Martin WLX/WMX
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=18252
Printed Date: 26 March 2026 at 6:55pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Martin WLX/WMX
Posted By: SteveAATW
Subject: Martin WLX/WMX
Date Posted: 13 July 2008 at 6:59pm
No not asking for the plan
But, given its based on the WSX we can assume long folded horn, but the reflex part interests me. Stasys X has long port path to give the LF extension, but the WLX and WMX just seem to port straight into the rear chamber with fairly short ports. Are they working on a different principle?
Posted By: ceharden
Date Posted: 14 July 2008 at 2:14am
I've had a chance to poke around a WMX. Couldn't take the driver out to see the throat arrangement but it's probably a typical Martin letterbox. Driver faces the corner of the cab but the horn path J shaped.
Roughly half the cab is horn, half is reflex rear chamber.
Date Posted: 14 July 2008 at 2:20am
Ah, so presume from that it does not have the same number of folds in the horn path as the WSX?
More importantly, did you hear it in anger and what was the verdict?
Posted By: ceharden
Date Posted: 14 July 2008 at 10:02am
Only one fold, just at the start. The horn length on the WMX is the depth of the box plus the short U-turn.
I haven't heard much of them in use, only one per side for a wedding but they seemed to do what they say on the tin! Pretty good for a single box.
Oh, and the driver appears to be a B&C, probably an 18PZB100.
Date Posted: 14 July 2008 at 11:05am
£3k subs at a wedding
Forgive my probable ignorance, didn't much sleep last night, is the U turn also the fold like the first one below (ie effectively a ported band pass horn), or is there another fold before it gets to the bend like the second pic. Also, someone once posted some internal shots of the WLX and it had some small triangular ports on the baffle into the horn throat, did you spot any on the WMX or is it just the ports to the cab front? And Clearly I own at visio
Posted By: ceharden
Date Posted: 14 July 2008 at 11:33am
Ah, actually it wasn't a wedding, it was a band who when I usually see them they're doing Jewish functions. It was actually a corporate do but same setup....
Sorry, I didn't explain well. The driver faces the other corner and is right up to the rear of the cab. Bit like a HD15 but with the baffle at more of an angle.
Posted By: Deadbeat
Date Posted: 14 July 2008 at 11:36am
WLX, anybody?
------------- Away on extended leave.
Posted By: TDA-Audio
Date Posted: 14 July 2008 at 12:34pm
this WLX...
------------- horns plans http://photofile.ru/users/tda-audio/
Date Posted: 14 July 2008 at 1:27pm
Where's the actual driver baffle on those markings?
Posted By: ceharden
Date Posted: 14 July 2008 at 2:42pm
It's the thick panel on the lower right hand side. Fires through a letterbox, round and out. Very similar to my ported horns really.
Tempted to give an 18" version a go, would be the same size as my twin 18" reflex boxes.
Date Posted: 14 July 2008 at 2:48pm
Ah sorry, brain fart - I presume the gap between the baffle and the horn path wall is the port from the chamber into the horn throat, didn't realise it was all the way through though, thought it was a cut out in each corner of the baffle
These actually look like a relatively simple build compared to say the WSX, granted not as simple as a reflex but not loads of stupid angle cuts
Posted By: ceharden
Date Posted: 14 July 2008 at 2:54pm
That gap is probably just a way of making use of as much space as possible for the rear chamber.
Reflex boxes can get pretty complicated when you start refining the design. These would be nice and easy to build as you say.
Date Posted: 14 July 2008 at 3:11pm
I think i'm getting mixed up on there as to whats panel and whats brace
TDA - is the rear chamber ported into the throat as well as the two ports to the outside world?
Will plastic pipe type ports cut it in these cabs or will it need something a bit more sturdy making from wood?
Posted By: ceharden
Date Posted: 14 July 2008 at 3:49pm
I'd just make it a shelf port....
They're only ported to the outside as far as I know....
