Studio Monitor amp transformer mystery
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=109364
Printed Date: 27 March 2026 at 5:30am
Topic: Studio Monitor amp transformer mystery
Posted By: Tedski
Subject: Studio Monitor amp transformer mystery
Date Posted: 20 December 2025 at 10:36pm
Hi all,
I'm looking for some help regarding replacing the transformer of the power supply of my aging but beloved Event Electronics PS8 monitor plate amps.
One is buzzing, it's driving me up the wall. Delaminating transformer.
Nothing is written on them, Event itself doesn't exist anymore and I can't find anything spec-wise.
What some research has taught me is that if I know the voltage it is outputting, it's input voltage (230) and how many amps it should be able to deliver (0.5A@230 says the badge on the amp) I should be able to determine the transformer I need to replace them with, is that correct?
So I should open it up, power it up and measure output voltage, leg to earth and leg to leg?
If for example its 2x 30v to ground and 60v leg to leg, I am looking for a 30V, 150 VA torroidal transformer?
Thanks for any help.
Posted By: Earplug
Date Posted: 21 December 2025 at 9:07am
Yup.
Open, measure AC on secondary & replace with something similar - that fits.   Smile
A fairly simple job. The real problem is if you're faced with a blown transformer & no way of knowing the exact voltages needed. The actual physical size of the transformer will be more a clue to the VA than the consumption figure on the badge, but more or less, yes.
Posted By: Tedski
Date Posted: 21 December 2025 at 11:49am
Thanks.
Luckily the transformer still works, and I have a second to compare.
Yes the VA rating is a bit mystifying to me. Also I would like to go from this steel core vibrating junk to https://www.tme.eu/en/details/55154-p1s2/toroidal-transformers/talema/" rel="nofollow - something like this .
0.5A @ 230 is 115Watt. If it turns out to be 30V that works out to roughly 4 amps, so then I spec it slightly beefier it works out to 150VA.
But I'm unclear if this calculation stays the same if the transformer has 2x 30volt secondary. I'll open up the amp this afternoon.
Posted By: Earplug
Date Posted: 22 December 2025 at 8:08am
The VA is calculated using the total voltage, so 150VA, 2 x 30v would give 2,5A. That should be enough for the monitor, but like I say, take a look at the original to judge the size needed. If something bigger than a 150VA will fit, use a bigger transformer. That can't do any harm & will run cooler. And yes, a toroidal is better. More efficient & less likely to make noises.
Posted By: service dept Steve
Date Posted: 23 December 2025 at 3:35pm
A couple of things, Double check that it is only two windings and that there isn't a smaller pair that would supply the 15v for the input stage. Secondly you mentioned you are looking for a toroidial transformer, it is very rare that toroids buzz without outside intervention, loose clamps or covers. Check those before you go too far.
Don't worry too much about the current because if you get the correct voltage and correct physical size you can't go wrong, you can however go wrong if you select just current and voltage because it could be way too tall or look like a dinner plate and still be correct. You should be able to measure the ac voltage at the transformer or as it joins the board but you can also measure the dc voltage and divide the number by 1.414 to get the lower ac voltage.
We are not "They", We are "The others" http://www.servicedept.co.uk" rel="nofollow - http://www.servicedept.co.uk -
Posted By: Tedski
Date Posted: 23 December 2025 at 7:14pm
Thanks guys. I have some free time now so I'll open them up and poke around with my meter.
I wish to replace the current transformer, a delaminating iron core thing with a torroidal.
If I'm totally confused I might post some pics.
Thanks again.
Posted By: Tedski
Date Posted: 26 December 2025 at 2:07pm
It measures at 2x 27.4V at idle, so that would make it a 25V transformer I guess?
There is quite a bit of room so I think I will order two of https://www.tme.eu/nl/en/details/55153-p1s2/toroidal-transformers/talema/" rel="nofollow - these .
A pic of the transformer:
Posted By: Earplug
Date Posted: 26 December 2025 at 4:14pm
Ok, cool.
So just one set of secondaries? It must generate any lower voltages needed via dropper resistors, or something similar. Simple. Good luck!!    Smile
Date Posted: 27 December 2025 at 7:53am
Ok, cool.
The schematic shows that the 15v are generated by a pair of zener diodes and dropper resistors from the supply to the lm3886s so only the two windings required in this instance.
