Something to do with your Celestions!
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=18700
Printed Date: 26 March 2026 at 11:31pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Something to do with your Celestions!
Posted By: Deadbeat
Subject: Something to do with your Celestions!
Date Posted: 01 August 2008 at 8:49pm
Gentlemen,
Many of you have probably seen these, but I will post them up for the benefit of those not on FSP.
These designs were wholly designed by Simon of FSP who has designed and built and tested them. I've mentioned them in a few threads so I thought I'd post them.
They are a good use for that stack of Celestions that you obviously have lying around , and work with other drivers as well.
Here:
1x18 bass horn (Celestion HDX) http://freespeakerplans.com/forum/forum_posts.asp?TID=217 - http://freespeakerplans.com/forum/forum_posts.asp?TID=217 C-Bin
1x15 kick bin (Celestion 4080FD) http://freespeakerplans.com/forum/forum_posts.asp?TID=218 - http://freespeakerplans.com/forum/forum_posts.asp?TID=218 folded like a Martin F2B.
1x12 DR mid horn (Celestion TF1225e) http://freespeakerplans.com/forum/forum_posts.asp?TID=219 - http://freespeakerplans.com/forum/forum_posts.asp?TID=219
Please take your time to comment. I have preliminary plans of these in dxf format, they aren't the final optimized versions, but PM me if you really want to have a look, otherwise Simon has put screenshots of the said CAD drawings on, as well as plots.
Also, if any of you would mind going down to Dorset with full measuring gear  You get the same prize if you go down to Shropshire and look around Robbo's F2Bs.
I bid you good day gentlemen,
------------- Away on extended leave.
