pd186/3 in 186 horn
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=107715
Printed Date: 26 March 2026 at 6:51pm
Topic: pd186/3 in 186 horn
Posted By: BrainlessTekno
Subject: pd186/3 in 186 horn
Date Posted: 21 February 2023 at 11:51am
what do you think about this? will it fit ?
also, is there a connection between 1850 horn and pd1850 or 186 horn and pd186, what does the numbers mean or is it just a coencidence? like i have a feeling that 18 meand that its 18incher but what about rest?
Posted By: DMorison
Date Posted: 21 February 2023 at 1:28pm
The names come from the Precision Devices drivers they were originally designed to use.
Posted By: levyte357-
Date Posted: 21 February 2023 at 2:09pm
This question could have been asnwered, by looking at the below 2x links, and reading previous posts on this forum.
https://www.speakerplans.com/index.php?id=1850horn" rel="nofollow - https://www.speakerplans.com/index.php?id=1850horn
https://www.speakerplans.com/index.php?id=186horn" rel="nofollow - https://www.speakerplans.com/index.php?id=186horn
The PD186 mentioned in the 186Horn plan, was for a MK1 PD186.
That is completely different from the current PD186/MK3.
As I warned you in "another thread", less than 48 hours ago, finding cheap drivers, and asking if they will work, is not a wise approach, for driver selection.
Try less posts, and more reading of relevant posts in the 186/1850 Horn forum, about comments regarding choosing drivers.
PD1850 Mk2 (Not PD1850/3), will be great driver in 186 Horn.
These can be had used, for approx £250 GBP. They will be better in this cab, than the cheap reflex drivers, you keep digging up.
Don't know anything about 1850/3, except it is very different to previous model.
Date Posted: 21 February 2023 at 3:03pm
Sorry for overposting.
okey i did not know there is such a difference between 186/2 and /3
Posted By: BigSoundNorthWest
Date Posted: 22 February 2023 at 12:22pm
