B&C’s 18NW100 compadable with the 1850hor
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=1747
Printed Date: 27 March 2026 at 11:02am
Topic: B&C’s 18NW100 compadable with the 1850hor
Posted By: Sencesync
Subject: B&C’s 18NW100 compadable with the 1850hor
Date Posted: 19 April 2005 at 8:11pm
id like to get a couple pairs of B&C's 18NW100 woofers. but as i look at thier stats, thier EBP is 121 and thier BL is at 28, is that ok to use for the 1850 horn, would i have better sound with the 186horn?
Posted By: tb_mike
Date Posted: 28 April 2005 at 12:25am
T/s specs? How do they compare to the original driver for this horn?
Posted By: hepek
Date Posted: 22 May 2005 at 11:43am
I am allso planing to built a pair of horn with b&c but 18ps100. and i have a same problem like you. i don't know which horn to use.
Posted By: tb_mike
Date Posted: 06 June 2005 at 4:50am
If the t/s parameters are rather similar to the one intended for the horn,it should work.
Posted By: boab
Date Posted: 20 June 2005 at 12:33pm
Build a 186 horn with a pzb100 they are much more suited. (As
recomended by Rog)
The ps100's are for slow and low directs. check the Bls oot.
boab
Posted By: ceharden
Date Posted: 20 June 2005 at 4:04pm
I have heard there are thermal power compression problems with using Neo drivers such as 18NW100 in small sealed cabinets such as the rear chambers on horns as there is a limited amount of air to cool the voice coil and magnet.  I'm assuming that drivers with large ferrite or ceramic magnets have a greater mass to absorb the heat and thus the increase in temperature is slower.  I'd be interested if anyone knows the truth on this.
From the investigation I've done, the 18NW100 looks like a great driver, but maybe not suited to horn boxes, been considering it for the X1 or variant perhaps.  Seems that PD seem to have the horn loading drivers corner covered tho...
Posted By: hepek
Date Posted: 22 June 2005 at 5:21am
hi there,
what do you think of building horn 186 with B&C 18ps76. it has high sensitivity 99db, BL26 and EBP 137  (because of high resonant frecvency 39hz).  Only problem is voice coil of 3 inch. but if i don't need too mouch power, what do you think should it work?
