---MINI-SCOOP-IDEA---
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=12410
Printed Date: 27 March 2026 at 8:37am
Topic: ---MINI-SCOOP-IDEA---
Posted By: tweeter box
Subject: ---MINI-SCOOP-IDEA---
Date Posted: 27 October 2007 at 12:04pm
From previous thread;
http://speakerplans.com/forum/forum_posts.asp?TID=12399 - http://speakerplans.com/forum/forum_posts.asp?TID=12399
Im trying to design my own *hybrid b-line mini scoopWink* box to load with a V18-1200, just needed some advice and opinions on;
a) what depth/length piece of wood A should be?
b) what angle/length piece of wood B should be?
If its any good will be building a pair of them, can i also mention that im not using any programing software so please keep your comments not to technical
Thanks in advance Tongue
PRECISION SOUND SYSTEM.
Posted By: mykey
Date Posted: 27 October 2007 at 1:02pm
What do you want from it? high bass? low bass?
or a bit of both?
Looking at the drawing the length of he horn is to much for the mouth size
you could get away with a 1.5 mtr horn length i reckon, what length is that 1.8/9?
......just all them hanging there like giant bananas.
Date Posted: 27 October 2007 at 1:18pm
Im after some REALLY low bass!
Would this design do it? Am i on the right track?
The height of the mouth would be 14", do u think this will be to tight??
Posted By: mykey
Date Posted: 27 October 2007 at 1:19pm
Do you have to have that specific size?
Date Posted: 27 October 2007 at 2:09pm
doesnt have to be that size just thought it would be convenient carrying/storage n what not!
How much difference will it make if the mouth size is bigger/smaller?
Im guessing a tighter throat would be better for punchy bass and a larger throat be better for deep??? Confused
Posted By: Jhodas
Date Posted: 27 October 2007 at 3:34pm
You'll need a bigger box.
Date Posted: 27 October 2007 at 4:17pm
Bloody hell how big exactly do u think i should make it?  Confused
Posted By: mykey
Date Posted: 28 October 2007 at 5:20am
what about 38 x 30 x 24
why not just build the DubPass?
Date Posted: 28 October 2007 at 6:59pm
Whats wrong with the dimensions ive got already?
Posted By: AlfieDring
Date Posted: 18 December 2007 at 5:33pm
"Im guessing a tighter throat would be better for punchy bass and a larger throat be better for deep??? "
Erm, well that box looks like a BigVentReflex to me rather than a horn really. So the opposite rule of thumb will apply, the larger the cross section of the port for a given length the higher the tuning will go.
So small port = deep tuning, large port = high tuning. If you want it really chunky it has to be loads longer to compensate.
Alf
Posted By: Mark James
Date Posted: 19 December 2007 at 12:21am
yes hes right look at the expansion rate of that horn.... more like a port than a horn....
actualy as an aside where the bottom bend is youve actualy got negative expansion, will this area not also act as an extra rear chamber? so a sort of direct radiating bandpass.....
insert silly sentence here
