Achat 112 SUB - Which amp / advices
Forum Name: Newbie Discussion
Forum Description: Newbie Discussion/Questions. Look less stupid here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=109426
Printed Date: 26 March 2026 at 6:54pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Achat 112 SUB - Which amp / advices
Posted By: bivan84
Subject: Achat 112 SUB - Which amp / advices
Date Posted: 07 February 2026 at 12:22pm
Hello. I put together a little system with 2 of them, coupled with Montarbo 210 sat (B&C 250AMX woofers and B&C 1" Horn), all amplified by a t-amp E4-250 with a DCX2496 crossover. The two Montarbo's are very sensitive and the two 112 work hard with that setup to follow them. Can I have an advice to make the sub more "present"? Does that amplifier is sufficient to power them? Thanks!
Posted By: Earplug
Date Posted: 07 February 2026 at 12:48pm
You are obviously under-powering the subs!
Minimum for those would most probably be something like the E-1200 or E-1400 (sticking with Thomann amps). Or the TA/TSA series. I'm really not sure what difference there is, but Thomann do give a no quibble 3 year guarantee, so worth a gamble.
------------- Earplugs Are For Wimps!
Posted By: bivan84
Date Posted: 07 February 2026 at 1:37pm
Thanks. I do not know if the speaker would survive to that amount of power :-)
Posted By: Earplug
Date Posted: 07 February 2026 at 3:05pm
Why do you say that? The speaker is rated at 350W. Do you think that is an exaggeration? In any case having 1,5 - 2 x rated power is standard. You can always limit the power going to the speakers with the DCX. It's always better to have a bit of headroom & avoid sending a clipped signal to the speaker. I think that sending square waves down the line is the most common cause for failure!
Posted By: bivan84
Date Posted: 07 February 2026 at 3:19pm
I was thinking that 990 W on 4 ohm of the t.amp E-1200 was too much for it...
Posted By: Earplug
Date Posted: 07 February 2026 at 5:29pm
And likewise the 4ohm thing. The impedance of the cab will vary with frequency & most likely only be 4 ohms over a narrow band. You won't really know unless you do the measurements or Thomann can provide the graph. Not too likely, really.
In any case, they do say that the thing will stand up to 1400W peak, whatever that means.
I'd say, always use the biggest amp you can afford, set your limiters - and use your ears!
Good luck!
Posted By: njw
Date Posted: 07 February 2026 at 11:12pm
The easiest and cheapest solution would be to knock the mid/tops down a few db's on the DCX or even run some overlap between the bass bins and tops, this obviously won't improve the overall SPL. Personally, I'd add another pair of the Achat 112's, run the four of them from the e4-250 and then power the Montarbo's from another amp that does around 300w/side into 8r as from what I can see the Montarbo's are considerably more sensitive than the Achat 112 subs.
Posted By: bivan84
Date Posted: 08 February 2026 at 11:26am
Good luck!
Understood, very clear. I will try to power them with a powerful amp. I have available an old Samson SX1800 which is rated to 2x600 on 4 Ohm just to see their behaviour.
Posted By: bivan84
Date Posted: 08 February 2026 at 12:23pm
njw wrote:
Personally, I'd add another pair of the Achat 112's, run the four of them from the e4-250 and then power the Montarbo's from another amp that does around 300w/side into 8r as from what I can see the Montarbo's are considerably more sensitive than the Achat 112 subs. |
Yes, that would be a reasonable solution. I do not know if that E4-250 will run happy with 4 ohm on all four channels.
Posted By: Earplug
Date Posted: 08 February 2026 at 1:20pm
Ok.
Another pair of cabs is a good idea. Better to spread the load & not push your cabs to death. You could always use the Samson with 4 cabs, but with each pair wired in series instead of parallel.
In any case, yes give the bigger amp a try & see what you think. It may give you a few dB's more.
