Mini Dub and Roots soundsystem build
Forum Name: Newbie Discussion
Forum Description: Newbie Discussion/Questions. Look less stupid here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=108758
Printed Date: 26 March 2026 at 6:55pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Mini Dub and Roots soundsystem build
Posted By: Osian123
Subject: Mini Dub and Roots soundsystem build
Date Posted: 20 October 2024 at 8:28pm
Hi,
I am in the process of looking into how to build my own reggae, roots and dub soundsystem. Finding it pretty difficult to figure out what type of sub boxes i need. I want it to be a 3 way system that can go down to ~45hz but doesn't really need to be mega loud. Will be mostly used in small spaces, playing to <40 people so was thinking something bass reflex with 2x12" drivers and then 2x mids and 2x tops. Any guidance would be much appreciated!
Posted By: HumbleDeer
Date Posted: 20 November 2024 at 12:02am
The combination of requested performance metrics at 45 Hz is nothing to sneeze at. There will be a small list of important items to bring up:
- What kind of power do you have available? - What are your space/heft constraints? - Are you building things by yourself? - If so, are you new to building things with wood?
Posted By: Xoc1
Date Posted: 20 November 2024 at 1:11pm
A compact tapped horn like a Tham 15 would be louder & meet your 45Hz requirement.
Posted By: Osian123
Date Posted: 20 November 2024 at 1:59pm
Hi, thanks for the reply!
I will most likely be plugging it into mains power. Needs to be able to fit into a living room (for storage), as long as it not massive it will be fine tho. I would love to build it myself and have some basic knowledge of woodworking.
Was wondering if the SB-15 would be a good option?
Cheers
Posted By: Osian123
Date Posted: 20 November 2024 at 2:02pm
Thanks for the reply Xoc1!
I was wondering if a tham design would be appropriate. I’ve heard that tham 15’s don’t do very well in small spaces? Have you had any experience with them?
Cheers
Posted By: Xoc1
Date Posted: 20 November 2024 at 8:12pm
Not with the Tham but yes with other tapped horns, I don't know how small a space you want to work in but 40 people suggests not that small. The difference in output from a TH system from a reflex is conciderable. Saying that by the time you have bought 2 or 4 12" bass drivers you could buy a decent 15" or 18" driver & in the right reflex cabinet be enjoying far deeper bass response if lower db levels & small spaces are your goal. What is a SB-15? Conciderations may be any equipment you have, Budget for any equipment you dont have, and if you want to build or buy. For bass mids & tops you are talking a lot of amplifier channels. If fully active stereo that is 8 channels, and 8 drivers to match=  amounts of cash. Maybe if I was starting fom nothing, I would aquire a pair of half decent active mid tops that could crossover at about 100Hz, and then concentrate my efforts on a sub that would exceed your requirements - You can't have too much headroom - But not enough soon becomes a problem!
Posted By: levyte357-
Date Posted: 21 November 2024 at 11:42am
Whole point of Roots and Dub soundsytstem, is system is to be felt, and heard.
This means ideally flattish response downto 35hz. When you disengage the sub kill switch, you are supposed to hear controlled, rolling thunder, regardless of volume level.
Save yourself time, and wasted money, by just finding pair of unloaded 2x18 gsubs, and load with Fane 18xbs. Or, build/buy 2x Staiper MS18 MK2, load with with Fane Xb, Colossus 1000.
Find unloaded pair of 2x12" + 1" cabs, load with Fane 12mb and DE250s or DE25s
JBL MPX1200 on sub, Qsc rmx2450 on 12s, Qsc rmx 850 on 1", Mostek 3x way mini pre. Nothing sounds as good, as system with headroom, turned down.
Cheap, done, smiles, every time you play.
------------- Global Depopulation - Alive and Killing.
Posted By: Osian123
Date Posted: 21 November 2024 at 5:06pm
Hi,
That sounds like exactly what I’m after, the system being felt an and sound good even at lower levels. Just a few questions about the components I’m curious about. I’ve head that mini scoop designs don’t sound great in smaller venues(small bars or even larger living rooms), would I be better if with the g-subs in this case? Do you have any suggestions/plans for 2x12” + 1” cab designs? I would like to try and keep the initial cost under 2k(and then mabye upgrade in a few years when I low what works etc), is this possible or should I expect to have to shell out a bit more than that to start off?
Cheers!
Posted By: stitchie
Date Posted: 21 November 2024 at 9:59pm
Osian123, I've got a mini set up could be what you're looking for, I have 2 x18 g subs, 1x 215 cab 2x 12+1 can come loaded or unloaded, possibly got a couple of amps to power them with, send me a message if you're interested. Cheers
Date Posted: 22 November 2024 at 12:06am
Cheers! |
To keep costs down to minimum, buy used ply cabs, cables, drivers, amps.
For starter system, just go 3x way:
- 18 inch sub,
- 12" mids,
- 1" highs (Compression drivers)
Many people selling up on FB Rig resale.
Contact Luke Smith, Kutty Qualitex, they will help locate full system, for your money.