Posted By: Earplug
Date Posted: 27 December 2025 at 9:01am
Ok, that is common, especially if the amp is only using relatively low voltage rails. When you have to drop high rail voltages, the resistors invariably end up black & eventually failing!   LOL
Posted By: Tedski
Date Posted: 27 December 2025 at 12:47pm
I ordered the transformers and I found the schematic.
In the manual it says the amp has turn on/off transient protection, but mine do like to emit a slight BANG when powering on or off.
Do you electronics wizards have an idea if I could fix that myself? It's not a huge problem because I rarely turn the off, but whilst I'm in there...
uploads/1919/PS8_Schematic.pdf" rel="nofollow - uploads/1919/PS8_Schematic.pdf
Posted By: Earplug
Date Posted: 28 December 2025 at 8:11am
That may refer to the MUTE function of the LM3886. That usually involves a resistor, switch & bypass capacitor around Pin 8. Your amp has the resistor & capacitor, but no switch, so who knows what the designer was trying to achieve.
Posted By: Tedski
Date Posted: 30 December 2025 at 9:53pm
Received the transformers and I have a newbie question.
I ground together 2 ends of the secondaries I presume but does it matter which side of the secondary?
Orange and black to ground, yellow and red are the two 25v legs?
Before you guys think "dude bring them to a pro", a sentiment which I share, trying to find someone that is willing to fix my aging stuff A: In a timely manner B: Doesn't bullshit me and C: I trust to do a good job is very hard, even though I work in the industry.
Plus now I get to learn something and scare my girlfriend.
Thanks again.
Posted By: Pinyorouk
Date Posted: 30 December 2025 at 11:52pm
Try yellow and black to ground.. No harm if it is wrong unless if you short a pair together.
Posted By: Earplug
Date Posted: 31 December 2025 at 7:08am
Yes, try one pair and measure the voltages. If you don't get summation, swap one of the ends!
Posted By: Xoc1
Date Posted: 31 December 2025 at 12:54pm
If the 27.4V was the DC rail voltage. The calculation would be.
Firstly add the Diode voltage drop for the rectifier
27.4 V DC + 0.7V = 28.1V. This would be the Peak AC Voltage
then divide that by 1.41 (square root of 2) to get the RMS AC voltage
28.1V /1.41 = 19.91V AC
If the transformer you have bought is a 25V AC
Are you sure that is correct or should it have 20V secondaries?
(25V AC *1.41)-0.7 = 34.55V DC rails
This is significanly more than 27.4V if that was the DC voltage you measured.
Posted By: kedwardsleisure
Date Posted: 31 December 2025 at 1:08pm
yellow and black together become your centre tap
North Staffordshire
Posted By: Tedski
Date Posted: 31 December 2025 at 2:12pm
It was AC straight off the transformer secondary. You're making me doubt myself now so I'll measure again but I'm 99% sure I was measuring AC.
Ok yellow and black it is, thanks all.
Posted By: Tedski
Date Posted: 09 January 2026 at 5:05pm
Sorted, thanks everyone!
They sound great still, and no more buzz.
Now I can enjoy my tinnitus in silence.
Posted By: Tedski
Date Posted: 09 January 2026 at 5:27pm
Damn, now I hear a very very faint buzz coming from one of the 8 inch drivers that I didn't hear before because of the transformer (no input).
Could that be something simple?
The old transformer secondaries were twisted around each other before the pcb, is that an interference thing?
Posted By: Earplug
Date Posted: 10 January 2026 at 7:50am
The large filter caps are "leaky"? Or try put a couple of 100nF caps across the rails. See if that helps.
Date Posted: 10 January 2026 at 2:51pm
where is that earth wire going near the transformer?
North Staffordshire
Posted By: Tedski
Date Posted: 10 January 2026 at 4:07pm
I knew someone was going to comment on that.
It's just jammed under that large washer. It used to run to the base of the old transformer because the old one was mounted in rubber, and therefore it needed it's own ground. The new one has a bolt going through the grounded aluminium plate so it is now unnecessary, so I just jammed it under there.
Both the earth wires, that one and the one connected to the plate go to the earth pole on the power connector.
If the capacitors are dying it could cause a faint hum?
Thanks.
Date Posted: 10 January 2026 at 4:13pm
take the earth wire out, if it touches the washer it will damage the transformer.
North Staffordshire
Posted By: Tedski
Date Posted: 10 January 2026 at 4:24pm
Ok. Between the washer and the transformer and on the base of the transformer are pretty thick rubbery insulating discs, so it's not metal to metal.
