THAM15 kick section
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=108020
Printed Date: 26 March 2026 at 6:54pm
Topic: THAM15 kick section
Posted By: teeth
Subject: THAM15 kick section
Date Posted: 03 August 2023 at 4:59pm
can anyone recommend kicks to run alongside a pair of THAM15
 2 or maybe 4 if i can afford it.
was considering paraflex 12s of some kind perhaps. would only need a pair i think as decent output. but open to suggestions.
Posted By: cravings
Date Posted: 03 August 2023 at 5:47pm
what have you got for tops?
Posted By: monkeypuzzle
Date Posted: 03 August 2023 at 9:44pm
I run between 2 and 8 Thams on my system. If you're looking at needing kicks, the than isn't really a sub so you'd be better looking for a different bass section. As mentioned, what are your tops?
Posted By: FOO
Date Posted: 03 August 2023 at 11:01pm
Maybe Cubo Kick 12?
Very simple build, and if it's down the road of the big brother Cubo Kick 15, it will do a good job.
Posted By: hectorberman
Date Posted: 04 August 2023 at 2:49pm
Just build 2 more tham 15!
I find they play very well in the kick range
Date Posted: 04 August 2023 at 10:58pm
Agreed,whilst they don't have the real thump of a dedicated kick box they also don't have the sub that could sit under such a box. I built them because they're an efficient all rounder and I'm really pleased. Play with a bit of eq and dial in some kick. If it doesn't punch enough then build more 4 a side does really well) or go down a different route. They'll never be the 6 X1's and 4 FK1 218s I used to run but that's fine.,they take up far less space and need much less power.
Posted By: teeth
Date Posted: 20 September 2023 at 7:21pm
going for tham kick section as i can bring a pair of 218 to the battle easily enough.
i will run them up to 140.
does anyone have delays to hand? i wasn’t able to find a definitive answer readily.
