18" scoops build advice needed please..
Forum Name: Newbie Discussion
Forum Description: Newbie Discussion/Questions. Look less stupid here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=12870
Printed Date: 26 March 2026 at 5:30pm
Topic: 18" scoops build advice needed please..
Posted By: bill-77
Subject: 18" scoops build advice needed please..
Date Posted: 21 November 2007 at 9:11pm
hi all forum members i,m planning to build x6 standard scoop box,s old school style...what i would like to know from the exsprienced in forum is how many  8ft by 4ft sheets of ply wood will i be needing for a single scoop box? i will be using the measurments from my other x2 scoops......  and would the standard wicks ply wood be ok to use ? £22 a sheet....or will i need to use the exspensive marine birch ply wood ?.....i have built small scale box,s in the past but nothing to what i,m in the process of doing ,,so i have some exsprience..tips and suggestions from the the exsprienced would be appreciated many thanks regards bill Wink
WISDOM IS BETTER THEN SILVER AND GOLD!!
Posted By: TONY.A.S.S.
Date Posted: 21 November 2007 at 9:23pm
Just use muti-laminate ply. Normal baltic birch isn't marine ply. I assume you have the cutting list, so draw your parts on to a scaled down 8x4, and then you'll have the answer. It'll be a good way of familiarizing yourself with the forth comeing project.
Posted By: bill-77
Date Posted: 21 November 2007 at 9:32pm
nice one tony a,s,s i appreciate your advice ....tony i heard alot of people use car chip spray to spray the cabs,,whats your opinion on this ? ..my other x2 scoops are painted with standard paint,,,what would be the best paint to use? somthing durable and long lasting thanks bill
Posted By: LostGrayCat
Date Posted: 21 November 2007 at 10:43pm
http://www.speakerplans.com/forum/search_results_posts.asp?SearchID=20071121224139&KW=speaker+paint - http://www.speakerplans.com/forum/search_results_posts.asp?SearchID=20071121224139&KW=speaker+paint
Date Posted: 21 November 2007 at 11:07pm
As a manufacturer, I've always stuck to pretty std. stuff In my position, I've always had to concern myself with production. Which means easy access from a reputable supplier, and buying in quantity always gets a good price. There could be some amazing material out there, that could used in a one off situation. If you went into production with car chip paint to do it properly would cost a fortune with the specialized equipment. It's unlikely that Fords use a can.
Posted By: bill-77
Date Posted: 22 November 2007 at 9:47am
thanks guys i,m gonna give this project a tryCry lol see how i get along ,,,i,ll stick to convential d.i.y paint to keep the cost low as possible...i was reading in a another forum some one suggested to  use chip board and build a prototype....i might just do that build x1 to get familiar and inprove my skills,,,Embarrassed lol well if i get stuck i,ll let you guys know ,,thanks for advice and guidence regards bill..
Posted By: Static Age
Date Posted: 22 November 2007 at 10:23am
i'm close to finishing off a pair of scoops myself at the moment, you will use the best part of two 8x4 sheets of ply per cabinet as the sides of scoops are quite large. dont forget to budget for the thinner sheets of ply you need to form the actual scoop part.
scoops are fairly easy to build as there are no particularly difficult cuts required, so i wouldnt bother with a chip board proto type.
Posted By: bill-77
Date Posted: 22 November 2007 at 3:15pm
  thanks static age for that tip...i was having a inspection at my other built x2 scoops and they seem to have that classic scoop part made out of some sort of thin mdf material ,,its very smooth ,,doesnt feel or sound like thin ply wood as its very hollow sounding....but i will use your advise and use thin plywood i reckon its more durable,,,what speakers will you fitting in your x2 scoops static? thanks for sharing your knowledge regards billWink
Date Posted: 22 November 2007 at 4:00pm
i will be fitting Fane Colossus 18XB's in my scoops to match my other scoops.
here is a handy tip from Rog regarding the scoop section...
'To make the curved part of the horn flare bend a piece of 3 mm plywood around some battens that have been glued and screwed to the side walls to form the curve, then glue and nail another piece of 3mm plywood on top of the first piece. Keep doing this with another 4 pieces of 3 mm plywood until you have all 6 pieces glued and nailed together. The finished curve should now be 18 mm thick. For a better job use 4 pieces of 18 mm ply to make the curved former. Use a jigsaw to cutout the curve from the 18 mm ply and glue and screw them in place evenly spaced across the width of the curve. The 2 outer most formers should be positioned right against the cabinet walls.'
