XM15 mitre angles
Category: Plans
Forum Name: X10, X12, X15 and XM15
Forum Description: Discussion / Questions about the X10, X12, X15 and XM15
URL: https://forum.speakerplans.com/forum_posts.asp?TID=12497
Printed Date: 27 March 2026 at 4:05am
Topic: XM15 mitre angles
Posted By: datguyjoe
Subject: XM15 mitre angles
Date Posted: 02 November 2007 at 3:56am
'ello,
I'm about to make an XM15 and was wondering if someone knows what the angles are for the mitred cuts. I would assume 45 degrees? Thanks.
Posted By: Richard Hart
Date Posted: 03 November 2007 at 10:21am
Yes, 45 degrees.
In the 90 degree plane there are two equal angles, just half it to get the individual value.
Posted By: kevin tyler
Date Posted: 20 November 2007 at 9:41am
err no, not 45 degs, mark it out and measure it,
we covered this when i made a pair, i think the angle was not possible using a circular hand saw too.
ok if you have nice tools.
kev
edit
i cant find the post, but i remember we had a discussion on here regarding making  a jig to pass the pieces through a vertical blade to obtain the right angle??
edit
here it is
http://www.speakerplans.com/forum/forum_posts.asp?TID=10126&KW=kevin&PN=1 - http://www.speakerplans.com/forum/forum_posts.asp?TID=10126&KW=kevin&PN=1
Date Posted: 25 November 2007 at 4:04pm
Kevin you are totally right, schoolboy error!
Just worked it out with trig, ones 39 and the other's 51.
Posted By: ceharden
Date Posted: 26 November 2007 at 12:43am
You could adjust the cab to have 45deg angles if you wanted tho....  Wouldn't make a lot of difference other than the angle it sits at on the floor.
Also, you don't need to cut a 51deg angle, just cut a 25.5deg mitre on each of the pieces instead!
