anything"
ok, so if i say:
"i own the loudest speaker box on the planet......." or some such BS, then:
by YOUR logic, i now owe nothing proofwise to ANYONE to have to back my claim.........?? exactly.
nope. same with paraflex, all folk are asking for is proof......
also:
"I get that they don't allow people to critizise their designs"
seriously mate, you feel that THIS is the way to promote your box design, by allowing NO ONE to criticize? lol... my god, what kinda backwards ass thinking is that?
Date Posted: 11 February 2023 at 11:02am
ok, so if i say: "i own the loudest speaker box on the planet......." or some such BS, then: by YOUR logic, i now owe nothing proofwise to ANYONE to have to back my claim.........?? exactly. nope. same with paraflex, all folk are asking for is proof...... also: "I get that they don't allow people to critizise their designs" seriously mate, you feel that THIS is the way to promote your box design, by allowing NO ONE to criticize? lol... my god, what kinda backwards ass thinking is that? not to mention, you have just said: "Was not my experience at all" so which is it? you CAN critique, as you said? or "its not your experience"?????? as you also say.
Posted By: Maze
Date Posted: 11 February 2023 at 11:04am
ok, so if i say:
No. Hyping your thing is one thing or sharing your excitement for something is OK by me, but to put forward false claims is another. But have such false claims been made? Please link then, cuz I've just not seen that, but I could have missed it.
Date Posted: 11 February 2023 at 11:10am
yes, youve definitely have. and no i cant, (apart from the one below as MMJ barred me for asking why the box design DOES NOT change, between 18 and 21" drivers...)
which BTW, is a MASSIVE RED FLAG as far as box design goes.. but whilst we're here, check THAT "fact" for a start as evidence of the BS... PLENTY claims that box size doesnt need changing for a 3inch driver diameter change....
Posted By: Maze
Date Posted: 11 February 2023 at 12:42pm
I've responded to specific statements that I think grossly exagerates. Like if you say "scoop" on the site it's an automatic ban. It's those kind of statements that I find ridiculous.
I think speakerplans is sufficient a forum for scrutinizing the designs. I personally don't think the Paraflex website has to constantly answer every naysayers questions. If they did fine, if they don't also fine (by me). We have right here to discuss the desings. But then let's also not make false claims here either, and be specific of what exactly incorrect information they have passed on.
Scoops is an interesting example because even though they perform poorly on paper and is an outdated design in many peoples opinion, they are still a popular design.
Posted By: jammin75
Date Posted: 11 February 2023 at 3:03pm
wot paper is that ? the sunday sport
king of the dancehall
------------- feel the vibes !!! "Who Feels it Knows it" Strong like Lion
Posted By: Maze
Date Posted: 11 February 2023 at 3:45pm
king of the dancehall |
Hope so, i still plan to build more some day. I want scoops to be best because they look best.
Posted By: Maze
Date Posted: 11 February 2023 at 3:47pm
Date Posted: 11 February 2023 at 5:05pm
ok, so if i say:
"The other benefit of this approach (assuming the HTR and LTR are phase coherent) is that the group delay profile of these boxes far more consistent across their passband than tapped horn, bandpass and most reflex designs."
Date Posted: 15 February 2023 at 3:54pm
Looks like Firmly Rooted and Sinai just had a nice comparable setup side by side, anyone manage to make it out?
Posted By: JamesH
Date Posted: 15 February 2023 at 9:17pm
No, what do F Rooted run? Im looking forward to taking my BP boxes over Sheffield soon though....
Posted By: hectorberman
Date Posted: 15 February 2023 at 9:44pm
Firmly rooted run polar bear scoops I believe
Posted By: turbo7
Date Posted: 19 March 2023 at 9:09am
Its a sect, one gets banned if questioning the 108dB 1w/m halfspace graph. Its utter nonsense to publish those numbers.
Any decent 2x21" BR or Bandpass with less volume will eat any paraflex alive. Typcially, the best 2x18" have a sensivity of 101dB halfspace, a fullspace SPL of ca. 95dB 1W/1M 30-100Hz.
The designs are mostly bad, a bad design is when your driver hits xmax way before receiving its power rating specs. Therefore, maximum SPL of a driver can simply not be achieved.
