G subbbbb - advice
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=1579
Printed Date: 26 March 2026 at 10:56pm
Topic: G subbbbb - advice
Posted By: ashleyb
Subject: G subbbbb - advice
Date Posted: 21 March 2005 at 2:13pm
ok so first of all ive never done this before i just wanted a mad sound system for partys n stuff. i copyed the plans for g sub and the box is ready :) but i have just a couple of questions, if u any of u can help me out?
1: say the box's volume is slightly out say one of the sides is a cm too much, will it make a differnce? and how?
2: im not rich, what happens if i dont use the speakers it says to use and i use Eminence Kappa 18 500W 18" Driver  instead?
3. what just happened to my font?
4. what power amp would u reccomend i use? considering im on a tight budget.
if ppl could help me out n gimme some advice itd be great
thanks
ash
Posted By: Andrew
Date Posted: 21 March 2005 at 3:36pm
A small change in volume shouldn't matter too much.  If the sides are no longer parallel, then that is a bonus, as it will reduce standing waves.
Different drivers can make a big difference, not always in a positive way.
Depends on the number of people.  Some folks buy really big amplifiers to power a number of subs.  I tend to use amps as I can lift them OK.  A smaller amp can always be used for lesser duties later on, like mid-range, for instance.
Posted By: Dom
Date Posted: 21 March 2005 at 4:14pm
Buy the PD's.
It's cheaper in the long run as you won't have to recone them...  The box was design around them..
If you're really really on a budget, buy a behringrer EP2500.  They are less than £200 and if you run it bridged it will give you 2.4k into your sub...
Personally I'd buy the PD's and cut corners on the amp by buying a behringer.
Posted By: Jez_Ultra
Date Posted: 29 March 2005 at 10:42am
When I lasted asked Pro Audio Parts for a price on a pair of PD186's they quoted me £440 delivered.  The RCF L18P300 are cheaper price, and will not suffer from the slight power dip at 50Hz.
