Super Scoop // PD.1845-2N vs 18sound 18NLW9601
Forum Name: General Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=109486
Printed Date: 27 March 2026 at 8:46am
Topic: Super Scoop // PD.1845-2N vs 18sound 18NLW9601
Posted By: gardenite
Subject: Super Scoop // PD.1845-2N vs 18sound 18NLW9601
Date Posted: 24 March 2026 at 9:20am
Any members here have experience using these two drivers in the classic Mogale Super Scoop?
Currently running 1850s in them and looking at options to improve on sound I’m getting (especially at lower volumes)
PD.1845-2N
Vs
18sound 18NLW9601
Any opinions welcome.
Thanks
*apologies if this should be in the ‘scoop’ forum … can’t seem to find that page
Posted By: paulus
Date Posted: 24 March 2026 at 10:06am
don't  bother with the pd its no good low bl and cone thin, shame as wanted it to be a hit but after testing it was a let down,(  , super scoop chamber is 202mm plus 18 on the front which is 220mm , the 9601 is 216mm from flange back , unless you have a 36mm front baffle neither are a good idea im afraid ,  , i tested supers with 1850s with and  with removed dogleg , ok spl down a bit , but it will come alive with the 50 in at lower volumes :) it really shifts air with it removed i can assure you , also turbomax 1000i was the best driver i tested  in it again leg removed
TRENDSETTER SOUND SYSTEM
Posted By: levyte357-
Date Posted: 24 March 2026 at 10:40am
We have a Scoop forum, for questions like this.
Suggest you ask admin, to move this post there.
By all feedback posted here, the 1845-2N, is not in the same league as 18nlw9601, even in the right Scoop.
The best driver in the standard Super scooper 18, is the Void V18-1000.
The 1850 excels in other Scoops.
18nlw9601 is my fav Scoop driver of all time, because I have drawn up Scoops, that it excels in.
PM for more details.
