Yorkville AP6040 amps for sub
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=12984
Printed Date: 27 March 2026 at 6:53am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Yorkville AP6040 amps for sub
Posted By: levyte357
Subject: Yorkville AP6040 amps for sub
Date Posted: 27 November 2007 at 2:52pm
Anyone in UK used these. Heard conflicting stories, but many people like them
Yorkville: AP AP6040 - Amplifier - 2x 2000w @ 4 Ohms
Specifications
| Amplifier class | H |
| Continuous Average Power @ 8 Ohms BCD (Watts) | 1250 (x2) |
| Continuous Average Power @ 4 Ohms BCD (Watts) | 2000 (x2) |
| Continuous Average Power @ 2 Ohms BCD (Watts) | NA |
| Continuous Average Power Bridged BCD (Watts) | NA |
| Burst Average Power @ 8 Ohms BCD (Watts) | 2000 (x2) |
| Burst Average Power @ 4 Ohms BCD (Watts) | 3625 (x2) |
| Burst Average Power @ 2 Ohms BCD (Watts) | NA |
| Burst Average Power Bridged BCD (Watts) | NA |
| Frequency Response (Hz, +/- 1dB) | 20-20,000 |
| Hum and Noise (un / Aweighted -dB) | -103 / -106 |
| THD -1kHz- 4 OHMS | 0.01% |
| THD - 20Hz-20kHz, 4 Ohms | less than 0.1% |
| Slew Rate (V/uS) | 50 |
| Damping Factor (30 Hz - 400 Hz @ 8 Ohms) | 600 |
| Crosstalk (1kHz / 20Hz-20kHz) | -75 / -60 dB |
| Input Impedance - Bal/Unbal (Ohms) | 20,000/10,000 |
| Input Sensitivity (Vrms) For Full Power Out | 1.4 V |
| Max Voltage Gain (dB) | 41 |
| CMRR @ 60Hz (min/typ) | 48/56 dB |
| Stereo / Mono / Bridge (S/M/B) | S/M |
| Protection | DC,Load,Thermal |
| Limiter | Peak |
| High Pass Filter | 40Hz, 12dB Octave |
| Cooling | Dual Internal Fans |
| Cooling Path | Front to Rear |
| Fan Filter | 2x User Serviceable |
| Inputs - XLR | 2 |
| Inputs - 1/4" Jacks | 2 |
| Outputs - Speakon 4-pin | 2 |
| Outputs - Binding Post | 2 |
| Power Consumption (typ/max) | 1800/3000 Watts |
| Rack Spaces | 3 |
| Transformer Type | Toroidal |
| Exterior Finish | Baked, Black Painted |
| Dimensions (DWH /D fm ears, inches) | 19 x 18.5 x 25 x 17.6 |
| Dimensions (DWH /D fm ears, cm) | 48.3 x 47 x 13.3 x 44.7 |
| Weight (lbs / kg) | 66.1 / 30 |
------------- "Who am I? I'm the guy who does his job.. You must be the other guy".
Posted By: tweeter box
Date Posted: 27 November 2007 at 5:57pm
Looks like they cant be bridged???
------------- PRECISION SOUND SYSTEM.
Posted By: doober
Date Posted: 27 November 2007 at 6:18pm
Do you know of anywhere in the UK that sells them? Last time I looked I couldn't find any Yorkville dealers.
------------- Blahblahblah
Posted By: shagnasty
Date Posted: 27 November 2007 at 9:08pm
No 2 ohm drive so if it did bridge (you could try with a phase changer) it would only drive 8ohm in bridge anyway...
May use dual bridged modules to get that kinda power outta 30Kgs anyway!!!
(probably best to check with ameter BEFORE you try the pahse changer trick!!!)
Posted By: Jhodas
Date Posted: 27 November 2007 at 10:09pm
I can't get to their website...
------------- Until the Lions have their own historians, tales of hunting will always glorify the hunter.
Date Posted: 28 November 2007 at 12:32am
tweeter box wrote:
Looks like they cant be bridged??? |
Why would you want to bridge this ?
It can do 2kwpc@ 4ohms, thats 2x 8ohm 18's per channel @ approx 1kw each.
Job done.
