Cloud VTX repair and restoration
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=107442
Printed Date: 19 April 2024 at 2:49pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Cloud VTX repair and restoration
Posted By: Randy Bohannon
Subject: Cloud VTX repair and restoration
Date Posted: 28 October 2022 at 1:54pm
The latest instalment in the resurrection of my teenage amplifier collection, Ole Faithful... the Cloud VTX 750, the amplifier that took more abuse than any other and kept going...
This thing has a cooling fan which put the average Dyson to shame and as a result barely even needed recapping despite having been on for most of the late nineties/early noughties.
I thought it might need brushing and hoovering, it actually needed sandblasting and acid pickling.
Dust seems to have retained moisture and caused rusting inside the case, this was brushed back and pickled in rust remover before being given a coat of rust neutralising paint.
Boards were stripped of the heatsinks and completely scrubbed down with meths, the years of fag smoke grime that came off them was unreal.
Heatsinks went into the ultrasonic cleaner, half an hour and very hot cleaning solution beat elbow grease every time as far as I'm concerned... :D
Repairs so far have been a few dry solder joints, a TX 304 bais spreader transistor that measured a gain of 2 on the transistor tester and cleaning the level pots.
There is an issue with asymmetrical clipping on one of the channels, it effectively clips earlier on the positive part of the waveform than on the negative and the effect worsens under load.
I suspect the driver transistors, will investigate and post some photos of what I mean later.
Posted By: kedwardsleisure
Date Posted: 28 October 2022 at 6:02pm
Lovely! The VTX were essentially an improved version of the CV series with more modern mosfets and a few other tweaks, designed I think by Andrew Colley and then morphed into the VTX by Julian Usher.
They were an expensive amp in their day, very few foibles really, the earlier habit of going DC and melting the speaker relays was mostly cured by a factory mod to the offset circuit and fully incorporated into the VTX boards. The clip limiter was also modified from a VCA based one to an optical one which is more reliable, the old VCA chips sometimes developing weird behaviour as they aged.
Nice to see them being loved!
------------- Kevin
North Staffordshire
Date Posted: 28 October 2022 at 11:09pm
Thanks for the information Kevin, always appreciate hearing the history of these things.
It's a good amp, not just in terms of longevity but also it actually sounds pretty good. It is quite a fast class AB MOSFET amplifier and I have been wondering whether an upgrade to the TL072s in the signal path might be worthwhile. I am trying to work out whether the opamps need to be JFET types like the TL072, and replaced with something like OPA2134, or whether a NE5532 can be slotted in. Looking at the resistors around them, I am thinking that a NE5532 would give better performance than the originals and not cost as much as the OPA2134 to boot.
The weird clipping behaviour is as below:
Date Posted: 29 October 2022 at 12:20am
I wouldn't touch the op-amps. nothing to gain. I would disable the clip limiter using the onboard selector and see if it still clips which might help to narrow it down. I assume you've checked the zeners are balanced and the droppers are in tolerance. You might also have a gate-source leak on one of the output fets which is loading the drive current down. Measure the idle current by checking the mV across the emitter resistors to make sure they're balanced. Use those j-hook test leads rather than multimeter probes, just to avoid an explosive slip of the probes. I can't think of anything else off the top of my head apart from the odd fractured tracks around the hot parts of the circuit.
------------- Kevin
North Staffordshire
Date Posted: 29 October 2022 at 6:36pm
Thanks for the reply Kevin, in short I found the issue with the help of the nudge in the direction of the emitter resistors, R58 had developed a invisibly dry joint, found only by measuring a very weird high voltage across the source resistor of an ice cold MOSFET:
Waggling R58 by chance solved the problem with the amp running out of current on the positive portion of the waveform, makes sense as one MOSFET as effectively out of the circuit and the stage sagged trying to produce the current from the remaining two.
There is an imbalance between the channels that is due to the gain pots, they will need replacing it seems.
Another small issue is that the channel B signal LED won't illuminate no matter the signal level and the overall power is a little lower than expected, clipping at around 150-160w at 8ohms rather than the spec'ed 190W. It manages 280 into 4 ohms, which is in spec, but this seems to be explained by the rails measuring at 58v at no load rather than the 64v the schematic gives.
I'm listening to it now, it's a good sounding amp through a set of Orpheus floorstanders, punchy and very airy in the top end.