Posted By: fatfreddiescat
Date Posted: 10 January 2026 at 5:17pm
That earth wire could be creating a shorted turn, a loop around the transformer core if there is metal to metal connection with the top plate, bolt and amp chassis.
Posted By: Tedski
Date Posted: 10 January 2026 at 5:21pm
I'll open them up asap and remove, thanks all.
Posted By: Tedski
Date Posted: 27 January 2026 at 4:11pm
I removed the pointless wire, and replaced the big capacitors (same spec, nice brand).
I'm afraid the slight hum is still present.
What I noticed while checking the voltage on the capacitors prior to soldering them off the board is that one of them read a negative voltage. Only slightly, 0.6V. But the 'good' amp didn't have that.
Could that be a clue as to why that one is humming?
Is the bridge rectifier dying?
I have no experience with this, that's why I'm asking. It has become a bit of a mission to get these b@stards 100% silent. Thanks for any help.
Date Posted: 27 January 2026 at 4:34pm
it's possible its partially open, eg one of the 4 diodes is open. But the increased ripple on one of the transformer tappings might lead to an audible buzz from the actual windings.
North Staffordshire
Posted By: Tedski
Date Posted: 27 January 2026 at 4:55pm
It is 100% coming from the 8 inch driver, not the newly replaced transformer.
No input present or even connected. The potmeter has no effect on hum level.
I just measured between the earth on the power connector and a radiator on the central heating, 0.6V AC.
Just recap everything?
Also I was searching for a new bridge rectifier, and I could find similar components, but they were labeled PC and not CP 604. Does that matter?
Thanks.
Date Posted: 27 January 2026 at 8:05pm
no its fine, any 6A rectifier would do, 604 means 5a 400v but I doubt it needs to be that high voltage...200V would do.
If you have a multimeter you can test it on diode check, it's just 4 diodes in one package.
North Staffordshire
Posted By: Earplug
Date Posted: 28 January 2026 at 6:54am
Getting rid of random hum like that can be a PITA. Try put a couple of 100nF caps across the large filter caps. See if that helps. Or it may be one of the LM3668's. Odd, but you never know. Is it definitely the woofer & not the tweeter - or both? That would be a clue.
Date Posted: 28 January 2026 at 8:38am
I meant to type 'six amp' BTW, late night typo.
North Staffordshire
Posted By: Tedski
Date Posted: 28 January 2026 at 4:11pm
While researching this subject I stumbled upon a few forum threads of people building their own amps and I learned a few things:
Contrary to al lot of information(wikipedia), the jury is still out on whether torroidal transformers emit more or less interference that a iron core one. That got me thinking, maybe I assumed the hum was present before I changed the transformers. Maybe the transformer is actually causing the humming.
So I cracked open the cabs again.
Another thing I read that seemed to be backed up by measurements, is that even the orientation of the torroidal transformer can make a difference in interference, so I started with rotating the transformer and powering up the amp. No difference.
So then I grabbed the shielding that was around the old transformers and modified them to fit the new ones. Seems to be galvanized sheet steel. I wrapped it in tape to insulate. And presto, the speakers are quite a bit quieter. Not completely silent, but the hum is pretty much inaudible at listening distance.
Maybe I'll bend up a chunky piece of metal as a cage around the pcb to get it even quieter. Steel or aluminium do you think? Connected to ground or no?
What a faf, but I learned a lot, thanks again for all the advise!
Date Posted: 28 January 2026 at 4:40pm
toroidals emit much less stray magnetic fields than EI lam transformers, it's inherent in their design.
The stuff wrapped around the old transformer is a piece of mu-metal sheet (google it).
Did you check the rectifier? If you changed both transformers, why does one hum and not the other?
Asymmetric ripple from a dodgy rectifier will cause increased electromagnetic radiation from the windings, so it's worth checking just in case.
Some rectifier faults in old colour TVs were betrayed by a swirling pattern on the CRT caused by the transformer affecting the colour purity as its magnetic emission increased.
North Staffordshire
Posted By: Tedski
Date Posted: 28 January 2026 at 4:50pm
Ahaaa, good info, thanks.
I'll order new rectifiers and report back.
Date Posted: 28 January 2026 at 5:06pm
just test the old one rather than keep buying bits, more chance of unintended damage
North Staffordshire
