Cabs on test were.
Boke MA912 with P Audio SN 12B & B&C DE 250. The 12" horn had no rear chamber cover fitted but the driver did have a sealed rear chamber because of the cabinet. I called this cab Boke MA912 Adam.
Boke MA912 wth P audio C12 300 MB and P Audio WM 44 (I think). The 12" horn had the correct rear chamber cover. I called this cab Boke MA912 Florian.
MT 121 with P audio SN 12 MB and P Audio BMD 750. This is basically one horn from the MT 122 design and a BMD 750 on P audio horn above it. I don't know which P Audio horn was used. I called this MT 121.
MX12 with P Audio SN 12 B and P audio BMD 750. This is a horn designed by Mykey and is available from the Jan Audio website. The measurements were taken without any rear chamber cover, but should not make much diffrence to the data above 300Hz. In fact the lack of a rear chamber means no reflected sound can re-emerge though the cone and add colouration, so it acted like a dipole. The response below 300Hz would have been effected by having no rear chamber cover fitted. The data for the HF section would be the same if the rear chamber cover was fitted or not.
Porn Horn V2 with P Audio SN 12 B and P Audio SN 740. The HF horn was designed for the Beyma CP 755 Nd. The SN 740 seemed to keep up with the 12" horn in level but not in terms of sound quality were the Beyma is a lot better. The CP 755 Nd's measurements would have been a lot better too, especially the distortion tests.
Measuring equipment used was a Bruel & Kjaer 4939 mic, which has a response from 4Hz to 100KHz and a M Audio Preamp. Sampling rate was 24 BIT 48KHz as no design had any output above 22KHz. The measurment program used was Ease. This sends out a test signal and then records the result. The recording is then used to deduct over 50 measurment types. The test signal use was swept pink noise from low to high. The range was 7Hz to 24KHz, but I stated the plots from 20Hz as there is nothing present that low, apart from wind noise.
The measurments were taken in a slightly diffrent way. I did this as I wanted to see what would happen if an average DIYer got hold of some cabs and drivers and throw it all together. Instead of measuring the LF and HF sections seperately, I measured the combined output of the whole cab. Again this was done to see what the whole cabinet including crossover settings from a LMS would be like. 2.83v, or 1 watt was applied to the 12" driver and the HF horns output was then set to be level wth the 12" horn. There was no HP filter set on the 12" driver for measurments, it was applied when doing the listening tests. For most of the cabs the 1" drivers were crossed over at 2.2KHz with a 24dB Butterworth slope on the HP filter. 1.5 and 2" drivers used a 1.7KHz HP filter with 24dB Butterworth slope. The LP filter on the 12" drivers was mostly 2.2 KHz 24dB when used with a 1" HF and 1.7KHz 24dB when used with either a 1.5 or 2" HF. But what we did was to set up each cab to give the best response we could. It meant that most of the time the above settings were used, but for some cabs the 12" drivers LP filters slope and type was adjusted to give the flattest response. Delays between HF and LF sections were also adjusted to give the flatest response. There would have been no point in using the same settings for each cab as the different components used dictated different settings. All we wanted to know was how good you could make 2 components put togther in a cabinet sound and perform.
First off is the frequency responses. The lower limit on the plot is 20Hz the upper is 30KHz. The accuracy of the sensitivity is within +/- 0.1dB. All easurments were taken at 1 meter.
This is for Adams MA912. You can see that the 12" horn only goes to 800Hz. The phase plug in this design does nothing. You can also see a lot of SPL below 100Hz, this is due to the high winds were experinenced earlier in the day.
This is Florians MA912. Again the 12" horn goes nowhere near high enough to match with the 1" driver.
This is an overlay on the 2 MA912 cabs. You can see that the B&C DE250 goes a lot higher than the P Audio 1" driver. Also note that the P Audio SN 12B plays lower and higher than the C12 300MB.
This is the plot for the MT 121. There is lots below 400Hz and it plays higher than the Boke MA912's, so fills the gap a bit better. The HF is a 2" unit and you can see the limited response above 12KHz.
This overlay of the MA912 and MT 121 shows the better output below 400 Hz and the better midrange response.
This is the plot for the MX12. Don't pay any attention below 300Hz. But its worth noting that this horn doesn't like the BMD 750 driver, as the response is very weak around 6 to 10KHz.
Overlay of MX12 and MT 121
Plot of the Porn Horn V2. This is the only design in the group that uses a phase plug on the 12" horn and you can see the diffrence it makes.
Adams MA912 against the Porn Horn V2.
MT 121 against Porn Horn V2. Note that the MT 121 has the same output below 400Hz.
MX12 against Porn Horn V2.
An overlay of 4 cabinets. I didn't put Florians plot on here as the response was not as good as Adams MA912.
I will post all the THD and harmonic distortion plots, group delay and water fall plots later in another post.
