Martin Audio W2 12" Driver replacement
Forum Name: Electro Frying Forum
Forum Description: Talk about drivers, processors and mixers
URL: https://forum.speakerplans.com/forum_posts.asp?TID=108590
Printed Date: 26 March 2026 at 5:29pm
Topic: Martin Audio W2 12" Driver replacement
Posted By: Ayotteted
Subject: Martin Audio W2 12" Driver replacement
Date Posted: 23 June 2024 at 9:18am
Hi
I am after a replacement driver for my Martin W2, Anyone know where I can source one
I am in the UK
Thanks
Posted By: KDW32
Date Posted: 23 June 2024 at 9:54am
Originally posted by Ayotteted Ayotteted wrote:
Hi
I am in the UK
Thanks
What numbers does your driver have written on the back of it?  I think iirc the early W2 used ATC and newer ones had RCF.
Posted By: APC321
Date Posted: 23 June 2024 at 3:21pm
The driver code for the W2 (8 Ohm) is listed as DLS 231.
I dont know if this would relate to the ATC or RCF.
Couldn't find anything for sale in the usual places. Replacement driver from Martin would be big money unfortunately.
Posted By: madboffin
Date Posted: 23 June 2024 at 11:04pm
Can you post a picture?
You should be able to get it reconed, whichever driver it is.
Date Posted: 24 June 2024 at 10:18am
It's a DSL231
Date Posted: 24 June 2024 at 10:48am
What other high quality speaker could I replace it with.
Posted By: fat_brstd
Date Posted: 24 June 2024 at 11:50am
I believe it is a variant of the "ATC PA75-314". No idea which one as that drive came in about 100 different variations.
There are specs for a few different versions on the ATC website at https://atc.audio/wp-content/uploads/2014/01/ATC-Driver-Specs.pdf" rel="nofollow - https://atc.audio/wp-content/uploads/2014/01/ATC-Driver-Specs.pdf
To be honest its probably worth giving martin a call given they are based in the UK and might have some info to help you out. They might even have a driver kicking about although given the age of the W2 it certainly would no longer be a supported product.
Adrians Wall Sound System
Melbournes Rootical Warrior
Roots - Dub - Steppers
Date Posted: 24 June 2024 at 12:03pm
Thanks for the advice ... I have emailed Martin :-)
Date Posted: 24 June 2024 at 1:23pm
Thank you all for your help
Posted By: Ryan94
Date Posted: 24 June 2024 at 1:38pm
Also on the look out for one of these. The others members are correct in saying it's an ATC driver. Martin don't stock them anymore. Have also spoken to ATC and they weren't entirely sure which version the DLS231 was.
If you find a pair of W2 for sale at a sensible price and want to split the cost, let me know.
Posted By: fatfreddiescat
Date Posted: 24 June 2024 at 4:15pm
As 'madboffin' (a former Martin Audio employee) mentioned, you should be able to get them re-coned quite easily in the UK and will likely id the driver for you given a decent picture :)
Date Posted: 24 June 2024 at 5:49pm
All sorted
https://www.recones.com/
Thank for all your replies
Date Posted: 24 June 2024 at 5:50pm
Here you go
Highly recommended
Date Posted: 24 June 2024 at 6:03pm
I know someone who is selling a pair ... I can find out the cost if that helps
Let me know
