HD15 honking help
Category: Plans
Forum Name: HD 15 horn
Forum Description: Discussion / Questions about the HD 15 horn
URL: https://forum.speakerplans.com/forum_posts.asp?TID=108663
Printed Date: 26 March 2026 at 12:35pm
Topic: HD15 honking help
Posted By: dgm606
Subject: HD15 honking help
Date Posted: 03 August 2024 at 6:41pm
1
Posted By: Teadub
Date Posted: 03 August 2024 at 8:37pm
which drivers are in them and what at what frequencies have you tried to xo?
Posted By: dgm606
Date Posted: 04 August 2024 at 1:51am
1
Posted By: teeth
Date Posted: 20 August 2024 at 7:05pm
set your upper xo lower, sub 140
also put some more info in your posts please
Posted By: 1ManSoundsystem
Date Posted: 16 July 2025 at 1:43am
honk honk ! Tongue
Posted By: BrainlessTekno
Date Posted: 16 July 2025 at 8:16am
im glad this post was brought up, lot of interesting info here LOL
BarSick / barsik soundsystem
Dont want to toot my own horn but toot toot
Posted By: levyte357-
Date Posted: 02 August 2025 at 7:16pm
Above graph suggests, flattening eq of approx -3db@150hz, with q of approx 0.5 would be a good start.
If none of the above makes any sense, or you are using horn loaded cabs, without LMS, maybe time to reconsider, if Sound/Mobile PA is for you.
Posted By: paulus
Date Posted: 04 August 2025 at 11:25am
i used hd15 for 10 years loaded with pd154( mad bl for a 15 inch )  and time aligned to my scoops , i cut them 75 to 125 and they were bloody good indeed
TRENDSETTER SOUND SYSTEM
Date Posted: 04 August 2025 at 1:08pm
The HD15 unprocessed response, wil almost always have huge peak in the response, making it difficult to hear anything, each side of the frequency peak.
A lot of older brand name  PA cabs, had a normally peaky, response, but they shipped with  dedicated "controllers", that smoothed the response.
Looking at older Turbo, FK1 docs, they published recommend smoothing eq settings, for  engineers using their own LMS, with these cabs.
Posted By: KDW32
Date Posted: 04 August 2025 at 10:12pm
HeartThumbs Up
Posted By: 4D
Date Posted: 05 August 2025 at 4:21pm
using the elderly turbo  tse218/118  I often have a nibble approx -3db at 80hz & 160hz reduces both whoom and honk..
Date Posted: 05 August 2025 at 11:48pm
I have a video somewhere, where I flattened the response of a THL-818, after reading Turbo docs, then  using standard Fane 18B, was running the cab, 80-400hz...
Posted By: fat_brstd
Date Posted: 06 August 2025 at 1:12am
I run the same (PD154 in HD15) and cross from 77hz to 154hz into the 12" section from an mt121
The biggest issue with HD15 is trying to play them too high. I feel if you are getting less than 1 octave from a box then its probably not suited to doing what you are asking of it.
Adrians Wall Sound System
Melbournes Rootical Warrior
Roots - Dub - Steppers
Date Posted: 06 August 2025 at 2:19pm
I would say, the plot I quoted, clearly shows the natural response, needs serious smoothing, to get a desirable result.
If with purely cutting, not boosting, engineer can obtain average of 105db sensitivity, from single driver 15" cab, 80-200hz, that is a win win.
But then, many would argue, 102db average sensitivity, from a 2x15 reflex, 70-280hz, with little or no smoothing, for ruler flat response, might be better.
Posted By: Steve20131
Date Posted: 30 September 2025 at 9:32am
Like horns in all bandwidths there are standing waves, especially in horns with folds.  I'm not sure it's a purely f/response issue.  You could try some wall damping especially inside the cab (if it opens...)