Posted By: mykey
Date Posted: 14 July 2008 at 3:52pm
I wonder if Martin's had a butchers at the XXL
------------- ......just all them hanging there like giant bananas.
Date Posted: 14 July 2008 at 4:11pm
I could be going mad but I think a while ago someone posted some pictures taken of the insides of the WLX on here, can't for the life of me find the thread though
Posted By: MarjanM
Date Posted: 14 July 2008 at 4:44pm
And where is the port?
------------- Marjan Milosevic MM-Acoustics www.mm-acoustics.com https://www.facebook.com/pages/MM-Acoustics/608901282527713
Posted By: mykey
Date Posted: 14 July 2008 at 4:57pm
on the front of the cab near where it says TDA-audio.com
Posted By: MarjanM
Date Posted: 14 July 2008 at 5:05pm
Do you tune the box like a normal reflex box. The back chamber that is.
Date Posted: 14 July 2008 at 5:17pm
Posted By: MarjanM
Date Posted: 14 July 2008 at 5:22pm
Yeah, yeah, i know the box. Just no one bothered to draw the ports
Date Posted: 14 July 2008 at 6:04pm
remove front panel
Posted By: MarjanM
Date Posted: 14 July 2008 at 8:12pm
So which one sounds better? WSX or these?
Posted By: ceharden
Date Posted: 14 July 2008 at 10:31pm
Are there any of the original B&C markings on that driver, is it the 18PZB100 as I suspected?
Posted By: richters
Date Posted: 14 July 2008 at 10:52pm
Looking at the picture, I would say that's not 18pzb100 because of the 18tbx100 style cone. It's close to the old model from b&c 18tbx46 (looking at the alu frame), maybe it is an oem version of that.
Date Posted: 14 July 2008 at 11:51pm
Ok found the pic i was on about. WMX is 4 ports, 2 internal, 2 external. WLX is 2 external ports only. Which I think makes these cabs quite different beasts. Looking at the WMX a bit closer, its beginning to remind me of the Nexo CD18 a little (obv without the cardiod rear driver)
So....
WLX is a ported horn
WMX is some weird horn/reflex/bandpass hybrid
Looking at Jeff Nine Bars test vid on youtube though if the piece of paper test is anything to go by then the WMX shifts some serious air low down. As does the Nexo, but then the Nexo can't go that high without wallowing. Wonder if Jeff can cast some light on what they sound like in comparison to other cabs (X1 would be the obvious one that springs to mind)
Posted By: ceharden
Date Posted: 15 July 2008 at 12:12am
Are you sure the WMX has internal ports? I couldn't see any when I was looking through the ports into the rear chamber. The Martin website claims it's the same type of loading for both cabs and I've only ever seen ports to the outside on their cabs.
Can you show us the picture?
Date Posted: 15 July 2008 at 12:27am
Sure, courtesy of TDA's photofiles:
Unless there's something going on behind the baffle which boxes it all off and encloses the throat there's two triangular ports either side at the bottom - does that look similar to what you saw?
Date Posted: 15 July 2008 at 12:29am
Second Pic:
Posted By: ceharden
Date Posted: 15 July 2008 at 12:47am
I would say that like we were discussing ref. the WLX, there is a letterbox throat and those triangular cut-outs are just to include the otherwise wasted space in the rear chamber.
Posted By: mykey
Date Posted: 15 July 2008 at 6:10am
they're not ports, they're there to use up watsed space to make the chamber bigger
Date Posted: 15 July 2008 at 7:17am
in Old WLx 18TBX46
IN NEW Wlx 18tbx 100
all OEM name (DLS-xxxx)
WMX - is not 4 ports..(2 ports)
Posted By: MarjanM
Date Posted: 15 July 2008 at 10:32am
So how do one calculate the porting? Simply take the rear chamber as a reflex box or?
Posted By: ceharden
Date Posted: 15 July 2008 at 10:44am
Use Hornresp which can directly simulate this type of horn with ported rear chamber.
