Recommendadtion for RCF L15P801 and L15P200A?
Forum Name: Advanced Discussion
Forum Description: Advanced discussion area for higher lifeforms
URL: https://forum.speakerplans.com/forum_posts.asp?TID=11162
Printed Date: 18 April 2024 at 10:53am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Recommendadtion for RCF L15P801 and L15P200A?
Posted By: jwka
Subject: Recommendadtion for RCF L15P801 and L15P200A?
Date Posted: 03 August 2007 at 12:52pm
Hi,
I do have the wo speakers and I want to bulid a (mono) sub for use @home on the terrace which means that a bit of bass fundament should be there.
Any suggestions on which enclosure to take?
Thanks a lot.
Posted By: lovaz
Date Posted: 13 August 2007 at 11:50am
EBP = Fs / Qes speaker with little EBP are more suitable for closed box high EBP for vented box, very high EBP for horn load; i think that this driver is also in the ISD program ( http://www.linearteam.dk/default.aspx?pageid=winisd - http://www.linearteam.dk/default.aspx?pageid=winisd ) database (EBP=180 for the L15P801)
------------- LOVAZ AUDIO
Posted By: jwka
Date Posted: 13 August 2007 at 5:44pm
Thanks for the hint, will try out the software.
However, I would be interested in results of others. Anyone here already used one of that speakers?
Posted By: Mike Severloh
Date Posted: 14 April 2008 at 10:05pm
Hi, I traded my L15P801s to a friend who successfully built up a pair of reflex boxes out of it, tuning around 45 Hz, sounded lovely.
Anyway, this chassis is a great midrange speaker that I used in a horn drumfill, from 100 to 900 Hz. With a closed back chamber and a 38cm long 50°-horn with a mouth of 56x56cm it is my most brutal drum monitor ever. I still use it, now with an RCF MB15N351. (Even death metal drummers cry for mercy after this !)
EAW and GAE use it in 15/2-monitors.
------------- Mike Severloh.