Date Posted: 30 October 2022 at 10:58pm
the leds can fail, just sayin!
------------- Kevin
North Staffordshire
Date Posted: 31 October 2022 at 2:12pm
I hope it's not that, I've already embarrassed myself with the test points on the crown as it is...
Massive thanks to Colin and Jon as Cloud Electronics, they went over and above to help top find the bias figures for my very old, Hitachi lat-FET using, unit; buy British!
Date Posted: 31 October 2022 at 2:18pm
I tried a square wave test on it, it seems that the inherent bandwidth of the amplifier has been, sensibly given it's a PA amp, been band limited.
Did notice it doesn't like clipping at 20kHz, ugly with a bit of rail sticking. It could probably do with the refresh of the small signal semis, maybe even a opamp swap in pursuit of the almost wholly pointless goal of a nice 20khz clipping?
Date Posted: 01 November 2022 at 8:37am
you could have asked on here, I have the figures
------------- Kevin
North Staffordshire
Date Posted: 01 November 2022 at 11:53am
Thank you for all your help Kevin, I certainly would have but as it turned out I ended up calling them up in the heat of the moment and was pleasantly surprised to be put through to the actual engineering team at the company. they said they thought it was 25ma (turns out this figure was for the later IRFP240/9240 revisions) but emailed me the next morning to say they'd looked through old notes and the figure for the Hitachi Lat-FETS (100mA per device). Really great service and getting hold of people like that is a great reason to buy British if at all possible, I have to say. :)
What are your figures, out of interest? I tried a minimum of 33mV across each resistor for a an average of 100mA across each device at first. It sounds good but lacks... I don't know a bit of treble sweetness that good fast MOSFET amps have? I'm going to give it another day or two, try it on my dad's Quad ESL63s and maybe push the bias up to around 200mA per device. From what I tried buggering about ~300mA is where you start flirting with thermal runaway and so for a retired amp, 200mA may be ok.
I found that the current sharing at idle wasn't spectacularly good in mine, with the MOSFETs furthest away from the fan consistently showing a higher bias current flow for a given adjustment of the bias pot than the FETs closest to the fan.
Current sharing at full load wasn't too bad, though again the MOSFET furthest from the fan consistently showed a greater current across both sides and both boards. Perhaps they are getting a bit tired and could do with replacing in an ideal world but for the life this amp will lead, no fear.
Thanks again for your help, I would have endlessly buggered about with the small signal stuff if not for your tip on monitoring the emitter resistors individually.
Date Posted: 01 November 2022 at 12:01pm
Yes that's right, 100mA each for the hitachi fets and 25mA each for the International Rectifier ones.
------------- Kevin
North Staffordshire
Date Posted: 01 November 2022 at 12:22pm
I suppose the considerations are different for a PA amp, reliability over all things, but my Hafler DH200 seems to have a sweet spot at around 200mA per device, be interesting to see if this responds the same.
Posted By: kipman725
Date Posted: 01 November 2022 at 3:01pm
Its funny you mention the high air flow and then sand blasting. A couple of these I have fixed had not faults apart from a track worn away in the same place near the fan, when replaced with a wire they worked fine. I suspect the airflow eroded the track. Good amps if you don't care about the fan noise, I once ran one at full power for 45mins till the water of my test load boiled.
Date Posted: 01 November 2022 at 8:14pm
I noticed a few corroded tracks, particularly at the front and rear of the bottom amplifier board.
In my case I think it was corrosion from the dust it trapped, that fan is an 11W, 160f^3/m beast compared to the average pair of 30f^3/m low voltage fans in the average amplifier and so I think it just sucks in more crap than most. this dust then holds moisture and corrodes the tracks through the solder mask.
Mine doesn't have a dust filter behind the front grille, incidentally, does yours?
I'm not surprised with your result, I couldn't get mine to overheat full power testing either, the load (1600w continuous in theory) however did... :D
I'm setting it to the higher bias tonight for some critical listening tomorrow.
Date Posted: 02 November 2022 at 9:03am
probably overheat
------------- Kevin
North Staffordshire
Date Posted: 02 November 2022 at 12:07pm
no filters in any of the VTX750 or VTX1000 I had
Date Posted: 02 November 2022 at 4:31pm
kedwardsleisure wrote:
probably overheat |
Nah, not this puppy...
It didn't overheat but it didn't sound any better that I could hear either. I've biased it back to factory spec and declared it finished.