Date Posted: 15 July 2008 at 11:07am
front remove panel
Posted By: Bespoke
Date Posted: 15 July 2008 at 2:24pm
TDA-Audio who are you ?
You seem to have pictures/desgins and info on EVERY cabinet out there
Top Top man ! and thank you for sharing this with us
------------- Gone
Posted By: MarjanM
Date Posted: 15 July 2008 at 4:46pm
So the next step would be the accurate drawing of it? Right?
Date Posted: 15 July 2008 at 4:54pm
That would be naughty
Plus the accurate drawing is only so much help. The drivers are likely to be off the shelf, but its not 100% certain they are, their could be some voodoo going on. So it's not just a case of copying the dimensions and building a copy. Even if the drawing seems resonable enough you need to drop it into hornresp with the driver params of whatever driver you choose, check the output and do the port tuning manually
Posted By: MarjanM
Date Posted: 15 July 2008 at 10:02pm
I was trying to do the exact thing in horn resp but somehow the graphs dont look like i will like too. It drops like a rock under 40Hz and the excursion is more than 10mm. Maybe i should spend some more time refining the ports and the back chamber volume
Posted By: heinrich
Date Posted: 16 July 2008 at 8:47am
I'm afraid this might sound like the ported W bin..........a horn with ports..........the sound mostly I hate.....
------------- .....power is nothing without control....
Posted By: Edward James
Date Posted: 16 July 2008 at 9:28am
No heinrich is not like ported w bin. Im sure
Posted By: J Nine Bar
Date Posted: 18 July 2008 at 1:38pm
SteveAATW, in reply to your private message on the WMX, though I would post a reply here as everyone can read then..
The WMX are sick bass bins, they move serious amounts of air, they are a short horn with ported rear chamber, they sound lovely, they move air like an 1850 horn/looney bin but sound more musical and go a bit lower. They don't drop like a lab or WSX as the tuning point is prob about 40-45 hz, but certainly have a faster hit.
I'll try and get a picture of the inside next time I have them out.
Posted By: ceharden
Date Posted: 18 July 2008 at 1:46pm
The best bit is that they're so damn simple!
The only bit that Steve and I haven't been able to work out is the exact throat arrangement. Also the hardest to get a picture of unfortunately.
Date Posted: 18 July 2008 at 1:53pm
the driver fires onto a slotted baffle a bit like a Martin 215. if that make sense?
Posted By: ceharden
Date Posted: 18 July 2008 at 2:21pm
Yeah, we'd guessed that, more interested in what happens between that and the first fold, and of course the actual throat area
Posted By: minaximal
Date Posted: 18 July 2008 at 2:25pm
maybe the wedge next to the throat which looks like it could be ported is actually a helmhotz absorber chamber.. i'v played with this idea before with aj horn, sometimes it can help output, when correctly sized.
------------- Subs + Barges = :)
http://www.metaacoustics.com" rel="nofollow - www.metaacoustics.com
Date Posted: 18 July 2008 at 3:46pm
Think its gong to be a combination of long arm + camera + flash job, and getting the driver off one and having a look through the baffle
Might just go and get one hired
Posted By: mykey
Date Posted: 18 July 2008 at 3:55pm
instead of doing all that, aim your energy at doing your own
Unless you are Chinese......are you?
Date Posted: 18 July 2008 at 4:16pm
To be honest I'm just interested in how the damn thing works than building a million clones of it. Done some variations of my own in horn resp and although you can get a response out of it, its a bit peaky a doesn't drop as low as the martin specs would suggest
As Chris mentioned, its simplicity has me intrigued, if it really is as simple as it appears then you wonder why aren't more people doing it
Posted By: mykey
Date Posted: 18 July 2008 at 4:25pm
I am, and have in the past
Posted By: mykey
Date Posted: 18 July 2008 at 4:27pm
Steven Court was doing it many moons ago with his 'W' bins
Posted By: ceharden
Date Posted: 19 July 2008 at 12:58am
You will of course have seen that I've already done a ported horn design which works very well indeed from initial testing (still need to get them finished and out on more gigs).
