Crest CC 4000
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=109253
Printed Date: 27 March 2026 at 7:15am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Crest CC 4000
Posted By: Earplug
Subject: Crest CC 4000
Date Posted: 06 October 2025 at 12:42pm
I've been offered a Crest CC 4000 at a decent price, but I am a bit hesitant about buying any of the newer Peavey-Crests.
Anyone have any experience with the CC range? Any good? Do they last??
Ta.
------------- Earplugs Are For Wimps!
Posted By: kedwardsleisure
Date Posted: 06 October 2025 at 3:01pm
I was just about to have some coffee & a abanana but the thought of the last CC4000 I had in for repair has made me lose my appetite. Apart from that, ok
------------- Kevin
North Staffordshire
Posted By: levyte357-
Date Posted: 06 October 2025 at 3:15pm
Ta. |
Will be useful for barbecues..
For playing sub, I would prefer Admark.
------------- Global Depopulation - Alive and Killing.
Posted By: Earplug
Date Posted: 06 October 2025 at 3:31pm
Haha, ok. So better to steer clear?
Date Posted: 06 October 2025 at 4:34pm
Earplug wrote:
Haha, ok. So better to steer clear? |
Admark AD42, is not quite as powerful as a Powersoft K20, but much nicer tone..
There's not much out there to match it for the price, used or new.
How does the CC4000, compare with that?
Posted By: Earplug
Date Posted: 06 October 2025 at 5:02pm
I don't actually need that much pure/stupid power!
I'll be driving a couple of P-Audio P-18N's - or JBL 2241's, which will happily run with around 800W-1kW of amp/channel. I usually drive these with a Crest 9200, or a CA18 copy I have, neither of which I've ever seen go anywhere near clipping. Far from it.
I've had a few smaller gigs recently, that I've been getting a friend to cover, using a 7001 to drive a couple of subs, but those are just a bit small to do the cabs justice. So I'm looking for something a bit bigger, thus the CC-4000.
Date Posted: 06 October 2025 at 5:11pm
There's pretty much no point, in lugging around heavy transformer amps, anymore..
When buying sub amps, buy the biggest/best you can afford.
If you can't afford Powersoft X4L, get Powersoft K20.
If you can't afford Powersoft K20, get Admark.
Posted By: Earplug
Date Posted: 06 October 2025 at 6:09pm
Haha, yes.
What the hell do I want with an X4L, or K20?? They`re totally OTT for what I need. Like I said, the Pro 9200 has served me well for years, no problem - & only around 10kg, Class H, lovely sounding amp.
I've also seen a 9200 for sale, a bit more expensive than the 4000, but also a lot better, so will most probably just go for that.
Cheers for the attention anyway!
Date Posted: 06 October 2025 at 8:29pm
on a serious note if you're happy with a pro9200 then I dont suppose a CC4000 will be that different, isn't it just a 9200 with a transformer power supply?
------------- Kevin
North Staffordshire
Posted By: Earplug
Date Posted: 07 October 2025 at 7:44am
Ok, I'm not sure.
The 9200 has a fair amount more power - 1300W into 8 ohm compared to 800W for the 4000. That may be down to a better PSU, but without looking inside, who knows. Given my experience over the years with the 9200, I might just go for another & be done with it. The 9200 does have a lot more positive (online) feedback than the 4000. I can't find much about the 4000, which is why I asked here!
Posted By: Elliot Thompson
Date Posted: 07 October 2025 at 1:09pm
All the amplifiers you are eyeing is a product of Peavey. Since the CA Series bankrupt Crest due to the high amount of failure rates and, the Professional Series had their own issues that were escalating as well, Peavey redesigned both Series. The CC Series can be looked upon as the improved CA Series and, the Professional Series 9200 replaced the Professional Series 9001. The Professional Series 9200 was replaced by the Pro-LITE 7.5 which, is a Peavey IPR2 7500 with a slightly higher electrolytic value.
Best Regards,
------------- Elliot Thompson
Posted By: Earplug
Date Posted: 07 October 2025 at 4:40pm
Ok, thanks for the clarification.
The Pro 9200 is obviously made to a budget, with a single board construction, which I've seen in some other modern Peavey amps and really don't like but like I say, so far has served me well.
The CC 4000 also makes me wonder, as it comes in at (only) 20kg, which seems light for the power it claims to produce. The CA12, for example, is 10kg heavier.
I remember the AB International Precedent Series, that were also lighter than one would expect and came with some blah about the transformer being smaller - but using larger value capacitors to make up for that. Needless to say, that didn't work!!
Date Posted: 07 October 2025 at 11:22pm
Yes. AB International went through numerous transitions throughout the decades. Their best version was the ones that stated "AB Systems." They were introduced in the late 1970's to the mid 1980's. The AB International name change (among-st other things) were introduced in the late 1980's to mid 1990's. The last I've heard about AB, it was owned by some High End Audio company with a High End Price to match. And of course, it is no longer called AB International. That was around 20 years ago.
The ones that stated AB International (Later Models) would offer a lot of idle heat whereas, the AB Systems would leave you wondering if it was actually on as it offered no idle heat. That is comparing the exact model numbers. The designs were different as the AB Systems used an E - Core Transformer whereas, the AB International used a Toroidal Transformer. In addition to the differential in Transformers, the AB Systems used RCA Semiconductors whereas, AB International used Toshiba Semiconductors.
The Peavey GPS Series was the only amplifier made by Crest when, Peavey bought them. Peavey bought Crest solely to get in the Touring Market. However, so many people (In the States) had issues with the Crest CA Series, no one was willing to take the risk despite, Peavey had an excellent reputation of low failure amplifiers. And, the Professional Series proprietary parts were showing their age.
The original designers from Crest started out from BGW.
Best Regards,
