Efficient BPH Idea
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=16074
Printed Date: 26 March 2026 at 10:56pm
Topic: Efficient BPH Idea
Posted By: Hugo Biermann
Subject: Efficient BPH Idea
Date Posted: 09 April 2008 at 6:52pm
Another F1/Turbo Style BPH, which I've been playing with. I'm going the low power, efficient woofer route. Thinking about budget. It should make some noise in ya average venue.
4 should get down to mid 40's
Have a look if ya want.
http://download142.mediafire.com/py2pymg1hbsg/jngd9gjjryn/WN118S.pdf - Click here to start
Posted By: Jake_Fielder
Date Posted: 09 April 2008 at 11:08pm
Nice, have you got any plots for that?
Posted By: Mark James
Date Posted: 09 April 2008 at 11:09pm
eer apparantly file does not start with %pdf
insert silly sentence here
Date Posted: 09 April 2008 at 11:15pm
jake did the pdf open for you?? I think I have a pc issue Im about to find out about!
Date Posted: 09 April 2008 at 11:16pm
I opened it, should i put it up as a jpeg?
here they are:
http://i53.photobucket.com/albums/g49/Jake_fielder/threebeedesign.jpg - http://i53.photobucket.com/albums/g49/Jake_fielder/threebeedesign.jpg
http://i53.photobucket.com/albums/g49/Jake_fielder/threebeedesign2.jpg - http://i53.photobucket.com/albums/g49/Jake_fielder/threebeedesign2.jpg
Date Posted: 09 April 2008 at 11:20pm
this blooming pc,!!! wont open most things. if you can mate, alough it wouldnt shock me if this pc couldnt recognise a jpeg, [im joking its just a very frustrating machine and I swear its possesed!!!]
markk
Date Posted: 09 April 2008 at 11:34pm
that extra bit of wood just above the corner... doesnt that seal the horn?? [I know it doesnt otherwise wher would the sound come from lol]
Posted By: Rengade Project
Date Posted: 10 April 2008 at 1:22am
Once again three-bee gives us the good stuff!
MUSIC SWEET,www.myspace.com/renegadeproject
Posted By: cravings
Date Posted: 10 April 2008 at 1:31am
markk... i think you're slightly misinterpreting the plan.. if i'm not misinterpreting you that is... the line with 550 written through it is just indicating the length of the brace that goes sort of vertically / diagonally from the center of the base, to the back panel... if you get me?
Posted By: H..
Date Posted: 10 April 2008 at 2:27am
Double the center brace (550) and move each one off to the side a bit - would make it easier to load 'tall' drivers into the box.... back of the magnet would sit between the braces
What 18" are you thinking of using ?
Posted By: heinrich
Date Posted: 10 April 2008 at 2:40am
I'd also love to know how the C18-650EL respond inside this horn.........( the best available off the shelf driver I could acquire)..
....that, if it fits in.......
.....power is nothing without control....
Posted By: mylesound
Date Posted: 10 April 2008 at 3:38am
wait to me it seems as if it is completely sealed off.
i must be misunderstanding it
Posted By: heinrich
Date Posted: 10 April 2008 at 4:00am
to understand fully the plan.....print em.....that would make things very clear.....
Posted By: Tony Insanity
Date Posted: 10 April 2008 at 10:00pm
There are 3 lines parallel to each other, the 2 bottom ones are unbroken and show the brace, the other is broken and has the dimension '550' written through it.
The line with the '550' dim is just there to show the dimension and is not a part of the brace.
Just take the line with the '550' out of the plan and all will become clearer.....I had to look twice before I realised! Smile
.....you might also look for her companion, a large Chinese rabbit, who is easy to spot since he is only standing on his hind feet in the shade of a cinnamon tree...
Date Posted: 10 April 2008 at 11:00pm
Its for P-Audio WN-18S
The C18-650EL will have the same response. I think it will be a SQUEEZE though....
Hope this pic will help...
http://imageshack.us/?x=my6&myref=http://www.imageshack.us/">img265/9892/82425651wu8.jpg
www.aggressiveaudio.co.za
Posted By: heinrich
Date Posted: 11 April 2008 at 5:40am
Wink
Posted By: el_dj
Date Posted: 11 April 2008 at 7:36pm
hi.... i know most people are gonna chop me for this..
but this could be my solution
i have the possibility to buy alot of cerwin vegas es 189's...
how would this speaker behave in this cab... compared to the b36 cab??
thank for the reply's
Old twat, with an interest in light & sound
Posted By: darkmatter
Date Posted: 12 April 2008 at 2:04pm
took me a good while to work out the 550 piece was a brace too!
after seeing the pics it makes me wish you could get the horns for comp drivers in a variety of coloursSmile
Posted By: boycey
Date Posted: 12 April 2008 at 8:56pm
is there something intrinsically wrong with painting them?
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
Posted By: heinrich
Date Posted: 22 April 2008 at 4:34am
@three:
what about a 15 inch design.......with c15-el, may be a variant of HD15?Embarrassed
Posted By: pk1964
Date Posted: 30 April 2008 at 11:20pm
what a fine cab bank hol weekend ill build some thinking fane or pd drivers which best?
Posted By: guillaume03
Date Posted: 12 May 2008 at 2:30pm
is it possible to have  plans for  a two 18 drivers ? make a 218 instead of 118, is this cab is better than a USB? It really looks like one 1/2 f1 f218, the dimensions are really the same (and i really love the f 218, but very expensive)!I have 4 p audio c 18 650 el and I will start to build 2 cabs for them, I was planing for usb, but this cab seems to be very good too, isn't it?does the c 18 650 will better work in this cab?
sorry if my english is bad or if the answer are in the topic, but i'm french and i don't understand every words...
Date Posted: 13 May 2008 at 10:02am
build two usb's purely because the response is at least partialy known. then get some cheap mdf and knock a few of these up as you can then revert back to the old cabs if theese dont do what you want. either would be god though.
Posted By: rich21
Date Posted: 13 May 2008 at 12:24pm
umm looks just like half of one of my 218 (turbo/f1 festival bin)
 a little sketch i did http://www.imagehosting.gr/upload4/out.php/i70347_218.jpg - http://www.imagehosting.gr/upload4/out.php/i70347_218.jpg
and posted here http://www.speakerplans.com/forum/forum_posts.asp?TID=14310&KW=&PID=137922#137922 - http://www.speakerplans.com/forum/forum_posts.asp?TID=14310&KW=&PID=137922#137922
Date Posted: 13 May 2008 at 9:46pm
this cab has the same outer dimensions as the F1/Turbo cabs. The rest was drawn up inside after playing around with Hornresp.
Date Posted: 13 May 2008 at 10:42pm
awesome!
a double would be silly!
alough 6 doubles would be sillier still!
Posted By: rich21
Date Posted: 13 May 2008 at 11:02pm
does that make 12 doubles crazy ?
Date Posted: 14 May 2008 at 4:05am
6 usb or 6 double like the single of three bee?wich is best for my p audio c 18 650 el?
USB or the model of three bee but in double?(i don't want single 18 cabs)