That doesn't mean I don't want to know how other people do it for comparison....
The WMX is the wrong shape for me anyway. I like the look of the WLX more, about the same size as one of my twin 18" boxes.
Interestingly I can get a nice flat response with a 15" ported horn (measures flat too) but trying to design a sensibly sized 18" version it just comes out really peaky. Tried a few drivers in the simulations and it doesn't make much difference.
Date Posted: 19 July 2008 at 3:28pm
and hence why i suggest an absorber chamber could have been employed in the throat to absorb the peakyness.. tda may see if it is or not
Posted By: djstefanos
Date Posted: 25 September 2008 at 2:45am
interesting topic dug up here. Would like to acquire some more info for WMX
Date Posted: 02 October 2008 at 7:50pm
WLX-STILL _version_by_tda-audio...
Posted By: MarjanM
Date Posted: 03 October 2008 at 12:23am
Any more details or plans for this box?
Posted By: mykey
Date Posted: 03 October 2008 at 8:02am
Posted By: tweeter box
Date Posted: 03 October 2008 at 9:54am
SteveAATW wrote:
Second Pic:
looks identical to the TBX i had!
------------- PRECISION SOUND SYSTEM.
Date Posted: 03 October 2008 at 11:35am
\\\\\\\\\\ooks identical to the TBX i had!\\\\
18tbx100 = martin DLS-xxxx
\\\\"your style is unorthodox, but effective. It is not the art, but the combat that you enjoy. It is defeat that you must learn to prepare for"\\\\
not passion... not enjoy.... - just many many work....
Date Posted: 05 October 2008 at 10:33am
to tweeter box
this pic - WMX inside....
Posted By: justamadman
Date Posted: 05 October 2008 at 6:16pm
now you just need to run it through Hornsrep with with a V18-1000 and release the plans.
how does the sound differ from the wsx???????
------------- in front of the bass bins baby
Posted By: mykey
Date Posted: 06 October 2008 at 2:59am
| That will be the day when this site hits rock bottom
TDA is already out of order for copying a new design, surprised he's not had a warning or been banned for what hes done
This site isn't full of low lifes is it?
Posted By: wafflesomd
Date Posted: 06 October 2008 at 5:10am
WSX plans are ok but these aren't?
Posted By: mykey
Date Posted: 06 October 2008 at 5:19am
no it isn't ok. WSX is an old design, but is still being sold, and these are the new replacements, bang out of order
ASS pland were never put up! is it because Tony was on here?
you guys are funny
it says...SPEAKERPLANS.COM, not .....commercialspeakerplans.wrong
Posted By: Deadbeat
Date Posted: 06 October 2008 at 3:08pm
I agree Mykey. No matter how good a clone is - it's still a clone. A martin 215 clone is fine by me (I mean - think of all the free plans that were virtually identical to them released by the driver manufacturers), WSX is pushing it as they are still being actively produced, but a WLX? Plans?
TDA - you seem to have a pretty good head and a good set of hands - it's time to put down the measuring tape and take out pen, paper and calculator to use in designing some cabs of your own.
PS
Mykey! Tony has released plans on here before
Posted By: mykey
Date Posted: 06 October 2008 at 4:08pm
have you seen his website deadbeat?
he's does big corporate jobs by the looks of it,he can afford originals
I bet he's going out as originals
someone ask him if we an see his badges? i bet they are spot on
sorry, it's wrong
If i wanted to, i could be driving a XK8 in six months, by doing exactly what hes doing
I won't because I want to sleep at night, and design my own, its much more satisfying than money when you achieve a great cab
Posted By: Deadbeat
Date Posted: 06 October 2008 at 7:05pm
sorry, it's wrong
I won't because I want to sleep at night, and design my own, its much more satisfying than money when you achieve a great cab |
Didn't see the website, but have now
Thanks.
