Crossover
Forum Name: Electro Frying Forum
Forum Description: Talk about drivers, processors and mixers
URL: https://forum.speakerplans.com/forum_posts.asp?TID=11376
Printed Date: 27 March 2026 at 6:31am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Crossover
Posted By: GAZ.
Subject: Crossover
Date Posted: 17 August 2007 at 12:03am
At the moment I am using a behringer active crossover for my system. Is this an ok unit or should I look for somthing better,any suggestions?.
------------- 100% Earth Moving Bass
Posted By: TONY.A.S.S.
Date Posted: 17 August 2007 at 7:50am
We have a Behringer here at the factory. It's the last of the cheap ones we bought. We went through a stage of buying one of everything to see how good they were . My only advice is to get the most expensive one you can afford. Not all expensive stuff is is the best, but when it comes to x/o's, You do need a good one because it's at the front end of your system. There is always a possibility that a cheap one will be more noisy than a more expensive one. Secondhand Omnidrives are worth a look. Although we bought the BSS gear new, we did buy a secondhand Saori. What I'm saying is a secondhand good one will probably be better than a cheap new one
------------- http://www.facebook.com/tony.rossell.3" rel="nofollow - http://www.facebook.com/tony.rossell.3
