1800w driver
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=109378
Printed Date: 26 March 2026 at 9:25pm
Topic: 1800w driver
Posted By: WaveLength
Subject: 1800w driver
Date Posted: 05 January 2026 at 12:07pm
Hi guys
Happy 2026
I'm thinking to upgrade my sub section and move to a more powerfull driver
I see that there are few 1800w around
Can i have a good advice on what would be the best to buy and that will work in suoerscoops?
Posted By: levyte357-
Date Posted: 06 January 2026 at 9:46am
Originally posted by WaveLength WaveLength wrote:
Hi guys
Happy 2026
Which drivers are you using in them now?
Not many drivers are optimum in the 18" Superscooper, would think Void V18-1000, is one of the best,  the unmodified Scooper.
Modify the throat section, then things change..
Date Posted: 07 January 2026 at 9:36am
I have void v1000 in supers now
But i Just want to get a more powerfull driver
I can even consider tò switch superscoop with another design
Posted By: Earplug
Date Posted: 07 January 2026 at 1:23pm
How many more (or LESS!) dB's will that give you? dB's are far more important than power rating, never mind a dozen other parameters to take into account. And what about amps? Will you have to buy a new (bigger/more expensive) amp/s? The Void driver is optimum for those cabs. "Upgrade" at your own risk.
Posted By: jammin75
Date Posted: 07 January 2026 at 1:38pm
add more supers or change box Big smile
Date Posted: 07 January 2026 at 1:40pm
To upgrade to drivers superior to the V18-1000 in Scoops, you will need another plan.
My Lev .44 Scoop, works with some of these drivers, but I'll never sell those.
I do have another plan, I developed, and one prototype for it.
Get in touch if interested.
Date Posted: 07 January 2026 at 2:15pm
I know that the output loudness Will not be diubled
I Just Need a Little more Power 🤪
Also i already have a cvr 4ch (2000w8r) tò drive 4x 1800w driver
I can't add more boxes cause i have not enough space in my home.
What design i should go for ?
Fane scaled up- Hugo full scoop- cow scoop?
Date Posted: 07 January 2026 at 2:26pm
Before considering changing drivers or cabs.
I would suggest replacing that CVR amp, with Void Infinite 8 MK2, or Admark AD60 amplifier.
As I can guarantee that CVR is not powering those Void drivers properly, especially down to 40hz.
Date Posted: 07 January 2026 at 2:46pm
My 4 v1000 have Always been drived by a 5000vz
I would use the cvr Just on a 1800w
Anyway i tested the cvr with Smaart  and the freq response was pretty flat down tò 30hz
Date Posted: 07 January 2026 at 2:58pm
My 4 v1000 are Always been drived by a 5000vz
Even a Macrtotech MA5000VZ, on 32A, would not fully power, 4x 8 ohm Voids.
A Void Infinite 8 MK2, on 32A, would power 2x of those Voids per channel, better than a Crest 9001, and can assure you, your CVR will not match that, despite what the specs say.
Only amps, that will power 4x subs better than a Void Infinite 8 MK2, are Admark AD60, Powersoft K20, or Powersoft X4L,  or pair of bridged QSC RMX 5050.
Date Posted: 07 January 2026 at 3:11pm
A 5000vz can do It .. with the ioc led constantly blinking 😂
Really thx tò share Ur knowledge Lev
I Always wanted tò buy an infinie8 MK2 but i Never found One for sale when i had money
Date Posted: 07 January 2026 at 3:13pm
A 5000vz can do that... With the ioc led constantly blinking 😂
Really thx to share Ur knowledge Lev
I Always wanted to buy and infinite 8 MK2 but i Never found One for sale when i had money
Date Posted: 07 January 2026 at 3:19pm
By the way i have 2 crown 5000vz
One void1000 powered by One ch of the 5000vz
Posted By: Earplug
Date Posted: 07 January 2026 at 6:09pm
"I Just Need a Little more Power 🤪"
Are you trying to heat your house!!   LOL LOL LOL
Date Posted: 07 January 2026 at 6:19pm
Yes it's really cold here man