Posted By: Tekasis
Date Posted: 26 July 2008 at 8:03pm
levyte357 wrote:
Anyone in UK used these. |
Only found one user on here who rates them!.
davidcordingley wrote:
if your in the states look at yorkville ap6040 these go quite well i have six of them and don,t need anymore power than that.four rows of eight to3s per channel.32 kilos.proper job...thats right 32 moses per channel.tidy.. |
http://www.speakerplans.com/forum/forum_posts.asp?TID=8918&PN=3 - http://www.speakerplans.com/forum/forum_posts.asp?TID=8918&PN=3
Any more ?
doober wrote:
Do you know of anywhere in the UK that sells them? Last time I looked I couldn't find any Yorkville dealers. |
Jhodas wrote:
I can't get to their website... |
http://www.yorkville.com/products.asp?id=19&cat=8&type=30 - http://www.yorkville.com/products.asp?id=19&cat=8&type=30
Check out their service manual...
http://www.yorkville.com/downloads/servman/smap6040.pdf - http://www.yorkville.com/downloads/servman/smap6040.pdf
Don't seem like many manufactures supply this type of detailed info!!!
------------- **Heavy Weight-Line**
Posted By: sKs01
Date Posted: 26 July 2008 at 8:19pm
people seem to nod their head towards yorkville in general on psw for this sort of aplication, as above i didnt know their were any uk dealers?
------------- You're a big man, but you're in bad shape. With me it's a full time job. Now behave yourself.
Posted By: doober
Date Posted: 27 July 2008 at 8:57pm
I emailed the uk distributor http://mirep.co.uk/ - http://mirep.co.uk/ to try and get a price and try a demo unit, but never got a reply.
I take Dave Cordingly's opinion highly, I used to do parties with him years ago, he was never happy with the bass until eyeballs were wobbling and people were struggling to breathe.
Posted By: powerplant
Date Posted: 08 March 2012 at 7:22am
Hello guys , looks like I am about to burst yorkville bag, the Ap 6040 is no miracle amp , just like crest 8001, qsc mx3000a , or EV p3000 operating at 2 ohm (also the ap 6020).
That is, 1400 watts, - 1600 watts , depending on either 20 - 20 hz @ 0.05 thd rating or 1 khz @ 1% thd Rating. All the amps are of the same class weighing in at 67 pounds same topology , Only way AP6040 can achieve the claimed 2000 watts of clean power is by driving only one channel at 4 ohms. These 4 ohm limit amps just run out of breath ( headroom) . The ap 6040 may sound just like the RMX 5050 or worst @ 4 ohms. bink's amp shoot out results were accurate. 1400 watts a 20 hz . just like crest 8001 2 ohm specs and 1700 watts @ 1 khz just like qsc mx3000 . therefore at clean real world power the ap 6040 is more like 1700 watts both channels driven , ( 3400 watts amp) . Ap 4040 follows the similar situation. Is similar to crown 2400 , and crest ca 9 . 2000 watts total real world clean power. Also AP 3400 . AB Test sounded same .
Date Posted: 08 March 2012 at 9:34am
powerplant wrote:
Hello guys , looks like I am about to burst yorkville bag, |
Since start of this thread, many amps have become available in UK that would smoke the Yorkville, @ 4 ohms stereo.
Was told years ago they are a nightmare to service/repair, lost interest there and then.
Posted By: MessyM2k8
Date Posted: 08 March 2012 at 10:12am
S DeXter on here had one. They are a nightmare to repair.
Posted By: Earplug
Date Posted: 08 March 2012 at 10:35am
Yes.
http://forum.speakerplans.com/help-needed-hk-vc-2400-yorkville-ap4040_topic61762_post615343.html?KW=yorkville#615343" rel="nofollow - http://forum.speakerplans.com/help-needed-hk-vc-2400-yorkville-ap4040_topic61762_post615343.html?KW=yorkville#615343
------------- Earplugs Are For Wimps!
Date Posted: 08 March 2012 at 12:32pm
Without a doubt, the Ap series Power Amps are very reliable and durable with straight forward analog circuitry. However, here in trinidad the semiconductor market has lost its way totally in inferior chinese replacement parts and compounded by the nonavailability of precision specialized parts making proper restoration impossible. I have one ap 6040 that i purchased broken with the inention to restore as a project but have not done so in consequence of the above . Customer support also leaves much to be desired. and finally, the general cost of yorkville amps.
To replace the two circuit boards Yorkville charging $900 us . I can buy a used PL 6.0 , B stock crest CC5500, Peavey cs 4080 , crown ma3600 , .
