help with a capacitor value
Forum Name: General Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=109304
Printed Date: 27 March 2026 at 4:05am
Topic: help with a capacitor value
Posted By: zigzagwanderer
Subject: help with a capacitor value
Date Posted: 02 November 2025 at 8:14pm
https://ibb.co/0jgdXCK0" rel="nofollow - https://ibb.co/0jgdXCK0
I need to replace this capacitor in a Furman power conditioner  , its dead so i cant measure the value
but am struggling to understand the markings.
is it F = 27 so 27nf
or F .27 so maybe 270nf
or something else ?
can anyone with more experience with these things offer any insight
Posted By: James Tengo
Date Posted: 03 November 2025 at 12:57am
Is this on the light driver or the voltage display board? Most of the Furmans I’ve been inside only really have MOV’s across the supply, a very expensive box of not much
Posted By: Earplug
Date Posted: 03 November 2025 at 6:55am
Post a picture?
Date Posted: 03 November 2025 at 9:08am
Neither , those are on seperate pcb's , this has a main board with a relay , the capacitor and relay are right at the front of the circuit on this board and i'm not getting any power past the relay.
Date Posted: 03 November 2025 at 9:09am
Post a picture?
apologies i can't figure out how to make it show directly !
Posted By: Earplug
Date Posted: 03 November 2025 at 10:58am
That's 27nF, 400V.
Maybe used for "direct" AC-DC connection to power the relay? Often seen on LED bulbs, etc...
Capacitor --> bridge rectifier --> low power DC circuit.
Date Posted: 03 November 2025 at 7:20pm
That's 27nF, 400V.
Thank you
 Yes "Capacitor --> bridge rectifier --> low power DC circuit" is basically what i am seeing.
Posted By: Earplug
Date Posted: 04 November 2025 at 7:28am
Ok, cool.
One thing -- there should also be a (high value) resistor in parallel with the capacitor. Make sure that that is also ok.
Date Posted: 04 November 2025 at 7:13pm
Ok, cool.
thank you , i've given it a thorough check over and a new cap from RS and were up and running again Tongue
