X1 pole mount to X15
Category: Plans
Forum Name: X1
Forum Description: Discussion / Questions about the X1 sub
URL: https://forum.speakerplans.com/forum_posts.asp?TID=1583
Printed Date: 18 April 2024 at 9:00am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: X1 pole mount to X15
Posted By: Hobbyist2004
Subject: X1 pole mount to X15
Date Posted: 21 March 2005 at 3:34pm
I'm using one X1 and one X15 per side right now, and I'd like to put a
recessed pole mount adaptor on the X1. Would this hurt the X1's
performance in any way? Also,
would there be a weight issue with the X15?
Thanks
Posted By: norty303
Date Posted: 21 March 2005 at 3:55pm
I can't see it being a problem as far as performance is concerned. Just make sure you get the deep top hats as the depth of the port on the X15 means they're a bit front heavy where you have to mount the top hat
------------- My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
Date Posted: 21 March 2005 at 4:20pm
thanks norty, I wasn't aware of the X15 port issue. If I only had time
to build 2 additional X1's or maybe some HD15's I wouldn't need the
pole mounts. My only other option is that I do have 1 tripod, so I
could purchase another and set the X1's on the inside of the tripod
with the X15's on top. I just wasn't sure if this would cause
sound issues, but I think all the pole hardware with equal the price of
an Ultimate tripod.
Posted By: Timber_MG
Date Posted: 22 March 2005 at 5:22am
I have built the cab and the port doesn't interfere with a good mouting of the top hat. I could place the top hat above the centre of gravity and don't use a deep top hat. In actual fact I would have preferred placing the top hat back a bit to give the cab a slight tendancy to lean forward.
