Whats the difference with JTS and
Category: Other Chat
Forum Name: Roots n Culture Forum
Forum Description: Talk about speaker box with other sounds here
URL: https://forum.speakerplans.com/forum_posts.asp?TID=12631
Printed Date: 27 March 2026 at 4:06am
Topic: Whats the difference with JTS and
Posted By: tweeter box
Subject: Whats the difference with JTS and
Date Posted: 09 November 2007 at 1:13pm
The item in the bottom of the rack is a 4way VALVE preamp made by behringer! Wink
It has seperate parametric eq's on sub bass, mid bass, mid and treble
The JTS has a few more additional features at 8+fold the price! Confused
What id like to know is;
a) What is the difference between the features on here and the EXACT/EQUIVILANT same features on a JTS pre amp? If any!!
b) Is the price justified? considering the behringer gives out that warm vavlve sound system bass ( JTS got no valves ) and only cost me £89 from new with recipt and garuntee!
Thanks in advance for all your input/feedback Big%20smile
PRECISION SOUND SYSTEM.
Posted By: Humble Tafari
Date Posted: 09 November 2007 at 4:12pm
I would have to use the behringer to give an throrough comment. Just reading ono paper is never like actually using it.
I have been using Tubbs preamsp since 84 and have never had any issues with any of them. Several of my preamps i have had customised (added switches/variation in cut-off points...etc) and pretty much stand by them. He has sent me a few prototypes over the years and they've worked just fine.
Yours look really impressive i must say, and interested to hear the accoustic difference between valve preamp and transistor pream. But the best objective would be for one to use them both to get most true opinion.
Respeks
Liberate the minds of men, and you will ultimately liberate the bodies of men - Marcus Mosiah Garvey
Posted By: Jhodas
Date Posted: 09 November 2007 at 4:56pm
Lob both down the stairs and take em both to a gig.
I know which one I'd play with...
Date Posted: 09 November 2007 at 5:03pm
Im guessing this is your normal way of comparing or testing equipment? lol LOL
Youd be a fool to play with any of them after a drop down the stairs!
Actually youd be a fool to drop them down the stairs in the first place! lol Big%20smile
LOL no offence intended
Date Posted: 09 November 2007 at 5:09pm
Respeks
Thankyou for your opinion/feedback
I dont think the behringer has as good build quality as a JTS but then ive never used a JTS, just wondering if anybody has used both?
Posted By: wasup
Date Posted: 09 November 2007 at 5:10pm
Nice to know what it is wanted to ask you when you posted in the my rig thread!
So you mention the warm sound is it like that? Does it make a big difference to the sound?Like no mistake or is it minimal?
I was looking into buying one but stopped partley due to funds but also they are not really valves in the true scence.This may cause a discution but read it was just modern things transisitors or such like imitating a valve! Hey no worries i would like to know about the sound itself!
Cannot help you compaire to a jts but why would you want to throw it down a any where let alone stairs?
How do you use it ? Like a crossover? One input and 4 outs like highs ,mids and bass? Or is it after a xover?
The signal is already split and then warmed up[valve effect] so inafect three/four inputs three/four outputs...?????????
Me i was thinking of using it for vocals!
Please tell me more ....
big up and more time andy
Posted By: russ d
Date Posted: 09 November 2007 at 5:15pm
the behringer is only a poormans 4 band (not 4 way) parametric eq, a very poor mans, its not a pre-amp, and certainly not similar to a sound system pre-amp... its made more for studio use rather than sound system, it can of course be used for whatever you want, but please at £89 you got to understand its a cheap piece of junk, real names in parametric eq`s or front end recording pre-amps for studio use are the likes of Neve, API, GML, SSL, Manley, Langevin, Universal Audio, Drawmer etc etc, and these things will cost 10 - 20 times the behringer, the reason is they are of much higher build quality, and actually sound good... behringer eq sounds weak and flimsy in comparison...
