Heat sinks
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=108142
Printed Date: 26 March 2026 at 10:04pm
Topic: Heat sinks
Posted By: Odjick
Subject: Heat sinks
Date Posted: 13 October 2023 at 5:07am
I am wondering if anyone has or thought of putting a heat sink (aluminum plate with fins etc.) in the rear baffle of a rhino or ms-18 mk3? Router out each side of where the cavity is to the open air and fit up some cpu fans. Waste of time and material? Not sure the motor would be close enough to transfer heat? Maybe not work in a stack? Every time i see those plans I can’t help but to think about it.
Thanks in general to all the scoop gurus on speakerplans, you know who you are. Love this forum