Posted By: bill-77
Date Posted: 22 November 2007 at 4:24pm
Thumbs%20Up nice build static,i see what you mean by over lapping the plywood sheets to make a solid rigid scoop very nice...lol i cant wait to get mine started,,,thanks again static for advice and tips much apreciated regards billWink
Date Posted: 22 November 2007 at 4:30pm
Bill, thats not my build. that pic is a super scooper built by Dom, the pic is taken from the readers projects section on the sepakerplans home page, see...
http://www.speakerplans.com/index.php?id=dom18sc - http://www.speakerplans.com/index.php?id=dom18sc
I posted the pic as an example on how to assemble the 'scoop' part.
my scoops are currently at a similar stage but minus the scoop, i will get some step by step pics up when i have finished the project.
Dan.
Posted By: bill-77
Date Posted: 22 November 2007 at 5:02pm
oh ok sorry thought that was your build lol ,,,i was wondering that looked very diffrent from the old school classic scoop lol ..static those pictures of yours would be very handy and educational for beginner project builders like my self ..will be looking forward to seing them Thumbs%20Up.....i,ll post some of my project pictures when i get the first finished lol dont know how long that gonna take me Embarrassed but i,ll be starting the first on sunday..static did you cut the pieces out with a jig saw or you took your measurements to a cutting merchant and have the x2 8x4 cut by them ? thanks regards billWink
Date Posted: 22 November 2007 at 5:34pm
i have a table saw so i cut all the panels on that.
my scoops are also an older style design, similar to the old JBL scoop but 18" version.
Posted By: bill-77
Date Posted: 22 November 2007 at 5:54pm
Thumbs%20Upnice static  thats so handy having your own tablesaw...i was thinking of using a jigsaw but thats gonna be messy cut outs all uneven and wonky lol so i,ll leave it to the cutting merchants Wink..static thanks again for sharing your knowledge regards bill Thumbs%20Up
Posted By: Jhodas
Date Posted: 22 November 2007 at 6:57pm
Don't use a jigsaw . I've never built a speaker in my life but I can tell you from my (extremely limited) woodworking experience that accurate miters are near as damnit impossible with a jigsaw.
Read point one on this page.
http://www.speakerplans.com/index.php?id=guide2 - http://www.speakerplans.com/index.php?id=guide2
From Mr. Mogale himself.
Posted By: bill-77
Date Posted: 22 November 2007 at 7:26pm
hey thanks jhodas thats really got me thinking coz at 1 point i was considering using a jigsaw Confused lol i know crazy idea especially for building x6 scoops ...its gonna have to be the cutting merchants ,,dont wanna waste the exspensive ply wood lol thanks jodhas for your advice and forum link very educational Wink
Date Posted: 23 November 2007 at 1:28pm
here are the pics..
Date Posted: 23 November 2007 at 1:30pm
Date Posted: 23 November 2007 at 1:31pm
Posted By: Tekasis
Date Posted: 23 November 2007 at 2:26pm
Looking good so far! Are you not planning to add the triangle piece at the bottom of the rear panel?
Date Posted: 23 November 2007 at 3:17pm
thanks, Tekasis.
which triangle piece are you reffering to, do you mean the panel immediateley behind the driver?
Posted By: Saul
Date Posted: 23 November 2007 at 3:51pm
...festool...
Posted By: Mark James
Date Posted: 23 November 2007 at 4:04pm
mitre with a jig saw?????? WTF? lol if tats all you got then id say youd be better trying to sand th angle than cutting it, and i wouldnt recommend sanding either......
insert silly sentence here
Posted By: bill-77
Date Posted: 23 November 2007 at 7:15pm
very impressed,great wormanship..cant wait to see the finish productWink....nice pictures... how much do those circuler bench saw,s cost?  i might be better of getting 1.... it would save me alot of time and hassle making trips to the cutting merchant...and it will come handy for other projects...saul mentioned somthing about festool is that a brand of circuler saw ?....i,m only familiar with automotive tools like snap on,mack,britool,,,,or could i use the hand held circuler saw those are quite cheap..saw them in wickes when i went to enquire about the plywood? thanks Wink
Posted By: bill-77
Date Posted: 23 November 2007 at 7:23pm
i know was a crazy idea lol but after i read what link jhodas sent me i was put offConfused,,,,i,ll probally invest in a bench saw or those hand held circuler saws by makita..i,m just getting my self prepared with what ever essential tools i might need to make this project simple and efficient as possible Wink
Date Posted: 23 November 2007 at 7:41pm
a hand held circular saw would do the job, though achieving some of the angled cuts is alot easier with the table saw.