now to compare to a jts pre-amp, the two units do two ultimately different things, the behringer as described is a paramertric eq, the jts pre-amp is a control unit for a sound system, not just an eq, it has all the input/output to feed a sound system, it filters the seperate bass, mids, treble to feed seperate amps, and decks, fx, mics etc can all be connected at the same time...your behringer cant do none of that... you can of course build a system with behringer (and other cheap makes) to do what a pre-amp can do, you`d have a lot of wiring to sort and you`d be carrying 4 or 5 times the ammount of gear to do the job of a sound system pre-amp...
btw, the valves on behringer gear, and fairly much most budget gear, do very little, they also all put a small lamp behind to give the valve more of a glow, it helps sell to beginners !... dont be fooled that your getting a real valve sound with that piece of gear...
btw2... there was one sound i played on that used a spl valve unit to push thier bass thru, they still used transistor amps to drive their speakers, thier idea was to give the bass that `valve` sound, to me it did`nt work, it made the bass sound flat, uncontrolled and undefined, its just not the same as running proper valve amps.
in the end tho` if your happy with your little setup then thats all ok, its a starting point, and as years go by you will learn and understand more.
Disciples on I-Tunes.
Disciples on Bandcamp: http://russdisciples.bandcamp.com/
Facebook: russ disciple
Youtube Channel: http://www.youtube.com/user/sargantbrown?feature=mhum
Posted By: wasup
Date Posted: 09 November 2007 at 5:25pm
I see u use a computer! So why would you want a pre amp?
No wires at all when running it through the comp and the sound is really clean and nice! Well it is on mine can do just about everything FOR FREE as the programs dont cost anything near a PRE well my didnt cost anything at ALL?
True  a sound card may help and cost but they arnt all that much either certainly less than a PRE...........
Also no worries with mike and cutout switches NONE.....
What if a pre breaks down? Whole system is out .......Your system now will keep going just without the broken bit........
more time
Andy
Posted By: TONY.A.S.S.
Date Posted: 09 November 2007 at 5:34pm
Andy, has your computor ever crashed, I always have that fear. Only ever been used to the normal hardware.
Posted By: Jhodas
Date Posted: 09 November 2007 at 5:39pm
none taken. I was referring to durability in a somewhat direct manner. Basically, JTS preamps have a record for reliability. Berry gear just doesn't have the same rep. It's like (almost)  everything in the audio world. You get what you play for. I'm not slating Berry btw. It's good budget stuff.
Posted By: wasup
Date Posted: 09 November 2007 at 5:44pm
heights Mr T !
Well No it hasnt ! Then why would it?
Me i only know what i have [not very much]..But untill now cannot see any cons between a computer and a pre... In theory i could use any comp so if mine broke i could use the one in the office of the hall i was playing at! But you couldnt if it was a pre!Or  i could run out from the mixer [also a pre] Ok how would i get my music out of the comp well mine on an external HD of which i carry 2...........
But then had no problems with power or lack of it ,like them talk about on here recently which will kill ur sound or quality ..But i see what your saying!
Date Posted: 09 November 2007 at 7:26pm
Give thanx for the Insite and heads up bredda Russ,
Makes much sense now.
Respeks
Posted By: Father-Francis
Date Posted: 10 November 2007 at 4:36am
heights Mr T !
comp and external all the music you have in them, did u pay to download ,rec from your own cds, or are you one them killers , remember your  the recordshop bro them have to eat too 45 run the dance .no dibidibi OuchAngry
Posted By: ToNy MoNtAnA
Date Posted: 10 November 2007 at 4:40am
Behringer valve pre-amp is JUST a budget parametric EQ really,nothing alse.
Also the valves are not a high quality type and are a warmth effect, as the rest of the circuity is transistor based, not all valve based.
A proper all valve based preamp are expensive like £500 or more.
JTS 4 way pre-amp has a high quality parametric EQ on bass and mid, high quality 10 band graphic EQ, high quality fixed 4 way active crossover, low,low mid,mid and hf kill switches, deck inputs with crossfade.
And a few other things.
