Hi Tommy, The phase plug is implied by the area of the throat Sth being less than the area of the driver. This is only a really simple script to get an idea of performance (IE low cutoff & bandwidth) of the horn.
Any directivity information & a more accurate high frequency response would need the throat area & different parts of the horn to be modelled individually. I've done this a few times, but get fed up with having to change the akabak scripts when i change my mind about the design.
As i rarely array my mid-top designs, usually cos i only build two & want a stereo system! (they quite often get arrayed when in storage hehe!) I'm not too fussy about constant directivity, more so with efficiency & wide dispersion. I try to match up the -6db points with the lower & higher frequency sections tho, so that the change in directivity varies smoothly down the stack.
I'm a keen fan of keeping only 1 mid-top per side to keep to the ideal of a point source (or cylindrical source in this case) as faithfully as poss.
You can really go to work with ducts in akabak, but it very quickly becomes hard work to make sure all the dimensions & areas are correct.
cheers,
Rob.
PS I dont have a mid modelled as ducts & waveguides on the pc i've got with me here but i did have this approximation to the folding of an 1850 here. This was a model i based the simulation of my smooth contoured 1850It uses ducts & waveguides to approximate the geometry in the 1850 horn:
Def_Driver 'sub800' Meas_DoNotModify dD=41cm dD1=8.5cm tD1=4cm |Cone fs=30Hz Mms=201g Qms=10 Qes=0.23 Re=5ohm Le=1.5uH ExpoLe=0.618
System 'better 1850' Driver 'D1' Def='sub800' Node=1=0=20=3
Enclosure 'rearchamber1' Node=3 Vb=45L Sb=2400cm2 | simulate v wedge with few ducts
Duct 'Du1' Node=20=21 WD=60cm HD=3mm Len=4cm Visc=0 Duct 'Du2' Node=20=21 WD=60cm HD=0.5cm Len=8cm Duct 'Du3' Node=20=21 Visc=0 WD=60cm HD=0.7cm Len=12cm Duct 'Du4' Node=20=21 Visc=0 WD=60cm HD=1cm Len=16cm Duct 'Du5' Node=20=21 Visc=0 WD=60cm HD=1.5cm Len=20cm Duct 'Du6' Node=20=21 Visc=0 WD=60cm HD=3cm Len=24cm Duct 'Du7' Node=20=21 Visc=0 WD=60cm HD=1.5cm Len=28cm Duct 'Du8' Node=20=21 Visc=0 WD=60cm HD=1cm Len=32cm Duct 'Du9' Node=20=21 Visc=0 WD=60cm HD=0.7cm Len=36cm Duct 'Du0' Node=20=21 Visc=0 WD=60cm HD=0.5cm Len=40cm Duct 'Du0' Node=20=21 Visc=0 WD=60cm HD=0.3cm Len=44cm
| first bend
Waveguide 'bend1' Node=21=22 WTh=60cm HTh=3.5cm WMo=60cm HMo=4.66cm Len=15.5cm T=1 Waveguide 'bend1' Node=21=22 WTh=60cm HTh=3.5cm WMo=60cm HMo=4.66cm Len=22cm T=1 Waveguide 'bend1' Node=21=22 WTh=60cm HTh=3.5cm WMo=60cm HMo=4.66cm Len=28.5cm T=1
| first expo section
Waveguide 'downpipe' Node=22=23 WTh=60cm HTh=14cm WMo=60cm HMo=21.5cm Len=44cm T=1 | second bend (three waveguides)
Waveguide 'bend1' Node=23=24 WTh=60cm HTh=7cm WMo=60cm HMo=11cm Len=30cm T=1 Waveguide 'bend1' Node=23=24 WTh=60cm HTh=7cm WMo=60cm HMo=11cm Len=45cm T=1 Waveguide 'bend1' Node=23=24 WTh=60cm HTh=7cm WMo=60cm HMo=11cm Len=75cm T=1
| exit horn Horn 'top half' Node=24 WTh=60cm HTh=32cm WMo=60cm HMo=60cm Vf=0L Len=65cm T=1 x=0 y=0 z=0 HAngle=0 VAngle=0
------------- What I cannot create, I do not understand
