Superscoop dogleg removal
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=108114
Printed Date: 27 March 2026 at 4:54am
Topic: Superscoop dogleg removal
Posted By: novice
Subject: Superscoop dogleg removal
Date Posted: 24 September 2023 at 3:18pm
Was wondering what the pros/cons are of removing the dogleg?
Does it open up more driver options?
Posted By: paulus
Date Posted: 25 September 2023 at 8:39am
less cone control ,slight loss in spl ,imho opinion work's way way better , I have a pair with  it removed and 1851,1850 and tmax 1000 all sounded way way better , for fane and 186 etc i would leave in to help with the control of the cone
TRENDSETTER SOUND SYSTEM
Posted By: levyte357-
Date Posted: 25 September 2023 at 9:12am
This is why I say now, better just to build Mykey 18" scaled up Fane Scoop, or just build Eminence 18" Scoop.
If you have older drivers.
Posted By: novice
Date Posted: 25 September 2023 at 9:25am
Thanks for the reply all.
Scoops are already built so building new ones isn't an option for me at the moment.
Wanted to see if there are some more modern, off the shelf drivers that would work without dogleg? Mid priced and looking for musicality over SPL
Date Posted: 25 September 2023 at 10:03am
Removing Dog leg, means substantially increasing chamber, and hugely increasing throat.
As Paulus has already said, this means substantial loss of cone control, and reduction of SPL.
Tells you, just removal of dogleg is not enough, to keep cab useful for most drivers.
Posted By: novice
Date Posted: 25 September 2023 at 10:34am
So are there other mods mods that can be done if dogleg removal isn't enough?
Only asking these questions as from what I've read lots of people are saying the cab sounds better without the dogleg. But these comments were made years ago so those drivers aren't avaliable anymore new so seeking current options.
Date Posted: 25 September 2023 at 11:49am
Know a builder, who does Superscooper 18 mods.
Posted By: novice
Date Posted: 25 September 2023 at 12:11pm
Does that mean they're not public knowledge? Can you point me in the right direction please?
Posted By: paulus
Date Posted: 25 September 2023 at 1:22pm
what driver do you want to use ?
Posted By: novice
Date Posted: 25 September 2023 at 2:43pm
Not sure was hoping for advice from people who have done the mod. Something that is currently available to make life easier. Was using 186 before and was thinking of getting fane xbs but then started reading about these mods.
Posted By: paulus
Date Posted: 25 September 2023 at 3:06pm
if your using those drivers keep it in , i have used 1850s in mine ( i removed my ones  ) and when pushed to there limits they were moaning!!! I had to be very careful , defo for 1851/52 and turbomax etc
Posted By: valve head777
Date Posted: 25 September 2023 at 6:16pm
I have direct experience with these drivers in unmodified super scoops. Using a JTS enforcer preamp and JTS UA6 amp, 2 or 3 drivers on each channel.
Fane xb... Nice warm musical sound, goes fairly deep but not serious spl.
Pd 186, very similar to the xb, slightly more spl, nice deep notes.
Pd 1850, not a good driver for this cab, doesn't hit the deep notes not musical at all. 50hz and above reasonable spl.
Pd 1851, very nice. Moves alot of air, nice deep notes and fairly high spl.
Celestian ftr18 hdx. Feeling slightly fragile, around the xb-pd mark, not serious spl but sounds nice.
The caveat with the 1851 is how the cabs are stacked.  Normally we  had 3 standing upright on each stack. Easy to control via the pre, could drop some nice weight.  But we also stacked 4 together on their sides 2 high, scoops in the middle. Much harder to control the bass, felt 'floppy' and very difficult to get higher bass notes. Transient response seemed to suffer. It felt as if we needed tighter cones when used like this.
As I say, unmodified supers.
I also used the original fane 'wardrobe' scoops with 1850. That was a good combination, fairly brutal but not the most musical. The fane scaled up could be a good choice.
Posted By: novice
Date Posted: 25 September 2023 at 8:44pm
Thanks all. Think I'll just keep the dogleg in for now and try some Fanes
Date Posted: 25 September 2023 at 9:57pm
Thomman price looks the same for xb and pd186. Personally I'd choose the 186 over the fane. Similar sound but I think the 186 has more resilience power wise. 5" voice coil over the 4" fane.
That's just my take tho...
