Amp ratings
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=18056
Printed Date: 27 March 2026 at 4:55am
Topic: Amp ratings
Posted By: Deadbeat
Subject: Amp ratings
Date Posted: 06 July 2008 at 4:54am
Hello Gentlemen.
These probably have been posted before...but
inspired by a recent topic, i've collated some links for your perusal:
Bink's 2004 PSW Amp shootout measurements:
http://srforums.prosoundweb.com/index.php/mv/msg/884/5658/0/ - http://srforums.prosoundweb.com/index.php/mv/msg/884/5658/0/
Bink's 2004 PSW Amp shootout ABX results:
http://www.live-audio.com/messages/98632.html - http://www.live-audio.com/messages/98632.html
Micheal Roger's oldschool vs newschool amp shootout:
http://srforums.prosoundweb.com/index.php/mv/msg/25215/0/0/0/ - http://srforums.prosoundweb.com/index.php/mv/msg/25215/0/0/0/
PL380 v IT8000 v 9001 Pro v PLX3402 Smackdown:
http://srforums.prosoundweb.com/index.php/m/229083/0/?srch=IT8000#msg_229083 - http://srforums.prosoundweb.com/index.php/m/229083/0/?srch=IT8000#msg_229083
More amp measurements:
http://www.avsforum.com/avs-vb/showthread.php?t=855865&page=1&pp=30 - http://www.avsforum.com/avs-vb/showthread.php?t=855865&page=1&pp=30
Away on extended leave.
Posted By: andyamp
Date Posted: 06 July 2008 at 9:11am
Hi Deadbeat
i am glad to see there are people out there that publish some of the real outputs of amplifiers.LOL
nothing new hereLOL
http://www.matrixamplification.com/ - http://www.matrixamplification.com/
Posted By: levyte357
Date Posted: 06 July 2008 at 12:00pm
Originally posted by Deadbeat Deadbeat wrote:
Hello Gentlemen.
If I'm going to use an amp for sub, I dont see the point of testing and measuring burst outputs, and O/P  power at 100Hz +. Confused
Because, thats not how I'm going to use it...
Posted By: Deadbeat
Date Posted: 06 July 2008 at 3:31pm
20-20K readings is what I'm usually interested in:
All the rest are for those men over there with their power hungry midtops.
Also, it can be for completeness - you can see the difference in power at different frequencies, and compare that to the rated power.
I forgot to add, Bink's test was done with SPL stuff (TD1, runts, bdeap) and they also utilised a 2722 audio analyser thing.
The ABX test was run using an ABX switch for quick comparison (like GiveorTake's idea on the other forum).
Posted By: richard stringer
Date Posted: 06 July 2008 at 11:45pm
Whats the best way to tes an amplifier's REAL power output at 20hz-20khz then? Because i'd love to see some real life figures so I knwo how much power i'd REALLY be putting into my subs. Oh by the way 1 guy said a 20amp circuit would starve a Crown MA5000, so what kind of power supply would I need to properly run a Crown XTI4000?
Posted By: andyamp
Date Posted: 06 July 2008 at 11:51pm
1.2kw   5amps
Date Posted: 06 July 2008 at 11:56pm
Hey andy? Does you mean a Crown XTI4000 would use 1,200watts of power and need 5 amp supply?
Posted By: andyamp
Date Posted: 07 July 2008 at 7:19am
only when on a test bench running sine wave 20hz to 20khz above 10 seconds.
Posted By: Deadbeat
Date Posted: 07 July 2008 at 7:24am
Then VTEC kicks in, yo! Wink
Couldn't resist.