i guess you have to decide exactly how much building you intend to do before you invest in tools but basic table saw's are reletively cheap.
http://home-garden.search.ebay.co.uk/table-saw_DIY-Tools_W0QQfromZR34QQsacatZ631 - http://home-garden.search.ebay.co.uk/table-saw_DIY-Tools_W0QQfromZR34QQsacatZ631
I am lucky as the table saw i use belongs to a friend, i store it in my lock up for free in exchange for the permission to use it. its been a great help in building cabs & i would be more than happy to replace the blade for him if it ever needs it.
i will post some more pics up as the build pogresses.
Posted By: bill-77
Date Posted: 23 November 2007 at 8:32pm
hey very impressed your project has given me more motivation...i reckon a table saw will be to major for what i be needing it for.....i think the hand held circuler saw would be ideal as after i,ve built the scoops and a few tops i wont be using it much...keep up the good work staticThumbs%20Up....i,ll be looking forward for the finished pictures...lol give me a couple of months for my first completionEmbarrassed and i,ll post a few of my project pictures....well i see how long the fist takes me then the others would be become easier to build...thanks again staic for pictures and advice regards bill Wink
Date Posted: 23 November 2007 at 9:04pm
you will find once you get going that things progress quickly. i only started on my scoops on Monday night, been working on them a couple of hours a day.
Date Posted: 23 November 2007 at 10:27pm
Get a table saw, well worth the investment. But the problem with tools is like getting the sound bug. It never ends.
Posted By: bill-77
Date Posted: 24 November 2007 at 5:08pm
hi lostgraycat i was comparing price diffrences between the hand held saws and bench saws and thers not much diffrence in price really so it will be a bench saw ,,more versitile thanks for the tip Wink.....just a matter of getting the saw and wood,screws,glue ect time comsuming,,i,ll be abe to only spend a few hours a day buiding due to work commitments and children ,,,but the key to a successful finish is patience,i,m not in no rush really as i have x2 scoops which are doing the job for now... lol and yes this is a very addictive and exspensive hobby or career to undertake Confused but i,ll get there slowlyEmbarrassed lol thanks guys for the support..
Posted By: boycey
Date Posted: 24 November 2007 at 5:52pm
check this out:
http://srforums.prosoundweb.com/index.php/m/236035/25637/0///19929/#msg_236035 - http://srforums.prosoundweb.com/index.php/m/236035/25637/0///19929/#msg_236035
sorry marjan but your handiwork is pretty awesome.
http://srforums.prosoundweb.com/index.php/fa/10730/0/19929/ -
Big%20smile
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
Posted By: bill-77
Date Posted: 24 November 2007 at 6:44pm
check this out:
Big%20smile
thanks for that link boycey ,,wow thats hard to believe those cabs where cut and mitred just using a standard jigsaw,,seing is believing nice work and finish,,so it is possible depending on expertese on jigsaw skills....i,m very good with using a jigsaw as i,ve laminated my entire house my self and built small box,s with just a jigsaw when i was a teenager lol .. ...its proven and shown in boyceys link...very impressedWink....Has any body on forum built large scale box,s like shown in link with just using a jigsaw ? would be good to know regards bill..
Date Posted: 24 November 2007 at 8:58pm
few pics from todays build session.
Holes for speakons & bolt fittings for castors, there are M8 T nuts on the inside.
Date Posted: 24 November 2007 at 9:02pm
on the left is the scoop i copied the dimensions from
Below, the new scoops minus the 'scoop'
Date Posted: 24 November 2007 at 9:41pm
Was wondering if there's enough room to add extra material so the wheels don't rip out?
Date Posted: 24 November 2007 at 10:08pm
do you think that could happen? i mainly do indoor gigs so i dont have to wheel the cabs over ruff ground.
Posted By: bill-77
Date Posted: 24 November 2007 at 10:23pm
static those are awesome old school stylee builds,made to perfection very impressed,and you only started last monday if i rerember correctly thats just shows how quick these can be made once you have made a few previously well done Clapand thanks for posting your project pictures for all off us to see and admire...static will you be painting yours or spraying them ?
Date Posted: 24 November 2007 at 10:33pm
thanks for the positive comments.
to get them to the stage they are in the pic above took about 16 hours, next step is to cut holes for handles & build the scoop bit. i have made a template for the curved formers so it shoudlnt take long.
