Eminence Killomax Pro 18 Plan
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=1670
Printed Date: 26 March 2026 at 11:31pm
Topic: Eminence Killomax Pro 18 Plan
Posted By: horatioa
Subject: Eminence Killomax Pro 18 Plan
Date Posted: 05 April 2005 at 12:31am
I Have A Lot Of These Speakers And I'm Looking A Good Design That Could Suit These Speaker, But I Don't Want ATall Box. Maxinum Hight 40-42" And Need To Play Very Big And Tight Bass
Spinners Choice
Posted By: richg101
Date Posted: 11 April 2005 at 10:31am
hi there.
been reading your post and was reminded about how much hell kilomaxs gave me. they just didnt give me any proper output at all.
try and swap them for omegas or sigmas or better still look at pd.
the kilomax is so inefficient and slow that you will wish you did not build boxes for them. i did
i use pd 188's now and they are wicked. reasonable priced and very hard hitting.
you will get a lot for the kilomaxs if you aim selling them at car audio people who dont understand efficiency and just care about power ratings. ebay?
Posted By: JJones
Date Posted: 12 April 2005 at 11:28am
I don't know if I'm qualified, but I'm working my way threw a similar situation.  I've got some Peavey "Low Riders" I want to use and I'm too "thick" to listen to all the people telling me not to.
I'm starting to build the boxes this week.  The Hornresp charts look reasonable for the Peavey's and I plugged in the Kilomax TS and it seems to perform (although full power would have the cone jump out of the frame.  Power reduction to about 800W).
If your interested, I'll give you a copy of the rough drawing (use at your own risk).  I'm no expert, but I don't quit easy.
Jim
What?????
Posted By: freddyi
Date Posted: 12 April 2005 at 11:41pm
being even more stubborn - I might build one (in case it stinks on ice) sturdy but light Karlson  resonator box for the Kilo and let things sail  - "might " obtain some gain in kick region and somewhat better control than reflex but not get "deep" bass
K could be made in between the sizes of original 1952 plan
http://home.earthlink.net/%7Ebuddhaboy2/K15.PNG - http://home.earthlink.net/~buddhaboy2/K15.PNG
and Gauss 5181 incarnation
http://home.earthlink.net/%7Ebuddhaboy2/GK - http://home.earthlink.net/~buddhaboy2/GK
not sure now much extension 305l 5181 might have over ~55Hz corner for 225l  box  - need to try one in this size range
typical response with 18" in 225l K http://home.earthlink.net/%7Ebuddhaboy2/shelf.jpg - http://home.earthlink.net/~buddhaboy2/shelf.jpg
should be someone with dough lusting for those sexy sausage-grinder heatsinks
wonder how PV18 will fare?  - Q and Le are lower than kilo- got s**tload of overhang
Posted By: LunchieTey
Date Posted: 13 April 2005 at 8:08am
Just took the time to plot some boxes on bassbox pro 6. The Kilomax is only suited to rather large (over 200ltr) ported boxes(as many have said before). I found a happy medium at 250litres tuned to 40hz. This design netted 127db continuous output at 800 watts(60-120hz) so long as you use it with a 35hz HPF. It won't take anywhere near it's 1250 watt maximum unless you put it in a really small box(for it at least!) and tune quite high with an equally high HPF. My 6th order bandpass use much cheaper drivers(p-audio p180/2241) and make 129db from 600 watts(same frequency limit) but only take up 200ltrs. Even eminence say it needs 250-400lts and is NOT suitable for anything else. At least if you were to run them with 'only' 800wrms,thermal compression should be well in check
Speaker addict
Date Posted: 13 April 2005 at 8:11am
Oh and as far as dimensions go,size it yourself,it's only volume that matters and brace it well(use other plans as a guide as to how to brace etc) Also make sure your port area is sufficient,I used shelf ports cause they act as convenient braces too!(one of em is 440mm long)
The FAQ section has good tips on which wood to use etc. Hope that helps
Speaker addict
Posted By: Tony Wilkes
Date Posted: 13 April 2005 at 11:53am
I have offered to draw some plans for the thread starter and was using a box of 300L tuned to 35 hz and using a couple of 6" dia vents. They still exceed xmax at 40 hz even with only 600 watts but with this driver everything is a compromise.