I did think about maybe fiddling with the opamps and making the input filter a little less severe but, as you say, it probably not worth it.
Date Posted: 02 November 2022 at 4:32pm
Cheers Kipman, I have some thin foam I will line the front vents with.
Date Posted: 16 November 2022 at 7:51pm
The new pots arrived and I fitted them, together with a new LED for the buggered signal indication.
It seems that Cloud went out of their way to find low output LEDs for the front the panel and I appreciate their efforts as the new one is too bright, really. I hsvr found a special, not-as-bright LED and bought it, whilst cursing my OCD.
however the signal indication for channel B still doesn't work. I really don't feel like pulling the thing apart again but it seems the problem is with the channel B PCB...
I have to say though, new pots seem to have improved the sound more so than any other single thing I have done including recapping.
Posted By: izzzzzz6
Date Posted: 16 March 2023 at 10:20am
I think i have about every type of Cloud amp ever made. I had a question but i can't remember what it is now. Oh yea. Does anyone know what RV1 is for? RV2 is bias. What is the bias setting on the VTX is it correct that of the transistors are the Hitachi pair i set it to 100mA? So sometimes the main transistors are International Rectifier? I have the Hitachi in a CV1000 and Hitachi in VTX1200. Oh, i see VR1 is for offset it's marked on a CV1000. How do i set offset? is this for the speaker protection circuit to be balanced? In one of these amps someone has soldered fixed value resistors to the underside of VR1 so i wonder why they needed to do that. Fixed quite a few of these recently, one thing to note is never to touch both heatsinks at the same time as they are live, i got a shock and blew something on the amp.
One repair was output transistors, several rotten tracks along the front of the board and one broken rotten track found under an audio cable that's soldered across the board on the cv1000. One repair was replacing the transistor that helps to regulate bias with temperature ZTX304 I'm going to swap with a BC639 but swap leg position, hope this works to do the same job. Another one had some strange resistances where someone had piggybacked some resistors along the speaker protection circuit somewhere. Putting those and one other resistor back to normal fixed that one. Would love to know where to set the offset. is that just done at the speaker output terminals? Cloud amps i own and will sell many of them: The 8ch with multizone mixer The 6x 120W i think. cv500 vtx750 cv1000 vtx1200 vtx1500
Petty decent, always ran very cool, need threadlock if you want to take them on the road. Bit heavy these days.
I noticed Old Croc mentioned noise on the older cv1000 etc due to an audio ic. I'm wondering if this is an issue i had on a cloud cv1000. I could sometimes hear scratchy random noise when the amps were on, not enough to hear over the music but annoying just the same. Assuming this was the same issue, does anyone know which IC tended to go noisy in-case i still have that amp somewhere. A Mr. Carlsons super probe would help here i imagine.
Just been checking bias on a vtx 1200 it was set around 25mA and max i could get was 60mA Did you mean 100mV? When i set bias to 100mV i have around 50mA across / between the + & - source legs of K414 and J119.
On the VTX1200 model i ended up setting bias to 25mA and offset to each speaker output to zero V. Couldn't find a service manual with the spec.
------------- Sound
Date Posted: 17 March 2023 at 9:39am
What is the bias setting on the VTX In one of these amps someone has soldered fixed value resistors to the underside of VR1. Would love to know where to set the offset.
Mosfet bias: Hitachi mosfets (old) are 100mA per device which equates to 33mV measured across an emitter resistor. Normally found in the older CV range (the predecessor of the VTX) When the hitachis were discontinued they moved to IR devices which need 25mA per device which equates to 8.3mV across an emitter resistor. The IR devices are selected so they current-share properly. If you don't use selected devices, it's very possible the amp will fail; this is because the IR threshold voltages have a wide spread, even in the same batch and it's not enough to just change them all since a low threshold voltage on one fet can mean it does all the work and the others sit biased off. If in doubt, measure the bias across each emitter resistor and compare the relative currents at idle. Threshold voltages in a matched set are within 25mV of each other of V.thresh. (not bias).
Fixed resistors: This was a factory modification, and the resistors were incorporated into later revisions of the pcb. It is to limit the amount of bias adjustment particularly if the bias trimpot goes noisy. Without the mod, an open circuit pot can cause the amp to go into DC protect with possible speaker damage. An intermittent pot can sporadically blow speakers or melt the speaker relays if you don't realize what's happening. The contact distance of the protect relays is barely adequate which is why they have magnets (should have!) glued to the side of the relays at the side of the contacts, to help to quench the arc if the amp goes go DC.
