mounting v1000s in 1850s
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=13235
Printed Date: 27 March 2026 at 5:42am
Topic: mounting v1000s in 1850s
Posted By: antiG
Subject: mounting v1000s in 1850s
Date Posted: 10 December 2007 at 3:55pm
we just got 4x 1850s that were previously loaded with PD1850s
we have got 4x V1000s to stick in them - i was told they are the same fittings as 1850s but they are not
how am i going to do this? i think i can drill all the new holes with a 90 degree drill attachment, though maybe not the one right at the back - could i get away with just a woodscrew in that one?
how can i get the t nuts to stay in on the other side of the baffle? screw them in dead tight without the driver in place then a bit of epoxy?
please help, i am a bit stressed about this!!!
Confused
Posted By: Mark James
Date Posted: 10 December 2007 at 4:10pm
errrr, they must have changed the mounting then, or maybey the 1850 we used to use were fitted for both [quit possible] also i have seen drivers held into 1850 horns with just woodscrews, just make sure you take your time with any filling and drilling, take it youve got bioteks old horns? if so well done a nice set of horns you have there [well either way]
insert silly sentence here
Posted By: minaximal
Date Posted: 10 December 2007 at 4:11pm
hold the t nuts in place, with your hand through the baffle cutout and bolt them in with the bolts to 'get them home' from the drivers side, remove bolts place driver and bolt up.
i think you were thinking the wrong way around.
Subs + Barges = :)
http://www.metaacoustics.com" rel="nofollow - www.metaacoustics.com
Posted By: biotec
Date Posted: 10 December 2007 at 5:00pm
I've just worked out what the problem is and I'm very sorry for the confusion.
I told you that I'd lent my PD1850 drivers to a friend with looney bins as a temporary fix and that they'd fitted in the holes drilled for thre void driver with no problems. I deduced that the void driver has the same mounting arrangement. What I didn't know is that my friend had used the 8 concealed bolt holes on my PD1850's and not the 6 standard holes that I used in my cabinets.
It is worth checking whether the V18-1000 has 6 concealed bolt holes that allow it to be mounted in a cab designed for the PD1850. If it has them they will be visible from the back of the driver and you will have to puncture the gasket on the front to use them.
I'm very sorry for the confusion, I hope you can sort it out easily. If there's any way that I can help please let me know.
Posted By: Dom
Date Posted: 10 December 2007 at 7:29pm
The Void bolt pattern is the same as the PD concealed bolt pattern.
This means that you can fit a PD into a bin originally made for a Void, but not necessarily the other way round as most people will drill holes for the 6 hole pattern on the PD rather than the 8 concealed holes.
I've had to put fanes into bins originally drilled for PD before - I just redrilled the driver...  Clamp the two chassis together, drill through the PD and through the other chassis...  Easier than messing around with the baffle...  The chassis is only aluminium, dead easy to drill...
Posted By: antiG
Date Posted: 10 December 2007 at 11:27pm
hi thanks for the help, i think im a lot closer to getting sorted
got this handy tool from b+q for £30
plus i figured out my problem with t nuts is that ive been drilling out the holes to the size of the bolt and wondering why the t nut isnt digging in properly... doh!
anyway tom from white elephant is on the case, what a diamond for helping us out
Clap
Posted By: Jake_Fielder
Date Posted: 11 December 2007 at 8:02am
good luck man, sounds like a right pickle!
Posted By: WhiteElephantSounds
Date Posted: 14 December 2007 at 4:36pm
Sorted! What a proper hassle though, working through that little access panel is a grief at best. Would be much easier to re-drill the chassis but the old pd bolt spacing’s are further apart than the v1000s and would be right on the edge of the chassis.
Thanks for the Stella and I better hear them getting well and truly spanked tonight,
  Tom
Posted By: Powie4321
Date Posted: 13 May 2012 at 2:00pm
how did u sort this problem m8? any help wud be appreciated, just got sum an hav got the same problem
Posted By: PISSHEAD
Date Posted: 14 May 2012 at 6:59am
Why not use 4 clamps to hold speaker in place?
The 'drunken master' strikes again.
Date Posted: 14 May 2012 at 11:51am
yeh its an option i have thort but it is a bodge isnt it