If you just play reggae and dub, your much better off with the JTS or full mostec preamp.
Or mostec mini-pre if your strapped for cash.
And if buying the Behringer was down to lack of money, then the mostec mini-pre for £350 is really affordable compaired to £595 for the JTS 3 way and £795 for 4 way JTS.
Although the mostec mini-pre only has a bass parametric, 7 band EQ, 3 way active crossover, 3 way kill switches, deck and line input, mic input.
And has to be used with an existing mixer.
Posted By: wasup
Date Posted: 10 November 2007 at 5:15am
Well not just a money thing just part of the equation!
I certainly dont think youd be better of with a PRE...I mean if one was starting out from scratch with no equipment at all it may be cheaper to start with a PRE as its all in one.However all in one has its downfalls BIG TIME ...
HOLD on who does that[put away what they have]?Most will all have a bit of this and that so in NO WAY cheaper...Also wouldnt be very concious to sudenly put away all what you have, just to have that PRE to be able to call ones self a REAL REGGAE SOUND!!!!!!!! The PRE doesnt make the sound better AT ALL in many ways worse!!!What can you do with a PRE that you cannot do with a collection of equipment????
All this HYPE is about gaining a SALE fe REAL........ Make me think of JESUS and kicking them all out of the church!!
If these PREs are that HIGH quality the price is  quite cheap mind you i have my doubts there as well!!!!!!!!!!!! Yes quality or a far cry from CRAP  ,i dont doubt and you can often meet the makers so should get service BIG UP THERE..... But keep it REAL how different are the components compaired to lets say a BERRY? They must be getting there transistors quit cheap BULK BUYING and that........
All the MAKE name mentioned earlier how much do you pay for the NAME and HYPE??????
A RASTA sound that promote this HYPE in my oppinion is no beter than the SYSTEM they call so bad..I mean its just a different system with a different AGENDA but the intention remains the SAME..........................Granted you have another group of people holding the rains of power both SYSTEMS are not JAH!!
more time
andy
Posted By: wasup
Date Posted: 10 November 2007 at 5:23am
Basically WHAT THE SUCK has that got to do with YOU? BEt your hollier than HOLLY.
However to answer you question YES ALL OF THEM ...............I have thousands of records YES i recorded some! YEs i have payed to download! YES MY own cds!AND YES I DOWN LOAD FOR FREE.................SO WHAT? TEll me about it I have owned a reggae record shop come culture/merchandise/coffie shop .
The reason i called my sound what i did is BECAUSE OF PEOPLE NOT UNLIKE YOURSELF!!!! you are the point i was trying to make so BIG UP AND THANX FE THAT!
What about suporting a sound ? I mean its all one way unless you have a wooly hat and buy your herb from the right grower!Perhaps CLONING ones views on the cleches and stigmas that are around would HELP .....
NA me i do what i have to do in the best way i can answer TO NO MAN only the MOST HIGH........................ SO COME DOWN OF YOUR HIGH HORSE AND CHECK YOURSELF......................
Posted By: mskeete
Date Posted: 10 November 2007 at 9:17am
wassup, you seen to like to take these discussions where they doubt need to go (well at least not in this thread) - woolly hats and rasta and weed and helping a next sound........
You've seen at least one open invite on this forum to sounds to come and play in walsall
Did you follow it through? (all I saw on the forum from you was a largely less than positive response)
It's IC's you'll find in JTS and my preamps not transistors. I use one transistor and that's for the output muting circuit. Some of circuits are quite close to what you find in name brand 'pro' equipment - e.g phono stage
You understand electronics don't you ?