Offset: Just measure across the speaker terminals with no input and adjust for minimum DC voltage.
Noise: The earlier CV range had a VCA chip to operate the limiter, this can do alsorts of weird and wonderful things, generate tones, squeals and rustles. It's no longer available AFAIK and was changed to a different system in the VTX. But the biggest source of noise is probably failing bias and offset trim pots. The carbon tracks develop noise with old age and are easily replaced.
The earliest CV amps had really nice bargraph VU meters which were pretty. LEDs were still 'bling' in those days, easy to forget.
------------- Kevin
North Staffordshire
Posted By: izzzzzz6
Date Posted: 21 March 2023 at 11:17am
Hi Kevin. Thanks for the details. It almost seems they don't want
anyone biasing these amps. I blew 2 fuses in my multimeter just slipping
off of the small resistor and into the heatsink that also comes off of the same leg because it's not easy to get to the
underside of the main balance resistors perhaps i should try to clip directly to the transistors leg. The VTX 1200 I have been working on has Hitachi fets. One thing i found is that 2sJ119 and 2sk414 are quite expensive and a cheaper pair is available, the 2sJ118 and 2sk413 seem to be same spec except a lower voltage rating. Wondering if they are still within spec. Next time i will try to measure across each resistor at a time rather than going across both of them from fet to fet. One thing i noticed was that bias ran slightly lower at one end of the amp and slightly higher at the other end. I wondered if this could be tweaked by changing resistances but it seemed fairly insignificant. Yes, i had to glue a few of those relay magnets back on and the "rustling" sound was in one of the cv 1000's might even be one of the ones i'm fixing. Makes sense to have (backup resistors) on the offset, annoying when those pots go bad. I have so many amps to fix right now. Some of them are: 2x Cloud 2x Lab 6400 2x large QSC amps around 4k and 5k size 2x peavey 2600 2x harrisons (can't remember the model but fairy chunky ones for their age)
Recently sold a crest something 900, built like a bomb, had those cool bar led's.
Got another rare touring crest can't find any data on it but it's very powerful.
Lots of issues with DSP's have a broken 2x4 sabine which sends random tones out to random channels.
Still wondering why the BSS fds355 shuts down when brightness is adjusted and why all of the screens across my 3x units all have different tints / colours but at least they work if you leave them alone.
so many repairs lurking around here and also piled up at my dads in the UK. Hopefully will make some progress this year on some of those amps. Also lots of digital amps from powered speakers. Getting there slowly.
James
PS. I currently have a good price on used Toshiba 2SA1302 ans 2SC3281. Bigger transistors but same leg spacing, mounting holes are higher up, but other than tapping a new mounting hole on the heatsink I'm wondering if they could run in the cloud amps given a different gate / base resistor setup.
------------- Sound
Date Posted: 21 March 2023 at 2:05pm
from one of my previous posts:
Use those j-hook test leads rather than multimeter probes, just to avoid an explosive slip of the probes |
then
It almost seems they don't want anyone biasing these amps. I blew 2 fuses in my multimeter just slipping off of the small resistor and into the heatsink that also comes off of the same leg because it's not easy to get to the underside of the main balance resistors perhaps i should try to clip directly to the transistors leg. |
Lucky it didn't take out all those expensive fets!
I'm wondering if they could run in the cloud amps |
no
------------- Kevin
North Staffordshire
Posted By: izzzzzz6
Date Posted: 22 March 2023 at 10:13pm
I have 3 different types of clip on connectors but the ones that work the best i only have some hooked up to a component tester right now. Need to make some more leads up i have a bag of them somewhere. Those other fets share the same data sheet, how high could voltages get? Or am I missing something else. Rails are at +-~72V i believe.
------------- Sound
Date Posted: 22 March 2023 at 11:58pm
this is the question I'm answering:
I currently have a good price on used Toshiba 2SA1302 ans 2SC3281. Bigger transistors but same leg spacing, mounting holes are higher up, but other than tapping a new mounting hole on the heatsink I'm wondering if they could run in the cloud amps |
Those are bipolar transistors
------------- Kevin
North Staffordshire
Posted By: izzzzzz6
Date Posted: 09 April 2023 at 1:41am
Thanks.
------------- Sound
