XTA DP226 Cleaning battery acid off tracks?
Forum Name: Electro Frying Forum
Forum Description: Talk about drivers, processors and mixers
URL: https://forum.speakerplans.com/forum_posts.asp?TID=109243
Printed Date: 26 March 2026 at 7:10pm
Topic: XTA DP226 Cleaning battery acid off tracks?
Posted By: monkeypuzzle
Subject: XTA DP226 Cleaning battery acid off tracks?
Date Posted: 28 September 2025 at 9:40pm
I'm just pulling the battery out of an XTA that I've recently aquired as its certianly started to leak. The unit powers up with a battery warning but seems fine. I haven't yet had a chance to pass audio though. I've noticed there is a bit of the acid that has fallen on to the tracks. What is the right thing to clean it off with?
Cheers.
Date Posted: 28 September 2025 at 9:53pm
Okay, the battery is out and I've cleaned it up so far with some dry cotton buds. that tracks and the laquer seem okay but I've noticed that the legs of IC4 right next to where the battery is have started turning a bit green.
As mentioned, other than having tested it passing aduio it does still work so hopefully theres a remedy to stop it going bad... Whats the cleaning process? IPA and a toothbrush?
Cheers, Matt.
Posted By: BJtheDJ
Date Posted: 29 September 2025 at 12:54am
Cheers, Matt.
Just a thought, but after that thorough clean, a
coating of clear nail polish would do the trick.
I still have most of it left.
Posted By: Jan-2T
Date Posted: 29 September 2025 at 8:35am
You could use alcohol to clean circuits, isopropyl alcohol or any pure alcohol on cotton sticks.
Or rince it water, just put it under a running hot water tap and blow off by air compressor.
Seems counter-intuitive but is really the best!
Some print restoring companies use a regular (clothes) washing machine to rince prints Big smile
If any traces of the acid are left behind, they will continue to react.
For the oxydised IC legs, maybe desolder it and clean the legs with a glassfiber pen.
Give the legs a nice thin coat of new solder and the nail polish could be applied indeed, nice trick with common goods.
Music!
Posted By: 4D
Date Posted: 29 September 2025 at 3:23pm
white vinegar & lemon juice to neutralise the potassium hydroxide that leaks out of batteries that stay flat for too long..
Posted By: LW42
Date Posted: 06 October 2025 at 7:18pm
Have similar issue anyone know if its possible to mos the unit to a coincell holder?
Posted By: HumbleDeer
Date Posted: 07 October 2025 at 12:02am
Yes, KOH (or similar) indeed! Because it's not battery acid if it's strongly alkaline. I recall there's a type of battery doin' the rounds lately that they even explicitly call alkaline batteries!
If you've spotted any damage, take a clear, in-focus, well-lit picture and post it here. There's probably others besides me that are also into electronics repair, so there's plenty of opportunity.
Date Posted: 07 October 2025 at 12:03am
with minimal effort and modification yeah
