wots this scoop
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=108576
Printed Date: 26 March 2026 at 8:27pm
Topic: wots this scoop
Posted By: teeth
Subject: wots this scoop
Date Posted: 13 June 2024 at 10:56pm
we've got 3 scoops, love em, want to build a 4th.
trying to figure out what the it is though.
dims are 680 x 560 x 1220
other than that, it's a scoop... not a lot to go off.
any leads appreciated, have gone through all the classic designs, time to look a bit niche...
Posted By: valve head777
Date Posted: 14 June 2024 at 1:09pm
So from your description its just a box with a scoopy bit, right?
Posted By: teeth
Date Posted: 14 June 2024 at 1:39pm
like most scoops it is indeed
appears to be thinner than most
it’s very close in dims to the celestian one but that’s isobaric…
short of cutting it in half we’re not sure how to go about cloning it
Date Posted: 14 June 2024 at 2:28pm
If I was trying,  I'd remove the driver and take measurements from the back baffle, and measure the front chamber.  I'd look at the angle of the rear most horn section by getting entry via the scoop and measuring the top of that panel to the back of the cab (if the horn/scoop isn't braced). With some work, you might be able to extrapolate the panel sizes and angles.
Posted By: teeth
Date Posted: 07 January 2026 at 1:17pm
please, anyone, my wife will divorce me if i cannot identify this scoop this year
Posted By: madboffin
Date Posted: 08 January 2026 at 12:57pm
You need to put up some pictures, including some taken from inside the box (up the scoop, and behind the driver aperture), then somebody might recognise them. And more measurements, as suggested above
If you can't do that, post some pictures of the Mrs, looks like she will be needing a new companion...