Go to the rane website and check out some of the circuit diagrams that they are kind enough to put in the public domain and tell me what's  so special and check the IC's they use - nothing exoctic or too expensive, check out some mackie, neeve or whoever
Same sort of thing so what is it that's "close to crap" in a preamp
If you want to back up your statements with technical talk then I'm here. If you want to drag more politics into the discussion then I'll go and read something else on the forum
you seem to have a thing about preamps - maybe too many people been telling that you HAVE to have one and you 'rebeled' - good for you
Buying components in bulk just starts to make sense when you have a certain amount of things to build. If I can get the SAME component cheaper if I buy 100+ or 500+ and I know they get used up then why buy 50 and pay more per part
Computers aren't perfect and there is more to go wrong in a computer than in a analog piece of equipment. If you knew all the sh*t involved to just get the OS to boot (maybe you do) never mind running an application then you might think twice about playing aout with one
Date Posted: 10 November 2007 at 9:57am
Give thanks Mskeete. the thing is almost every where I read people talk negative about someone doing something positive , and I say this cause I don´t just play I promote and produce so it hurts when people just download music for free an play from their comp it´s not right. And I never said I was perfect I only try to do what I feel is right for all.
I don´t have time to make everything so I work and buy if i play a cd its´ cause you can´t find it on lp or 45´s or our owe production. about cloning I´ve been growin am owe since I came to europe 90% of what I smoke is home grown.
No hard feelings Rasta don´t steal ,Rasta don´t beg. ask you´l get advise how wrong can you go. Sorry everybody I know this is not the place for this , but I don´t like negative vibesShocked
Date Posted: 10 November 2007 at 10:12am
Basically it's all down to how the sound is run. Although there is still such a thing as crap gear if it won't do the job, doesnt last or does the job poorly.
And also if you try and get something thats not made to do the task at hand, it's gonna suck at it.
Although theres nothing wrong with using something different as a personal preference to be unique.But as long as the crowd get impressed.
You could have a FK1 system but it would sound crap due to the sh*t operator. An example of that is the Valve Sound System. Decent system but idiots running it.
A pre-amp in the reggae scene can make a reggae sound, better, if you know how to operate it correctly to fit in with the tunes played,etc.
But it's not essential, as Jah Voice don't have one, but sound heavyweight and play decent tunes so the crowd loves them.
But if you want to be a traditional reggae sound system with sirens and fx etc, you need a pre-amp like JTS or mostec.
Date Posted: 10 November 2007 at 10:50am
Yes Tony M I hear you thats always been the way I sees it 19years we´ve played on normal speakers and just a normal mixer and the dance nice ,always have a crowd of people. we just want to upgrade now so we got a JTS preamp , haven´t used it yet we plan on running a 4 way system I let you know how it goes. biggup
Posted By: wasup
Date Posted: 10 November 2007 at 11:24am
WHAT ABOUT THINGS AND TIMES?Determining why where and what!
THATS exactly what i am saying!
Exactly it! But many are under pressure to be and or to have.Wether that be done intentional or just the way we PEOPLE are keeping up with the JONSES and all that i dont know .But again thats exactly why i say what i say..Not for or against but all this reggae must be like this or that NO CHANCE!
You know that advertizing machine that seems to be behind everything! BABYLONIAN or the SO CALLED CONCIOUS ONES......Same thing just a different mask!
So did reggae sounds start with a pre? Or has that developed over the begin years? If so then in the true scence of the word TRADITIONAL then it would be what came before together with the development OFF..In my oppinion!
Date Posted: 10 November 2007 at 11:45am
Its not about lack of money im just not really interested in getting a JTS or a MOSTECH, i dont feel i have the need for one, personally i think my controls on my mixer, graphic equaliser and crosover are plenty useful.
The only reason i got this berry job was coz it looked cheap for what it is and i wanted to experiment with the advantages/disadvantages of a parametric,
I think all stuff from berry is crap/cheap for a reason (budget/starter) I tried one of theyre amp once with my subs n they sounded sh*t, floppy and uncontrolled i actually thought my subs were rubbish !! good thing i didnt damage them.
I tested a mates mostech 4 way not to long ago and IMO it wasnt nuthing speacial, but thats my honest opinion!
