new peavey sub
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=11783
Printed Date: 27 March 2026 at 2:15am
Topic: new peavey sub
Posted By: mhtplsh
Subject: new peavey sub
Date Posted: 17 September 2007 at 9:03pm
Here is the info about launching of new sub from Peavey.
It looks as bandpass horn loaded sub to me. This is just to pass the info to
our members.
I am not connected to Peavey.
Summer NAMM: SP™ FH Folded-Horn Sub Boasts Booming Power
July 28, 2007
AUSTIN, Texas — Booming with a 3200-watt peak power output, the new SP FH folded-horn subwoofer from Peavey is engineered for the most demanding low-frequency sound-reinforcement applications.
The new SP FH utilizes an 18” Low Rider® Black Widow® loudspeaker with a 4” voice coil and Kevlar®-impregnated cone in a folded-horn design that produces an earth-rumbling low end. Ideal for use in nightclubs and large concert productions, this subwoofer registers a focused frequency response from 30 Hz to 300 Hz and 1600 watts of program power (3200 watts peak).
For three decades, the Peavey SP Series has provided astounding accuracy and clarity in sound reproduction and legendary reliability under heavy-use conditions, and the SP FH continues those traditions through innovative engineering.
The Peavey SP-FH will be available Q4 2007 from authorized Peavey retailers.
Features · 18” Low Rider® Black Widow® woofer · Field-replaceable loudspeaker technology · Compact folded-horn design · Frequency response: 30 Hz to 300 Hz · Sensitivity (1w/1m): 108 dB · Peak power handling: 3200 watts · Program power handling: 1600 watts · Direct input jack with 1/4” jacks and four-pin Neutrik® Speakon™ · Built-in casters for easy transport · Nominal Impedance: 8 Ohms · High-quality carpet for durability · Dimensions (HxWxD): 36” x 24” x 34” · Weight: 150 lbs.
Posted By: Preacher
Date Posted: 17 September 2007 at 10:24pm
http:///www.peavey.com/news/article.cfm/action/view/id/266/20072807.cfm - http:///www.peavey.com/news/article.cfm/action/view/id/266/20072807.cfm
Folded HornWink
It's all about the music & the vibe, so enjoy it while you can.
Posted By: _djk_
Date Posted: 18 September 2007 at 2:50am
CV copy.
djk
Posted By: odc04r
Date Posted: 18 September 2007 at 10:34am
Up to 300Hz, pfff.
Posted By: _djk_
Date Posted: 19 September 2007 at 2:49am
Ditto for the 30hz part (maybe eight in a corner).
djk
Posted By: everdark
Date Posted: 21 September 2007 at 10:14pm
I'm familiar with Peavey drivers, they are tight but you need a load of them to get the presure of pair of Eighteensound's. I've got rid of SP series rather fast
Posted By: _djk_
Date Posted: 22 September 2007 at 2:42am
The box in question uses the LowRider 18, a very different animal.
djk
Posted By: tb_mike
Date Posted: 10 October 2007 at 8:52pm
Consumerism -repackaged product ad nauseum.
Posted By: vectif
Date Posted: 21 October 2007 at 1:16pm
Talking of looking like Cerwin Vega.... Have you seen what wharfedale are offering these days?
http://www.wharfedalepro.com/Default.aspx?dsplType=2&pid=23&ParID=17&IdLang=1 - http://www.wharfedalepro.com/Default.aspx?dsplType=2&pid=23&ParID=17&IdLang=1
Surprisingly very similar specifications.
Posted By: _djk_
Date Posted: 21 October 2007 at 10:53pm
When you get a degree in marketing you are allowed to change the laws of physics by a factor of 10 (either 1:10 or 10:1 as suits your needs).
MODEL MX-F18B
GENERAL INFO
System type 2x 18” Folded Horn subwoofer
Frequency response +/- 3db 30-300Hz
Sensitivity (db 1w@1m) 106dB
System impedance 4 ohms / 8 ohms Switchable
System FB 30Hz
Maximum SPL Peak dB 141dB
I have no idea where the second 18 is, nor how it could be either 4 or 8 ohms, nor how less than eight boxes in the corner could be only 3dB down at 30hz, and it would have to be fed with in excess of 3KW (with no woofer compression) to hit 141dB.
djk
