Dollies
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=108866
Printed Date: 26 March 2026 at 6:54pm
Topic: Dollies
Posted By: Teunos
Subject: Dollies
Date Posted: 06 January 2025 at 5:51am
I'm currently building dollies for the double 12" hornloaded mids i've been using for years.
The idea was to place them on the dollies face down, stacked in pairs.
Built from 18mm birch, of which i had a full plate left, 15mm would have been sufficient though.
Due to the cutouts for the rubber feet on the bottom, skids on the back, cutouts for the wheels and various lips to align the dollies to the cabs i've decided to CNC the sides and plate the wheels sit in when the dollies are stacked.
Glue up of the only joint on the dolly required rebating for ease of assembly on the side panels.
Boards that hold the wheels attached
2 Dollies stacked
The cab on the dolly
And the dolly on top of the cab, on top of which the next one will sit.
ToDo: Sand, fill holes and paint.
Best regards,
Teun.
Posted By: dj jammin
Date Posted: 06 January 2025 at 9:03pm
Nicely done... they look spot on..
Reverence Sound system
Posted By: fatfreddiescat
Date Posted: 06 January 2025 at 9:43pm
Very nice Thumbs Up
Posted By: Teunos
Date Posted: 03 February 2025 at 7:43am
Rounded over all the edges on the router table and painted them last weekend.
I've decided that only the bottom dollies really need wheels since they will always be used in pairs. This saves 8 wheels, weight and makes handling easier + avoids potential damages to the bottom cab if the upper dolly is placed too wild due to the wheels banging the sides. Instead, 2 dollies have 2 small plates mounted in opposing corners to lock them onto the lower dollies when stacked.
Stacked pairs with a strap to keep them in place.
Best regards,
Teun.
Posted By: colinmono
Date Posted: 28 August 2025 at 4:32pm
Brilliant. I love wheels. I bet a lot of design work went into these.
Is it a bit tricky to lift the top cab onto the dolly that is resting on the bottom cab?