The point of this post was exactly as stated on page 1, it wasnt to degrade anybody or prove whos betta but simply to find out what people thought and get some feedback/advice
Yet again thanks for your input Tony Smile
Posted By: wasup
Date Posted: 10 November 2007 at 11:49am
give thanks Mskeete. the thing is almost every where I read people talk negative about someone doing something positive , and I say this cause I don´t just play I promote and produce so it hurts when people just download music for free an play from their comp it´s not right.
Who YOU to say what is or isnt right?Please define NAGATIVE? As that is a matter of perspective ..Truthfully said one doesnt go without the other.They flow into and out of each other ..Why/How do you think new,better or improved things EVOLVE or happen?
Well truthfully what you just said[above] and now its not for everyone but because you promote ,play and what ever....BASICALLY keeping it real Its YOU YOU AND YOU! Hey but no worries i dont feel what you feel I SEE IT DIFFERENT however am like you doing what i have to do......Thing is you PRESUMED very cleche dogmatic BABYLONIAN thought patern .What i do or dont do and you are wrong!!
So if someone cannot work or get buy because of what ever personal reason he may not play music? Or only that what he has payed for? By playing it bringing it to peoples ears isnt he giving suport? What if all he earns ,if infact he does earn anything goes back to where it came from? Not my situation however could be someone elses or part of some one!
I think i was refering to taking on the apperance thought patern or what ever of PEOPLE when i used the word cloning!
Mind you the cloning you speek of is very interesting ! I to have in the past had a room with mothers and children lol lol....Mind you NOT ALLOWED TO SPEAK OF THAT ON THIS FORUM!
Hey but can we clone from a RASTA perspective? not that you have said you are!
So basically your listing LIMITATIONS cleche wise! Reality show me something else!
Well perhaps YOUR VIBE IS WHY I REACT IN THE WAY I DO !!! INITIAL REMARK TO ME IS ANYTHING BUT POSOTIVE...HEY I AM SURE YOU MENT IT LOVING AND TENDER.DIDNT MEAN TO BE SO BLOODY PRESUMTIOUS....But like you didnt say you was perfect TRUE TRUE still would advise to CHECK YOURSELF BEFORE pointing ones finger...All said in the nicest possable way!!
Date Posted: 10 November 2007 at 11:59am
Well I guess it started from Jah Shaka. Who is the legendary, the best ever selector for roots and dub. And he uses a pre-amp. And everyone wanted to be as good as selector like him, but no one yet can.
But then again he uses KT88 valves and a Garad turntable, so why doesn't most sounds use that too... I guess cos they don't want to try copy Shaka entirely. And be more unique.
I'm not entirely sure before Shaka who started in the early 70's. If anyone alse used a pre amp before that time. Studio One might have. I was born in the early 80's.
Maybe someone born in the 60's whos into reggae could say.
Posted By: wasup
Date Posted: 10 November 2007 at 12:21pm
Well chosen ! like you said SEEM......however certainly not a preconcieved notion of mine and kept in CONTEXT VERY RELEVANT..Isnt the soundsystem a voice?
Again well chosen words tread carfully! No i didnt see it ! Quit far for me the logistics of it all mind you certainly not saying i wouldnt! Did you also see in a thread not so long ago that i had offerd to come for nothing yet my offer wasnt taken? ne hard feelings BRO either way!
I used the word transistors for the want of better or more words .I ment all what is to be found within! Not being specifiek just generally speaking..Sorry i see i may not do that and in the future wil specify!
DO I ?
Same sort of thing so what is it that's "close to crap" in a preamp...
OUT OF CONTEXT ! Ok no literary genius i know but i didnt say that at all!this is what i said or i am missing something????
Yes quality or a far cry from CRAP  ,i dont doubt    is what i said... again no worries.....I was being posotive in my mind!!
If you want to back up your statements with technical talk then I'm here. If you want to drag more politics into the discussion then I'll go and read something else on the forum..
 Sounds like a school playground GUV...... so i guess its go READ sumfing else!
Mind you are soundsystems seperate from politriks?
I mean  HUMMBLE in one of his post recently seems to say the two are not to be seperated..
