Budget 2way 15inch pa top idea
Forum Name: Advanced Discussion
Forum Description: Advanced discussion area for higher lifeforms
URL: https://forum.speakerplans.com/forum_posts.asp?TID=109170
Printed Date: 27 March 2026 at 4:06am
Topic: Budget 2way 15inch pa top idea
Posted By: Mr.miva
Subject: Budget 2way 15inch pa top idea
Date Posted: 20 July 2025 at 9:44pm
Hi, I want to make some budget diy pa system and I have a problem and that is I live in apartment and i dont have very good power tools for wood cutingCry. And I was thinking if I can buy a empty or cheap 2 way wooden cabinet and put better components. I found the box PA 15 ECO MKII on thromann and to just put some better high driver + horn and better mid range driver now idk if box is good it is made of plywood. And here is link to the box  https://www.thomannmusic.com/the__pa15eco_mkii.htm - https://www.thomannmusic.com/the_box_pa15eco_mkii.htm
Posted By: monkeypuzzle
Date Posted: 20 July 2025 at 9:51pm
Total up how much money the boxes will cost plus getting better components for them (and throwing away perfect working drivers?) and I can say for certain that you’d get a better second hand option anywhere. The drivers would already be matched to the box, the crossovers if running passive would be correct and it would be well built. I understand the desire to have some “diy” ownership over it but this is definitely not the way to do it.
Posted By: Mr.miva
Date Posted: 20 July 2025 at 10:06pm
Well the problem is the used market is not that good like only stuff that is there are diy boxes and reselling the total cost would be like i can get bins on b-stock for around 100-90$ i will keep mid range driver for some time the horn+high range driver 100-150$ crossover will diy something 20$.
Posted By: julius111
Date Posted: 21 July 2025 at 12:21pm
you could build something like this in your kitchen
https://celestion.com/blog/build-this-15-two-way-pa-cabinet-design/" rel="nofollow - https://celestion.com/blog/build-this-15-two-way-pa-cabinet-design/
you might pay a small premium on wood if you have it cut to plan
but that leaves you with only making a bunch of holes with a jigsaw
best, julius
