Center Chanel To Match My Dentons 85th
Forum Name: Newbie Discussion
Forum Description: Newbie Discussion/Questions. Look less stupid here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=109136
Printed Date: 26 March 2026 at 10:56pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Center Chanel To Match My Dentons 85th
Posted By: Tumescent
Subject: Center Chanel To Match My Dentons 85th
Date Posted: 20 June 2025 at 8:15am
Hi everyone,
My family and I lost our home and everything in it in the January Eaton Canyon fire. I had just purchased a pair of Denton 85th anniversary bookshelf speakers and the center channel I had was an older M&K brand center channel that I purchased from a friend many years ago. Everything burnt so I’m starting from scratch and I just purchased another pair of the same Dentons 85th, but now I don’t have a center channel.
These Dentons have a specific sound to them, so should I just get a third Denton 95th and use it as the center channel or is that not a good idea? I’m not a speaker expert so would like your expert opinion. I believe Wharfedale does make a center channel but I have no idea how good that is. Also, should I buy a different brand center and if yes which one that would pair and sound really well for the LR Dentons? I will really appreciate your help.
Thank you.
Posted By: Lucasdude
Date Posted: 20 June 2025 at 4:33pm
Ideally, all 3 front speakers (LCR) should be identical or atleast use the same drivers. I don't believe Wharfedale make a centre channel to match the Dentons, so if it's possible for you to buy a 3rd 85th anniversary one then that's what I would suggest. Keep the speaker in the same orientation as the stereo pair, and as close to the same height as possible.