He thanks the soundsytem for all his KNOWLEDGE! Abviously not your oppinion......BTW my initial remark or question was dirrected at the BERRY in question certainly didnt realize i would meet with so much hostility and or animosity!! so again sorry ! mind you not sure for what!
you seem to have a thing about preamps - maybe too many people been telling that you HAVE to have one and you 'rebeled' - good for you....
Well thanx! lol But me it was THINGS and TIMES i had this and that so i built on it !! Which is what i have been saying all along! CERTAINLY NOT IN ANYWAY REBELIOUS! Again like i said if i had nothing i would certainly investigate starting with a pre !!!!!
Good BIZ sence! GUV
But again not what i was saying! What i was trying to say is, are the components used in a berry or such like THAT MUCH INFERIOUR TO THE ONES LETS SAY YOU USE???????I can see it however pos!Also not saying you would cut corners but you are subject to the same as any manufacturers! Thats just it! So how do you reach your balance was basicaly it!
I build make lots of things out of having to or to go without[my thing]! Sometime one has to take less or more ...Why is this any different than buying electrical components?
I think thats the point TONY ASS was making! All things go wrong at some point in time TRUE ENOUGH!
Me i just push the button and it goes on thats it finished[well and i can do a little bit more lol]! But if it did break down i could use any comp from anyone ! Not something that could be said for a pre! IS IT?
So perhaps i should ask why build it a PRE none modular? Why do you do that! Is it just a question of space? I mean a sound system[the stack] is modular so is almost everything else but not the PRE......! Why ?
I aint agianst YOU M ! You should know that? I tell anyone who want a PRE to go to YOU so lol WASUP?????
Posted By: DUBPLATE
Date Posted: 11 November 2007 at 2:05am
just use wat ever u wanna use
if u like wat u hear
u got a followin
u makin money
it hasnt cost u too much to get wat u want
carry on doin wat u want till u can afford to buy beta stuff
j-voice has blow the need a preamp myth out the window, they can do the (sirens and fx etc) thing cause they use a mixer & must have unused channels
Posted By: King Simeon
Date Posted: 11 November 2007 at 2:01pm
I think there are two points in answer to the original question, both have been expressed, so its clear it just down to opinion/preference.
You can work out any set up to run a sound, you could use fifty different pieces of equipment to run it thru. Many sounds to the day are still playing round with different ways of setting up. Thats the 'fun' of sound system. Whether you can hear much difference.....? I've not heard anything that drastic to make me think its all that worthwhile.
The pre amp makes running a whole heap of equipment simple. The ammount of technicals every sound has, its handy to have signals as straight forward to trace/control. As i see it the pre amp is the ideal custom built solution, fed from experience since the begininngs of sound system. If you have any way different to run sound, thats choice, and also a natural development in running sound. There are no rules.
Personally, i couldn't run it without a pre. I dont have enough technical knowledge to know how to make a set up that is cheaper and as effective, and good; to my ears. I remember Tubbys played a session in Nottingham, think it was with Smith & Mighty. Tubbys took about 12k and S&M(!!) had somthing like 60!!! Tubbys out weighted comfortably. There are countless stories similar, ie. Boomshackalacka sound, their spec stood up to others with a lot bigger. Simple things, no secret buttons/units business.
Bottom line, it's what you do with what you got. Personally Jah Voice spent a whole heap of money on equipment, but i get no flavour from their sound. All productions sound the same thru their set, lack 'character'. I like to hear 'difference', ruff around the edges is part of the music, check the cycle of old hardware/sounds coming back in vogue in productions. Also it should be noted that a lot of material played on sounds as dubplate are often un-mastered, its difficult to 'shine a turd'. Again, character, if the vibes are there, which is the reason it gets to reach a session as a special dub, let it runnnnnn same way! I still look forward to developments with Voice, they're making a lot more of their own tunes and full respect for that. It's only my preference on their sound, i'm just more keen on hearing more of their productions, there's a lot of experience in there.
Date Posted: 11 November 2007 at 4:26pm
Respect King Simeon for your opinion Smile