Posted By: James Tengo
Date Posted: 08 February 2026 at 5:25pm
I have a very similar setup, a pair of sherman R2m's and a pair of the 112's and drive them with a E4-250, I have also driven them with an E-1500. Have you removed the passive crossover? That improved output in my experience. I would add another pair before looking at a more powerful amp
Posted By: bivan84
Date Posted: 08 February 2026 at 6:20pm
James Tengo wrote:
I have a very similar setup, a pair of sherman R2m's and a pair of the 112's and drive them with a E4-250, I have also driven them with an E-1500. Have you removed the passive crossover? That improved output in my experience. I would add another pair before looking at a more powerful amp |
Thanks for sharing! Yes, I have removed the internal crossover and redo the cabling for accepting a 4 pole speakon to link the Montarbo's on the TOP output, using one cable from the channel 1 and 3 of the E4-250. Yes, they sound better without the internal 6 db/oct filter.
You find the E4-250 appropriate for that use or is limited? Any suggestion for filter or equalisation? I simply use a HighPass 24 db/oct at 35 hz and the top are crossed at 150 Hz.
EP1500 could drive the 112s without hurting them?
Date Posted: 08 February 2026 at 7:00pm
The passive crossover went quite a bit higher than 150hz, I overlap the sub and tops on my setup, running the subs out at a shade over 200hz, but my tops are only a 6.5” and 1” horn, so I benefit from a slightly higher crossover point. If running the slightly bigger Shermann R8m’s I drop the crossover to 170hz. Adding the other cores to the speakons was the first mod, the second adding an active / passive switch to take the crossover out of action on the subs was the second. Incredible output for the size and weight. A friend also has a pair, which he runs with a set of void mycro 8’s. They were happy on the E-1500, but no significant benefit to driving them with the bigger amp. If you want more output add more cabinets.
Posted By: Earplug
Date Posted: 09 February 2026 at 11:19am
Yeah, passive xovers just waste energy & more sq inches of cone always beats more watts. I usually drive my 18" with Crest 8001's - or a 9200, but have had to use a smaller amp a couple of times, like a Yamaha P7000 & the difference was marginal, altho' the 9200 definitely has more headroom.
Posted By: bivan84
Date Posted: 15 February 2026 at 4:15pm
Yes the 112 sub + Montarbo AS is a small setup. I will try next time with a little bit powerful amplifier on the subwoofers! Thanks for all the advices.
For the DCX2426 settings like limter and maybe highpass? HP 37 Hz 24 db/oct is ok?
Posted By: bivan84
Date Posted: 15 February 2026 at 4:17pm
James Tengo wrote:
The passive crossover went quite a bit higher than 150hz, I overlap the sub and tops on my setup, running the subs out at a shade over 200hz, but my tops are only a 6.5” and 1” horn, so I benefit from a slightly higher crossover point. If running the slightly bigger Shermann R8m’s I drop the crossover to 170hz. Adding the other cores to the speakons was the first mod, the second adding an active / passive switch to take the crossover out of action on the subs was the second. Incredible output for the size and weight. A friend also has a pair, which he runs with a set of void mycro 8’s. They were happy on the E-1500, but no significant benefit to driving them with the bigger amp. If you want more output add more cabinets. |
Thank for your reply. I think that the t.amp E4-250 is lacking some power to the subs...
Posted By: Earplug
Date Posted: 15 February 2026 at 4:20pm
Well, Thomann say 40Hz for the cab, so you should set the HP there.
Date Posted: 23 February 2026 at 7:00pm
Just pulled the rig out and fired it up, I run the 112’s 40hz LR24 up to 200hz LR24 , with my Sherman R2m’s overlapping 125hz LR24 up to out, but at -4db to the subs. Cracking little system, the size and weight of the subs make even upstairs rooms in venues really easy.
Posted By: bivan84
Date Posted: 23 February 2026 at 7:19pm
Thanks for the feedback. Which amplifier are you using?
Date Posted: 23 February 2026 at 10:10pm
The t amp E4-250, same as you. Crossover is a BSS 336T minidrive.