Posted By: kedwardsleisure
Date Posted: 08 March 2012 at 7:53pm
Yorkville stuff built like brick toilets and very comprehensive service manuals.
In the uk they are sold under the HK Audio brand which is distributed by John Hornby Skewes.
------------- Kevin
North Staffordshire
Posted By: C-Audiofreak
Date Posted: 08 January 2016 at 8:46am
If the yorkville amps are only available in the uk under an HK badge how come a few yorkville badged amps crop up on the second hand market ? Are these imported by individuals? I've thought about importing a couple from the states but get them converted to 240v once here as I'm told the transformers have dual tapped transformer so the primary side to 240 instead of 110 would be a simple procedure I just want an AP6040 and another 2020 if I can get them
Posted By: bass*en*mass
Date Posted: 08 January 2016 at 4:16pm
these come up often on European main continent.. just have a look around.. Shipping aint that bad normally.
Date Posted: 08 January 2016 at 4:22pm
Date Posted: 08 January 2016 at 4:34pm
for example.. shipping from Germany to uk up to 45kg is only 25€..
Date Posted: 08 January 2016 at 4:43pm
C-Audiofreak wrote:
If the yorkville amps are only available in the uk under an HK badge how come a few yorkville badged amps crop up on the second hand market ? Are these imported by individuals? I've thought about importing a couple from the states but get them converted to 240v once here as I'm told the transformers have dual tapped transformer so the primary side to 240 instead of 110 would be a simple procedure I just want an AP6040 and another 2020 if I can get them |
If you do that get the fans checked, if they are DC, you are fine, but if they are AC powered, swap them, a US AC will will run slower in the UK (60Hz vs 50Hz) and may not be able to cool the amp properly...
Date Posted: 09 January 2016 at 11:55am
If you want to import themn you'd be better getting them from a european source as they'll be the correct voltage and there wont be a hefty import duty. I'm pretty sure they use DC variable speed fans...they're not that backward! According to Yorkville there's a trade distributor in Le Bourget France called Major Audio.
And I didnt say they were ONLY available as HK in the UK..any dealer is free to import stuff from wherever they want. My post was 5 years ago and I don't even know if HK still use Yorkville.
edit: just checked with HK and yes they still do them, called the VX series.
------------- Kevin
North Staffordshire
Posted By: 70,s hero
Date Posted: 09 January 2016 at 6:02pm
I have 4 H.K / Yorkville amps the 2400's , class A/B , quite happy with them, repaired a power supply on one, parts avaliable in U.K. Heavy old school amp
------------- Top banana
Date Posted: 09 January 2016 at 6:58pm
Hi mate I wasn't questioning what you said I was just saying they are very few and far between secondhand in the uk and only ever seem to find the HK vx series of amp which are rebadged ap series yorkville amps
Date Posted: 12 January 2016 at 7:26pm
Those AP / VX are a bit of a tight packed amp but the quality is fantastic. Shame they arent a more popular brand here as I'm sure they'd be appreciated
------------- Kevin
North Staffordshire
Date Posted: 12 January 2016 at 8:14pm
The ap6040 that I'm after are 3u so prob not as tight packed as the AP4040
Posted By: ychole audio
Date Posted: 18 January 2016 at 10:06pm
How is the Yorkville ap6040 compared to Crown Macro-tech 5002vz? Same power on paper..
------------- I am ZERIEL'S dad!!!
Date Posted: 18 January 2016 at 10:43pm
Around £300 more expensive ychole
Date Posted: 18 January 2016 at 10:45pm
C-Audiofreak wrote:
Around £300 more expensive ychole |
So its only the price? They will perform in par then.
Date Posted: 18 January 2016 at 10:48pm
Prob I have not heard a 6040 but the 4040 sounds nice and never had the luxury of hearing the crown so can't pass comment the crown though is 2ohm capable whereas thi yorkville isn't
Posted By: Bigbass77
Date Posted: 11 September 2016 at 4:35am
I got one run 4 cerwin vega psx18b home use mainly deep deep bass can talk over it but jiggles your insides got eq n limiter
Posted By: White Noise
Date Posted: 11 September 2016 at 10:28am
We've had some ap6040's for a few years, great amps for the money !
used them mainly for sub and kick duty.
will power four pd1850's, XB18's or pd156's pretty well
I think Dave (Snafu sound system) imported them for his rig some years back...
