any designs that use a 21'' and gets 145db?
Category: Plans
Forum Name: Plan Requests
Forum Description: All plan requests here
URL: https://forum.speakerplans.com/forum_posts.asp?TID=14784
Printed Date: 26 March 2026 at 11:31pm
Topic: any designs that use a 21'' and gets 145db?
Posted By: Dre collier
Subject: any designs that use a 21'' and gets 145db?
Date Posted: 20 February 2008 at 4:37am
Hey guys I'm new to the forum. But I know alot about speakers and how to use them and their correct form. well anyway I was wondering if anybody knew any designs on a subwoofer that reach an output of 145 peak, I heard of bassmaxx and others doing this. I been thinking of using a 21'' from 18sound or beyma. but don't wanna do front loaded or scoop or bandpass. Please help!!!!!!!
PRIMETIME
Posted By: mykey
Date Posted: 20 February 2008 at 5:16am
you'd be looking at these type of dimensions I rekon
http://www.funktion-one.com/f221.htm -
http://www.funktion-one.com/f221.htm - http://www.funktion-one.com/f221.htm
......just all them hanging there like giant bananas.
Date Posted: 20 February 2008 at 5:26am
I look at that before but don't know the horn design. would you know what it is?
PRIMETIME
Posted By: H..
Date Posted: 20 February 2008 at 9:29am
Just call FK1 i'm sure their give out the design ....................................... NOT!
Posted By: TONY.A.S.S.
Date Posted: 20 February 2008 at 9:25pm
I guess the horn design on the f1 cabs hasn't really departed from the original Turbosound designs. There maybe cosmetic changes to the outside but in principal I would be surprised if they differed that much. Unless anyone knows anything different.
Posted By: tb_mike
Date Posted: 20 February 2008 at 11:01pm
No.Compare the horn mouth area,with a 21" speaker,the speaker is far smaller.It cant move enough air.
working backwards
145dB at 1metre
145 - 30dB(~1kw) = 115dB sensitivity 1watt 1metre
Note the sensitivity of typical 18 and 21" speakers,they are near 99dB at 100hz.At 50hz,its usually lower.
Date Posted: 21 February 2008 at 12:01am
but here in the US we dont have PD. All I can use is Beyma and 18sound 21's. so I'm leaning towards a basic folded horn design wit a 21'' most likely 18sound. Anyone ever done a folded horn design wit a 21''?
PRIMETIME
Posted By: tb_mike
Date Posted: 21 February 2008 at 7:30am
Well 18sound is just as good.
Posted By: ceharden
Date Posted: 21 February 2008 at 12:09pm
There is often a huge price premium on 21" drivers over 18".  It can often work out better just to use two 18" rather than one 21".
Posted By: jethrocker
Date Posted: 21 February 2008 at 3:45pm
Or wouldn't 2x 15" give you about the same SD as 1 x 21"...?
Posted By: Mark James
Date Posted: 21 February 2008 at 4:09pm
tbh i dont see any point in 21s other than " mines bigger" but they must die easily???
cant imagine a 21" being very efficient at all???
2x15 would be more sensible,
145db is going to require a horn im sure, and a 21" loaded horn is just going to rip itself apart within 5 minute surely???
there are turbo 21" band pass horn plans about but i cant seem to see the point with them to be honest, a 21" wont have much kick and wont be as effective at going low as a similar priced stack of 18s....
insert silly sentence here
Posted By: VECTORDJ
Date Posted: 21 February 2008 at 4:12pm
Hi Dre, 21" woofers are rated from 800 watts to 1000 watts AES ( a good real world rating) ( the 18sound is rated at 1500 watts but if you read the fine print it is in the 750-800 AES range). This would allow up to aprox. 135 dB at full power at 1/m in a large folded horn bin. To get to 145 dB with one woofer would mean close to 4000 watts. Your woofer would have a short life. Four 21" in large horn bins in a stack could reach 145 dB. The way to reach extreme spl is with the use of a lot of bins.  Rog had posted photos of about 20 bins he used for a show about year ago. He stated he got strong response down to below 20Hz with super high output. This is the way to go.  VECTORDJ / VECTORSONICS
Posted By: mobiele eenheid
Date Posted: 21 February 2008 at 4:17pm
Yes 2x15", 2x18" is more like a 24", talking Sd.
Quote a subwoofer that reach an output of 145 peak
Forget peak, it's often nothing more than a theoretical 6-10 dB above continues, so 139 dB continues. So 109 dB/W/m, which is still an incredible lot in the bass range in half space. Either some sort of peak from a single enclosure somewhere high up above it's usable bandwidth or from a multiple of cabinets (or a single in 1/4 or 1/8 space).
Aiming at something like ~104 dB/W/m @ 100 Hz (1/2 space) would be far more realistic.
Date Posted: 22 February 2008 at 2:51am
Okay I see wat you guys are saying but wat if I wanted to do something like bassmaxx's deuce, it reaches 145 peak!! but again he is using B&C 12''' is there any better 12''s than B&C????
PRIMETIME
Posted By: SteveAATW
Date Posted: 22 February 2008 at 3:10am
The F221 works well and is earth shatteringly loud, but only because of the driver I suspect and you can't buy them - dual voice coil, custom OEM job and without the neo magnets the cab would be virtually unmoveable. It's a very different sound to the TSW-721's of old. If you tried to copy the design with an off the shelf 21 I suspect the loading would rip the driver to bits quite quickly.
Upper bass is good from them but there are limits to how fast it can go obviously and I'd be inclined to have a few twin 18's or twin 15's on top of them as well
Posted By: tb_mike
Date Posted: 22 February 2008 at 8:19am
Yeh the bassmaxx goes loud.It was measured at a sub shoot out,but it didnt go low.
B&C 18sound all similar good quality.
You can get 'super woofers'but they are expensive and are usually used for car audio/ extreme home theatre
Posted By: BenW8C
Date Posted: 12 June 2019 at 10:35am
I'm aware of the fact that this threat is more than 10 years old, but I'm really curious about the difference you are talking about between F221 and TSW721. I'm trying to find either of them, how do you like both?