Posted By: mykey
Date Posted: 29 November 2008 at 3:06pm
I'll try and get a picture of the inside next time I have them out. | i have to dissagree with you on this, unless Martin ARE telling porkies
I did query the specs the other day but no one answered my question
with a -10db @ 28hz  this cab will have a tuning of around the 32/3 hz mk
Posted By: Amano
Date Posted: 04 December 2008 at 11:37am
It is my aproximate drawings... not 100% original values! But...
Date Posted: 05 December 2008 at 10:44am
It is my aproximate drawings... not 100% original values! But.. |
is not copy WLX geometry and tuneng wented...
В теме forum_posts.asp?TID=18252&PN=7 - http://speakerplans.com/forum/forum_posts.asp?TID=18252&PN=7
я выложил приблизительный чертеж составленный на основе
спецификации к WLX и ваших фото, неизвестными остались длина портов и
их диаметр. Могли бы Вы заполнить эти пробелы?
Кстати, при моделировании на динамике 18TBX100 не получилось
достичь заявленной АЧХ и чуствительности для 1-го кабинета в
полупространстве.. Что осталось для меня загадкой как там получается
28Гц при 96Дб чувствительности и 35гц при 103дб?????! .... По видимому
графику АЧХ можно сделать вывод что WLX играет ни чуть не ниже чем WSX.
Видимо симуляция недостаточно точно представляет реальную картину...
TDA-Audio answear
WLX - good cab !!! (very compact cab) , but not best cab..... wsx -rullezzz bh-882 - best bass horn for my... |
Posted By: Amano
Date Posted: 05 December 2008 at 12:19pm
I need know throat area, length and diameter of ports.. And I'll try to draw a new plan of cab, which would be more closer to original WLX sound.
Posted By: MarjanM
Date Posted: 05 December 2008 at 12:34pm
That was also my conclusion. I have simulated different drivers in a such a box and didn't get any lower than 50Hz. Is there any trick that we are not aware of?
Posted By: mykey
Date Posted: 05 December 2008 at 1:44pm
I said recently that the spec's were suspect
- 10db 28Hz ???????
105db ??????
for it's size I cant see it doing what it says it doe's
unless the're saying use 4 bins
the bute is close to 27Hz - 10db, but look at the differance in size of the brute 45 and the Martin Hybrids
Posted By: MarjanM
Date Posted: 05 December 2008 at 4:03pm
For me it is ok if it goes down to 37-38Hz in group of 4. I dont need lower response.
Posted By: CHAMPION
Date Posted: 07 December 2008 at 12:22am
------------- Sticks n Stones
Date Posted: 07 December 2008 at 1:02am
Posted By: mykey
Date Posted: 07 December 2008 at 5:40am
thats even smaller, so I would take those spec's with caution
Posted By: pawan
Date Posted: 12 February 2009 at 9:18pm
thanks this topic
------------- PB
Posted By: Tujmi
Date Posted: 01 November 2009 at 11:52am
Martin audio WMX ??
Posted By: ceharden
Date Posted: 01 November 2009 at 3:02pm
Nope! The driver in the WMX faces the rear of the box and fires through a letterbox like the WSX and other Martin horns. It's a pure horn (with the reflex assistance) rather than a BPH.
Posted By: Tujmi
Date Posted: 01 November 2009 at 3:24pm
somebody has a plan from him?
Date Posted: 01 November 2009 at 8:31pm
\\\\\\\\\\Martin audio WMX ?? \\\\\\\\\
no!
Posted By: Amano
Date Posted: 02 November 2009 at 5:31am
I'll try to draw WMX later...
Posted By: Panoramix
Date Posted: 09 February 2025 at 10:41am
have someone build this wlx cabs from tda/ammano plan ? and ?
i plan to build 2 to put under 2h3 for little gig.
