hd15 drivers
Category: Plans
Forum Name: HD 15 horn
Forum Description: Discussion / Questions about the HD 15 horn
URL: https://forum.speakerplans.com/forum_posts.asp?TID=1257
Printed Date: 27 March 2026 at 3:11am
Topic: hd15 drivers
Posted By: datguyjoe
Subject: hd15 drivers
Date Posted: 21 January 2005 at 12:02am
couple questions about the  HD15 sub. I built 2 of these subs, and used Eminence Delta 15LF drivers. the specs seem to be fairy close to the kappa 15's, just different power handling. they sound pretty good. Anybody see anything wrong with this? My second question is if I were to build build another pair and load them with the recommended kappa 15lf do you see any problems with combining the 2 pairs all together other than one set having lower power handling? I know combining different kinds of subs is usually a no-no, but these are the same boxes, just different drivers.
Posted By: norty303
Date Posted: 21 January 2005 at 3:35am
The HD15 isn't really a sub.  Its designed as a kick frequency box and should really be used with a sub under it like the X1 if you want to go that low or with just a lot of the HD15's to get the extension.
As for your question, the ideal route would be to load them all the same.  If you stack all of the boxes together they may not couple as well with the different drivers in place.
My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