Date Posted: 22 November 2024 at 2:18pm
The Pre-amp and sub amp are at the heart of a decent Roots/Dub soundsystem, regardless if LMS or PA Mixer are also used.
As mentioned previously, the Mostek 3x way mini pre would be absolutely ideal for you, and a decent sub amp like QSC RMX 5050, JBL MPX 1100, Peavey GPS 3400, Peavey CS4080, EV P3000, Void Infinite 7 MK2, are cheap but heavy, great sounding subs amps, for the beginner.
Posted By: Osian123
Date Posted: 22 November 2024 at 10:18pm
Stitchie, your mini system is exactly what i'm looking for! I would love to know how much you'd want for it, and all the configurations you'd be willing to sell it (just the tops or just the subs for example). Unfortunately, it's unlikely i will be able to take it off your hands as i am not the richest atm, was planning on gaining as much knowledge as i could on here and make a complete plan of everything i would need to make the rig, and then potter away at building the boxes and hunting for good deals on drivers, amps etc. If i end up not buying any of your gear, i would much appreciate any info/tips on your system and any plans for the boxes (especially the mid tops).
Cheers!
Posted By: bob4
Date Posted: 23 November 2024 at 7:09am
Tbh, I don't think there is any sense in trying to build midtops for a beginner. Much cheaper, convenient, and probably better sounding to buy some second hand factory cab. It's also the domain in which you are more likely to make big mistakes and be frustrated.
Subwoofers are more forgiving.
It's going to be a big learning curve anyway, putting a system together, tuning it etc.....
I think building a midtop from scratch makes more sense after you have gained experience, listened to a lot of different things, and had time to make up your mind on what you like. Without a clear vision and relying on second hand opinions will just have you running around in circles.
For excellent results you will need a lot of time AND money (and experience, or a well proven plan/design).
At the same time you can get very good deals on very good professional grade PA loudspeakers if you are tenacious and know what you are looking for.
2k overall budget is not much, but not bad either.
Posted By: stitchie
Date Posted: 23 November 2024 at 10:35am
Osian123 i'd sell the 2x g subs for £200 unloaded (but have 4x PD186 600w mk1 drivers to go in them £600) and 2x 12+ 1 mid tops for £70 loaded also got a behringer europower 1500 700w @ 4 ohms amp for £100. let me know if any good for you. Cheers
Posted By: Osian123
Date Posted: 23 November 2024 at 1:27pm
Stitchie, that is great for me! I would be very keen to buy the loaded boxes and amp for £770. Only problem i can think of now is how to get them from you to me, how many hours drive are you from north wales? I could potentially come and get them if not hours and hours away.
Cheers
Posted By: stitchie
Date Posted: 23 November 2024 at 2:22pm
Osian123, I think you've misunderstood i should have been clearer in my pricing loaded g subs would be £800 (200 unloaded + £600 for 4x drivers) amp £100, loaded mid tops £70 total £970. I'm in Nottinghamshire, where are you located? Cheers
Posted By: stitchie
Date Posted: 23 November 2024 at 2:25pm
Just to add 2 of the PD186 drivers are fresh re-cones and the g sub have full grills
Posted By: stitchie
Date Posted: 23 November 2024 at 3:00pm
I've sent you a private message, let me know if you've got it? Cheers
Posted By: Osian123
Date Posted: 23 November 2024 at 4:06pm
I feel like i'm being a bit stupid atm, but i can't find anywhere for private messaging on here, how do i see private messages?£970 makes more sense, i did think 770 was too good to be true  I am only around a 3 hours drive form Sheffield, so i could potentially come and get them.
Cheers!
Posted By: bob4
Date Posted: 23 November 2024 at 4:09pm
Cheers! |
You need to pass a certain count of posts before you can send abd receive pms
Posted By: stitchie
Date Posted: 23 November 2024 at 5:03pm
just been informed you need to have at least 10 posts to send and receive private messages
Posted By: Osian123
Date Posted: 23 November 2024 at 5:22pm
Ah ok, i have 8 I think, do we just have to keep posting on here till we get 10?
Posted By: Osian123
Date Posted: 23 November 2024 at 5:23pm
Posted By: stitchie
Date Posted: 23 November 2024 at 5:24pm
Posted By: stitchie
Date Posted: 23 November 2024 at 5:25pm
see if you've got the message i sent you
Posted By: markturnip
Date Posted: 28 December 2024 at 4:26am
Does anyone have any pictures they could share? or perhaps there's a dedicated forum for mini dub soundsystems?
Posted By: Osian123
Date Posted: 27 March 2025 at 4:13pm
Hi, Cheers for all the comments and help, got me a lot more clued up on what I needed! Atm, I have 2 12”+1” mid tops powered by a europower 1500 amp. I’m looking to upgrade this setup, was thinking of adding 2 1x15” bass reflex subs for now. Was wondering if this would be a good idea? And any suggestions on amps and crossovers to use would be much appreciated. The final plan (in the future) is for these to sit on top of 2 18” scoops, would this setup sound good and be well balanced? Will be playing roots, dub and steppas.
Cheers