I'm painting them with black aldcrofts, i dont have the facility to spray the aldcrofts on.
more pics to come as the build comes to a finish.
Posted By: bill-77
Date Posted: 24 November 2007 at 10:40pm
Its a shame they dont make them the old school way any more..16 hours is a decent time considering you only put in a couple hours a day well done static...i.ll be looking forward for the finished pictures keep the good work up Wink regards bill
Date Posted: 25 November 2007 at 11:11pm
ok maybey you can mite cut with a jigsaw, howether i personaly couldnt and doubt some one who is not realy skilled could, and i certainly wouldnt recomend it.
@static age, nice looking work there!!! i love seeing build pics. it is just so nice to see a loudspeaker halfe built, thank you for sharing......
Posted By: Tekasis
Date Posted: 26 November 2007 at 9:37am
I was referring to that panel, but then realized you & Bill are building standard scoops & not supers!
Date Posted: 26 November 2007 at 10:41am
yep old skool style scoops Tekasis. if i didnt already own a pair like that then i would have built supers but i wanted matching cabs.
@Markk, thanks for the positive comments!
Posted By: levyte357
Date Posted: 26 November 2007 at 5:25pm
But I hear supers are a lot more work than Fane or JBL, and not that much difference in sound, just sturdier and heavier due to bracing.
Static those look like JBL's but maybe bit wider etc (Bit like my mods), Which drivers have you heard in those, and what do they sound like?
Date Posted: 26 November 2007 at 5:51pm
they are very similar internally to the JBL scoop. the front chamber size is not much different to the super scooper.
my original pair are loaded with Fane 18XB's & they sound very good, loud & have a nice warm tone to the bass.
thats why i have built this new pair, i already have another pair of 18XB's to go in them.
i havent tried tham with any other drivers, i do have some 1000watt RCF (i cant remember the model) which might be worth a try.
Date Posted: 26 November 2007 at 6:41pm
My mods should result in lower extension, at slight expense of throw.
How much would would you charge me matey, to do a rough prototype in chipboard?
Posted By: minaximal
Date Posted: 26 November 2007 at 9:38pm
well, i wouldn't bother without a big pot of filler, unless i had...
a foot plate for the jigsaw to fit on the guide rail.. but then the circular saw is quicker.
Subs + Barges = :)
http://www.metaacoustics.com" rel="nofollow - www.metaacoustics.com
Date Posted: 27 November 2007 at 10:58am
thats an interesting prospect, chip borad isnt the best stuff to work with but it is very cheap for a 8x4 sheet.
let me finish of the current scoops then i will get in touch via pm & we can arrange something mate.
edit: Levyte check ya PM's
Posted By: Father-Francis
Date Posted: 27 November 2007 at 12:00pm
Nice one Lev
Posted By: Tekasis
Date Posted: 27 November 2007 at 1:36pm
[chip borad isnt the best stuff to work with but it is very cheap for a 8x4 sheet.
Over the years, we've come across scoops which actually sound better in chipboard & MDF than ply! Not too sure if this all depends on the type of cab.
Posted By: tweeter box
Date Posted: 27 November 2007 at 2:03pm
Wicked build pics Static Smile
Scoops look well nice, bet they gonna sound the buisness aswell.
PRECISION SOUND SYSTEM.
Posted By: bill-77
Date Posted: 27 November 2007 at 5:04pm
hi all been buisy doing over time to pay for the materials needed..just managed to get a second hand bench saw for 60 pounds from ebay...scary piece of kit to use that 10 inch blade looks and sounds dangerous when powerd up lol ..i thought using my airtools at work where bad enough...got x2 sheets of ply and just need to measure and mark then cut.. gonna ask  me nephew to come and assist  coz that sheet of ply is dam heavy..Cry....static did you join the x2   8x4 plywood sheets together then cut them or cut them one by one ?  thanks regards billWink
Date Posted: 27 November 2007 at 5:31pm
i cut each 8x4 sheet seperately. plan your cuts carefully to get the most out of your sheets, you will find the scoop side panels are the biggest panels to cut out.
Posted By: bill-77
Date Posted: 27 November 2007 at 5:43pm
thanks static for the tip and advice...i,m getting there gradually ...i,ll begin to post some pictures when i get the first scoop partly assembled..plz rerember this is my first major build so it gonna take a while Embarrassed
Posted By: tommysb
Date Posted: 27 November 2007 at 8:29pm
Just take things slow, do a panel or 2 in each session and don't rush!