We are ready to organise shootouts with any paraflex design, but people are shy, nobody has the balls to bring the toys, as anyone knows its going to be very clear which design is good and which is hype.
Posted By: turbo7
Date Posted: 19 March 2023 at 9:14am
I know the outcome and its going to be a desaster for the paraflex, but there will be no proof at least here - nobody will show up with Paraflex
Posted By: Esc4pe
Date Posted: 19 March 2023 at 10:34am
Isn’t nearly every horn design ever like this? Certainly wouldn’t call them all flawed! If the db / 1w is high then surely that doesn’t matter as it’s just a different way of achieving similar levels?
Tbh to me the want for getting the most out of a small power supply far exceeds the want for soaking a load of power up into hefty drivers.
Maybe I’m missing the point?
Not sticking up for paraflex as I am still yet to hear
Posted By: turbo7
Date Posted: 19 March 2023 at 11:12am
It depends on the driver if it is suited for hornloading or not.
If you got the best horn 18" you can find, it will not even reach its x-max with full power applied with a correctly matched scoop.
Try simulating any of the best available drivers in a paraflex, its OFF. Technically speaking, a bad impedance matching just means no real but more imaginary loading of the cone, that is the case with paraflex at certain frequency(ies), that is the case with any cone loading below the horn cutoff, the excursion will rise but no SPL, because no loading. That is the reason one needs a highpassfilter with Subwoofers depending on the tuning frequency.
Applying Voltage that does not contribute to power to SPL conversion but to heat...
This is a general rule that applies for all subwoofers - if you can not put in the power rating of a subwoofer, already reaching Xmax - you will end up with less SPL compared to the one that takes the power mechanically ( and more.. )
Thats it, and any paraflex is welcome to get destroyed, i have a lot of respect for Sinai sound which is the only big sound i know who stands strong with his system, making him an example.
I would not even be interested at all in Transmissionline derivates, but if the sect tells the world they got 108dB 1w/1m halfspace, this can not be ignored, too many people get fooled by this idiots, its simply a blatant lie, nobody is going to discuss it as one gets banned immediatly.
Date Posted: 19 March 2023 at 10:37pm
I would even prefer single 21" reflex over the paramess
Posted By: turbo7
Date Posted: 20 March 2023 at 6:46am
its no problem for me that people working with the bass they like, i have no bad feelings about paraflex at all, i like progress in any way, but the behaviour of people behind these projects is irritating. If the design is that good - why put out fake graphs and ban any discussion about it...
For comparison. This is the Gjallarhorn, a large tapped horn which is comparable in size with the CE2E. This is a groundplane measurement.
This is the measurement of the L Acoustics K28 Bass, which is near the theoretical maximum of output of a 2x18" ported Bass. The industry standard, Full space measurement. If we recalculate that to groundplane, just add +6dB to the curve. If we compare that to the CE2 groundplane measurement, we learn that 2x K28, which is 4x 18", is still 1dB less in output at 50Hz.
That is a lie. We are talking about 4x 18" vs. 1x18".
This is one of the "official" groundplane measurements of the C2E:
Date Posted: 20 March 2023 at 8:35am
Which is why some paper needs to be ignored.
Don't know why some still cannot accept, not all Scoops, are the same Fane, Eminence, JBL Design, from 50s/60s/70s, and some people know to tune/change/evolve an old design, to suit modern drivers.
In the real world, with all that's going on, and the number of people dying from war daily, Scoop vs Paraflex doesn't really matter.
Instead of all the online keyboard warrior lark, "many" would just require a Roots Reggae soundclash/dance, with very good Systems of both types, in large venue, with decent power, and each system having "8x" sub drivers each.
As speakers are designed to play music, and entertain.
I'll reserve my judgement, until one of the above occurs.
Date Posted: 20 March 2023 at 9:30am
When Matthew starts posting graphs / schematics that arent done in MS Paint, ill take more notice tbh
Posted By: Norseman
Date Posted: 21 March 2023 at 5:52am
in response to the firmly rooted question:
polar bear scoops es18bph QSS midtops are their new ones
