New System
Category: Plans
Forum Name: Po rn Horns
Forum Description: Discussion / Questions about the Po rn Horns
URL: https://forum.speakerplans.com/forum_posts.asp?TID=11691
Printed Date: 27 March 2026 at 5:14am
Topic: New System
Posted By: dickscode
Subject: New System
Date Posted: 10 September 2007 at 7:19pm
Thinking of building a system using 2 or 3 Punishers and 1 Porn Horm mk2 per stack. Generally it will be live music with some '80's dance!
Anybody have an opinion whether I would be stretching the crossover points of them both or if they would be ok, don't really want to add another low mid cabinet.
Thanks
Posted By: rinse
Date Posted: 11 September 2007 at 12:52am
I don't think the Porn Horn goes nearly low enough.  You could try running the Punishers that high but most claim it doesn't sound that good.
A shame really but some HD15s would do the trick and let the Punishers concentrate on the lower frequencies...
Posted By: mykey
Date Posted: 11 September 2007 at 11:01am
It all depends on what you load the punishers with.
I've heard that the ciare doesn't like it up high
I believe  the porn horn goes down to 140?
Discode, is it near-field sound your looking for? porn horns and punishers are really outside Joby's, well the Porn horn I would say is, looking at the depth and dispersion.
The old gals at the back wont be able to chat.
......just all them hanging there like giant bananas.
Date Posted: 11 September 2007 at 11:36am
I've given ours a go at about 130Hz and they seemed okay, the response is certainly loud enough.
Posted By: Sibulus
Date Posted: 12 September 2007 at 2:02pm
Cab resonance though? We go up to 100Hz, max. Keep it doing what it does best.
Posted By: odc04r
Date Posted: 12 September 2007 at 11:18pm
Got 2 stacks of 3 up to 140Hz in a big marquee, sounded fine. Think we even tried 160Hz and it wasn't bad but 140 did sound cleaner.
Inside a hall I just found that 140hz rattled the sh*t out of everything, 112Hz worked well for me there.
Posted By: Sibulus
Date Posted: 20 September 2007 at 7:56pm
What do you run ontop of them? We use X-tros.