Tony
Posted By: Ultramars
Date Posted: 19 April 2005 at 6:50pm
i'm using kilomax 18 in the C-sub design, driven by  electrovoice P2000 bridge 4 ohm, and the result is very nice, i'd say. at least, it doesn't seem slow to me, just a good result compared to the price of theses drivers ! i'll make some of theses box for ome PD1850, we'll talk about it again, maybe ;)
Posted By: Insomnia
Date Posted: 07 September 2005 at 10:45am
hello mate,
Just read you post-
I dont know myself as i have never had any but- I know people who have been putting kilomax's in the ev t18 design reverse folded bass bins and have had quite good results-used in multiples
There is a establisthed company in the Uk- that will sell u the t18's already loaded with kilomax's- so they must have a half decent output!!
I realy dont know-but its worth a try
Posted By: tb_mike
Date Posted: 11 September 2005 at 9:49pm
Oh dear. No wonder people say its slow on a reflex box.When Qts> 0.4 things start to get bad for reflex size wise.The right basshorn is a possibility. If you want a portable box id sell this underdamped woofer.
Qts : 0.56
Posted By: _djk_
Date Posted: 13 September 2005 at 6:47am
If you already have a bunch of these things I would consider the rear loaded horn design (scoops).
They will also work OK in a 4th order bandpass, but are only useable from about 50hz~110hz (but they will be 104dB vs 96dB for a standard vented design). The bandpass box would have to be about W30" X H30" X D35" to work right.
djk
Posted By: Tom Umney
Date Posted: 03 October 2005 at 10:31pm
No the kilomax would sound crap in scoops.
I'd say the C-sub where it says you can use them as one of the drivers to choose from.
Posted By: tb_mike
Date Posted: 03 October 2005 at 11:09pm
Toxic: ported/bp6 will be real boomy with this woofer. Thiele,or some one like him reccomended Qts<0.45 or something. Maybe he wants boom tho ;-)
Date Posted: 04 October 2005 at 11:50pm
Well Rog on those plans says the Eminence Kilomax can be used in the C-sub.
Although generally Eminence Kilomax is pretty unsuitable for most boxes.
Posted By: _djk_
Date Posted: 05 October 2005 at 4:44am
That driver will sound much better in a BP4 than a BP6A.
djk
Posted By: Lasse Lukkari
Date Posted: 05 October 2005 at 8:06am
Rog also said that he doesn't recommend it anymore.
Posted By: horatioa
Date Posted: 26 March 2006 at 12:13am
I Think They Would Work Very Well In The EV T18 Design With A Little Modification, Can Some One Share Their Technical Expertise, Another Thing Electro Voice Had Modified The T18 To The SB180.
Spinners Choice
Posted By: horatioa
Date Posted: 26 March 2006 at 12:22am
What Is The BP4
Spinners Choice
Posted By: _djk_
Date Posted: 26 March 2006 at 1:48am
A 4th order bandpass enclosure (BP4). Similar to the 'C' sub shown above, but with only one chamber ported.
The 'C' sub is a BP6A, a BP6B has a port from one chamber to the other, and then one port to the outside.
All three types are sensitive to the T/S parameters of the drivers, and no substitutes should be made without checking in a box modeling program.
The Kilomax 18 does not model well in a BP6A.
djk
Posted By: Insomnia
Date Posted: 26 March 2006 at 9:05am
dont bother putting kilomax's in T18's mate
Posted By: mobiele eenheid
Date Posted: 31 March 2006 at 10:12am
I did model Kilomax in 6th order BP(A) (iirc something like 120 ltr tuned to 45 Hz and 80 ltr to 75 Hz) it did look pretty impressive SPL-wise and powerhandling, just horrible groupdelay.
My guess would be that it will sound much better if the second chamber is around 40 ltr tuned to 200 -300 Hz. Would behave like BP6/BR-hybride. Less SPL but much less groupdelay and less peaky aswell. Also less distortion from cone movement.
Wkr Johan
Posted By: _djk_
Date Posted: 31 March 2006 at 10:01pm
The group delay is simply a function of the frequency response.
A simple sealed box with a low-pass filter of the same roll-off rate and same frequency has the same group delay.
djk
