Need help with X15!!!!
Category: Plans
Forum Name: X10, X12, X15 and XM15
Forum Description: Discussion / Questions about the X10, X12, X15 and XM15
URL: https://forum.speakerplans.com/forum_posts.asp?TID=1844
Printed Date: 29 March 2024 at 11:56am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Need help with X15!!!!
Posted By: jac2003
Subject: Need help with X15!!!!
Date Posted: 11 May 2005 at 12:19pm
Hi,
I will open a bar/cafe in Shanghai. Due to the high price of well known
intl brands here and unavailibility and low quality of some local
brands, I have decided to build some loudspeakers myself.
We have a 250 sqm (about 2500 sqfeet??) location with a high ceiling
and we need to play a wide range of music and also some solo
performances now and then)
I though I might try to build the X15's myself since I'm quite
experienced with the cabinet part - but I know nothing of speaker
design.
Anyway, with some luck I found the P-Audio distributor in China and ordered the following components:
sn-15mb woofers, bmd 750 compr drivers, ph-3223 flares.
I got it for a very good price ($65, $60 and $25 for the above!!) but i
know that the hf driver is different from the one in the plan.
Here's my question:
Will it work with the bmd 750?
What do I do regarding crossovers?
Thank you very much!
Posted By: Timber_MG
Date Posted: 11 May 2005 at 12:44pm
Try mailing proaudioparts for a recommended crossover for the SD-740 +
1.5"-2" adaptor on the same horn. The response of this combo is likely
not the same, but you might get useable results. That's blooming cheap
if I may say so.
Posted By: jac2003
Date Posted: 11 May 2005 at 12:56pm
Thanks broer,
I will mail them. Just one more question - what subwoofer option from
this site would you recommend for P-Audio drivers, if posible. I
really need something that's not too big.