Posted By: bill-77
Date Posted: 27 November 2007 at 8:38pm
  thanks tommy thats exactly what i wanted to say lol you said it for me thanks Wink...
Date Posted: 29 November 2007 at 1:50pm
i had a little break from the scoop build since the last lot of pics, but last night i put a couple of hours work in..
heres the formers for the actual scoop bit. i decided to use the curved formers as recomended in the super scooper plan, i also added a 50mm wide horizontal brace which i mounted into the curved formers via cut outs for extra strength.
Posted By: adambomb
Date Posted: 29 November 2007 at 2:06pm
fill it with sand!
http://www.freespeakerplans.com" rel="nofollow - www.freespeakerplans.com
Date Posted: 29 November 2007 at 2:19pm
Originally posted by adambomb adambomb wrote:
fill it with sand!
Hi adam could u explain this pls?
Posted By: mykey
Date Posted: 29 November 2007 at 2:48pm
not practical
very good static using the ribs
we did that in the XXL's and doing the same in the DubSubs
you should have left the back off though so you can see if there are any gaps to fill
in the dubsub its ok because of te piece missing for the castors
will be proper when you've finshed them
good to have the photo history of the build as well when you go to sell them
......just all them hanging there like giant bananas.
Date Posted: 29 November 2007 at 3:17pm
i could see if there were any gaps by looking through the handle cut outs on the bottom.
cheers for the positive coments mykey
Posted By: bill-77
Date Posted: 29 November 2007 at 5:09pm
very nice static ..very detailed and clean work well doneWink....just about got my pieces cut lool
Date Posted: 29 November 2007 at 9:44pm
pics from tonights build session.
scoops now in, battens for grills fitted & screw holes filled.
Posted By: mykey
Date Posted: 01 December 2007 at 3:17pm
Clap solid , will be around for years
you gonna put a nice cross brace in
and why did you miss out the dog leg? (triangle piece)
battens around the mouth are a bit large though?
i'll do you a drawing of what i think you should have done and a few other members mite want to do it as well , its what i used to do on my other scoops
Date Posted: 01 December 2007 at 4:42pm
i will be fitting a cross brace in the mouth, i left it out to make it easier to get in & paint the inside.
the triangle piece isnt present on the scoops i copied so i didnt put it on these.
again the battens are the same size as on my other scoops, they do look quite big but they dont stand out as much when painted.
Mykey, thanks again for the constructive comments, i would like to see your drawing.
like i said my other scoops do not have tha dog leg (triangle bit) & they sound great.
does it really have much of a difference to the sound? if so i might do with/ without comparrison test with some working cabs.
Dan.
Posted By: bill-77
Date Posted: 03 December 2007 at 8:29pm
[/QUOTE] []static those scoops are aboslutely solid well doneClap..and thanks again for making the effort to post your project pictures on here Wink....been a very buisy dude just about got the first finished thanks for the guidence and tips stactic age  ..will be posting very soon..
Date Posted: 03 December 2007 at 8:42pm
pics then bill? lol...
Posted By: bill-77
Date Posted: 03 December 2007 at 8:50pm
lol very soon my friend ,messed up on the first then had to rebuild it Embarrassed..not easy for a newby lol getting there though LOL
Posted By: ToNy MoNtAnA
Date Posted: 11 December 2007 at 1:30am
Love how you did the bracing and battons, Static Age.
Posted By: APSUS
Date Posted: 17 January 2026 at 10:02pm
Can I get away with using 3mm for the scoop and use expansion foam behind the scoop or would that be too weak? Could I use fiber glass on the scoop to make it stronger? Or just use 2 x 18mm birch ply panels angled.
Posted By: njw
Date Posted: 17 January 2026 at 11:39pm
 3mm is fine if you layer a few pieces on top of each other with plenty of glue inbetween, I've done lots of cabs like this, you can get away with 6mm if the radius isn't too tight. If you build around a former it makes for a super strong cabinet too.
Posted By: BadmanSS
Date Posted: 24 January 2026 at 2:49pm
I'm new to this and would love to build my own but don't know where to start.   I love this build but it looks intimidating.
Do you happen to have the measurements.   I like this and the golden horn design, but not sure what direction to go. Any help would be highly appreciated.   I don't mean to hijack your thread but would greatly appreciate your help because it seems like you were in the same boat as me recently.   I asked around for ppl to build for me but their prices are ridiculous.
