Kick/midrange horn design
Forum Name: Feedback Forum
Forum Description: How Your Projects Perform
URL: https://forum.speakerplans.com/forum_posts.asp?TID=108139
Printed Date: 26 March 2026 at 6:54pm
Topic: Kick/midrange horn design
Posted By: Mitzi_ssd
Subject: Kick/midrange horn design
Date Posted: 10 October 2023 at 3:41pm
Hey all,
I'm designing a mid/kick horn for a diy venue that friends of mine run and I was wondering if anyone could give me some feedback. The design objectives are as follows:
  • 100-900hz approximate usable bandwith with good emphasis in the kick register (Skram subs below and Altec 511E above) Depending on how the Skrams sound I might be able to cross over higher, like 110hz
  • Single 15inch driver (I really like the sound of the Oberton 15L400 in another horn I built, so I'm designing around that. It has a very pleasant midrange voice and plays up to 1.5k in the 40cm exponential horn)
  • Near 130dB output at 1m. The room is around 150qm and I'd like to use 1 per side
  • Size is not really an issue, but two people should be able to lift it
  • Approximately 90 degree horizontal coverage to match the Altec radial horn
How does this design look? Is the change in flare rate too abrupt? Can I expect the horizontal dispersion to be roughly the same as the angle of the exit flare?
Are there other drivers I should consider? Hornresp shows the PD153c002, for example falling off rapidly after 500hz, but AJhorn shows good HF extention like the Oberton. The Oberton has only 3.5mm Xmax, but I suspect that's part of the reason it's such a good midrange.
Thanks so much!
The mouth is 109cm x 50 cm
Posted By: VECTORDJ
Date Posted: 11 October 2023 at 4:44am
A+
Posted By: Meat Substitute
Date Posted: 12 October 2023 at 10:58pm
That's not got the directivity in the sim yet. Once you add that you'll see that it goes a lot higher.
Date Posted: 13 October 2023 at 1:06pm
ha, thanks Meat Substitute, you're right.
I'm just starting to understand the directivity feature of hornresp. It doesn't work for multiple segment horns, so I simulated an exponential horn with similar dimensions ( damn this thing is huge Cry)
When simulated on axis, hornresp shows this massive peak around 400hz (reducing the compression ratio helps it mellow out a bit, but still there)
Ajhorn, which people say is very accurate for mid/high shows a much more reasonable on axis response...
Anyone have a hunch how this will behave in real life, with the two segments and wider horizontal dispersion? Is there any way to insure a flatter on axis response?
