Fane Colossus 18 SB 1000w in 1850
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=107710
Printed Date: 26 March 2026 at 9:48pm
Topic: Fane Colossus 18 SB 1000w in 1850
Posted By: BrainlessTekno
Subject: Fane Colossus 18 SB 1000w in 1850
Date Posted: 20 February 2023 at 12:17pm
Hi,
Im planning to build 2 or 4 of 1850 and not sure what to put in, i know ideal would be void 1000 but its little bit expensive for me... what about Fane colossus 18 SB, will it fit ?
If not are there some cheaper options ?
EDIT:
also there is option of fane colossus XB instead of SB
Posted By: teeth
Date Posted: 20 February 2023 at 12:57pm
what about... PD1850?
Date Posted: 20 February 2023 at 1:01pm
well pd1850 are even more expensive... goes about 500e, fane col 18sb goes around 280e.
But what do you mean ? Is fane colossus not good for 1850 ?
Posted By: levyte357-
Date Posted: 20 February 2023 at 1:03pm
I would suggest 186 Horn, over 1850 Horn, will effortlessly hit below 50hz with modern drivers.
Especially PD1851/2.
Date Posted: 20 February 2023 at 1:06pm
Well look, PD1851/2 is even more expensive but suggestion to consider 186 horn i will consider. So will fane collosus work in 186 horn ?
Date Posted: 20 February 2023 at 1:34pm
In the long run, you will spend more money, reconing cheaper drivers, sub optimal for use in Folded Horns, compared to used quality drivers.
Fane 18SB 1000 T/S Parms
FS 36 Hz
Re 5.2 Ω
QMS 6.583
QES 0.366
QTS 0.346
Vas 199 Litres
Vd 0.893 Litres
CMS 0.109 mm/N
BL 24 T/m
MMS 177.2 grams
Xmax 8.25 mm
Sd 1134 cm2
Efficiency 2.49%
Le 2.23 mH
EBP 98.36 Hz
As can be seen from above, this driver is a budget reflex driver, no where near as strong as V18-1000 or PD1850.
When 186 Horns where drafted, PD186/RCFL18P300 were considered OK, but now, choice of drivers optimal in Folded Horns, have increased.
Only the very strongest reflex drivers, are recommended for cabs like 186 Horns.
My PD1851s are new unused, but I also have some used, but freshly reconed PD1852s, which way outperform V18-1000s/PD1850s, in right cabs.
Date Posted: 20 February 2023 at 3:47pm
Your answer is just what i wanted and you made me reconsider to saving for optimal drivers... sorry but im new to this so can you tell me the definition of reflex drivers ?
Date Posted: 20 February 2023 at 4:01pm
https://en.wikipedia.org/wiki/Bass_reflex" rel="nofollow - https://en.wikipedia.org/wiki/Bass_reflex
