Scoop and G-Sub combination
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=108228
Printed Date: 27 March 2026 at 4:55am
Topic: Scoop and G-Sub combination
Posted By: APSUS
Subject: Scoop and G-Sub combination
Date Posted: 15 December 2023 at 5:24am
Is it possible to use a G-Sub stacked on top of a pair of scoops wired in parallel with the scoops? If the G-Sub had matching 18” speakers with the scoops? Would it sound out of phase?
Posted By: levyte357-
Date Posted: 16 December 2023 at 12:29pm
If your Scoops aren't playing low/loud enough, without mixing other sub cabs, suggest:
  • Better drivers,
  • Better sub amps,
  • Better pre-amp.
Posted By: APSUS
Date Posted: 16 December 2023 at 4:58pm
I was watching an old video of Jah Tubby’s and it looked like he had 18” subs stacked on top of his scoops, maybe it was the Jah Tubby’s ‘muderous’ way of playing. I doubt he was using the 18’s above his scoops for mid-bass.
Posted By: FOO
Date Posted: 16 December 2023 at 8:31pm
Thats going to be some odd mix. Skip the scoops and get some more Gsubs and strap them to something like a LAB PLM 14000.
And use big boy drivers while your at it. Easy to setup. Easy to use. And no over excursion issues besides if you really push it to the max.
Date Posted: 16 December 2023 at 11:33pm
Actually I know him, been to many of his dances, and that's exactly what he did, 2x18 reflex on Mid bass.
Date Posted: 16 December 2023 at 11:37pm
For Reggae/Dub systems, reflex is the absolute best cab above Scoops, for 80-300hz.
In fact only thing better, is 15" reflex.
Reggae/Dub mid bass section, is more about low mid, as opposed to kick bass.
ES18,gives strongest kick 70-150, but 2x15 reflex, gives the 90-300hz, real thick sound on low mid vocals, on music/mic.
I have 4x 3x15" cabs, which are same width as 2x 18" Scoops, I also have a few PD158s, gagghing to go in them
That lot would be shouty, indoors or out.
Posted By: smitske96
Date Posted: 17 December 2023 at 3:16am
Gsub is far from optimised for modern high xmax drivers. You need far more port area to maximise performance.
Posted By: FOO
Date Posted: 17 December 2023 at 5:54am
Didn't say he should just go with original Gsub. Everybody should know the cab have to match the drivers.
