I need a smoke/haze machine
Category: Other Chat
Forum Name: Lighting Talk
URL: https://forum.speakerplans.com/forum_posts.asp?TID=19520
Printed Date: 26 March 2026 at 5:30pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: I need a smoke/haze machine
Posted By: Heathrow_B_line
Subject: I need a smoke/haze machine
Date Posted: 07 September 2008 at 10:22pm
hi guys
I need a good smoke or haze machine for use with my new laser lighting rig
I would like something with a timer so i can set it and leave it all night or possibly dmx control, can anyone offer any advice?
i mainly want to use it for big shows, so 600 to 2000 people is my aim
Cheers
HBL
------------- Produce a killer sound. Take no prisoners.
Posted By: pk1964
Date Posted: 07 September 2008 at 10:28pm
got a zr22 mint make me a offer in flight box 2
Date Posted: 07 September 2008 at 10:55pm
can you post a link up to the model you are referring too.. would it fill a large marquee with smoke/haze?
Posted By: csg
Date Posted: 07 September 2008 at 11:06pm
with a decent fan, yes. good machine
Posted By: whitehousejamie
Date Posted: 08 September 2008 at 1:53pm
I use the Martin Magnum hazer which i'm quite happy with.
Also have a look at the Look Solutions Unique 2 hazer, and the Le Maitre units.
------------- Lighting, sound & staging hire www.eventstore.co.uk www.pauljamespromotions.com
Posted By: bitzo
Date Posted: 08 September 2008 at 2:06pm
There's a DIY solution
http://www.authorsden.com/categories/article_top.asp?catid=10&id=31395 - http://www.authorsden.com/categories/article_top.asp?catid=10&id=31395
Posted By: odc04r
Date Posted: 08 September 2008 at 3:45pm
We use a JEM technofog, much better than the crappy cheap foggers and with fairly good output. No DMX but it does have timer/output level controls on the remote.
Edit - just saw 600-2000 people, too small for that methinks.
Posted By: ceharden
Date Posted: 08 September 2008 at 4:44pm
Smoke Factory Tour Hazers are my current favourite. Nice haze, good DMX control of fan and haze output. Obviously not a cheap option as it's a professional unit but Used Lighting have one ex demo for just under £600 at the moment. Probably worth it if you're going to be using it regularly. Quite compact and can be tipped while filled with fluid!
Posted By: norty303
Date Posted: 08 September 2008 at 5:35pm
Ona budget, I've had a lot of success with one of these:
http://www.thomann.de/gb/stairville_sf1500_nebelmaschine.htm - http://www.thomann.de/gb/stairville_sf1500_nebelmaschine.htm
They do a 3kw version too. Comes with DMX and timer remote and will output continuously on 20% if need be.
I bought an 18" metal fan from ebay for £30 to help the smoke disperse around the venue. Works very well and MUCH cheaper than proper smoke fans.
------------- My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
Posted By: csg
Date Posted: 08 September 2008 at 6:41pm
for versatility and low running costs you are far better with a good quality fog machine and fan rather than a hazer
if you want haze, then run it slowly and spin out the output with a fan
if you want fog, then turn it up!
I use an effects company supersmoke with a 18" blower for my bigger jobs - for a tent of 2500 capacity, then it will be running at 25% continuously for a decent haze, and will get thru 2.5l of fluid per 6 hours ( effects company dense grade)
the secret is having a good quality machine - anything by unique, smoke factory, jem , le maitre and effects company should be fine
Date Posted: 15 October 2008 at 6:33pm
thanks for the info guys
i will have a look around the shops and see what i can find
Posted By: DPR2001
Date Posted: 17 October 2008 at 9:09am
Hi,
I use a Martin Magnum 2000 mackhine. Produces a lot of smoke in very little time. If I go to a venue when they don t allow smoke I use My Jem Stage Hazer. Both have variable output and timer. I might be selling my stage Hazer soon - don t get enough use out of it as we usually take out the Martin Magnum.
Posted By: wasup
Date Posted: 17 October 2008 at 2:11pm
A couple of three RASTAS and a few waterpipes will do the trick! Write it all down and thats the timing sorted,.....
------------- a butterfly can cause an whirl wind!
Plant a sead and JAH WORKS BE DONE!!
Posted By: CHAMPION
Date Posted: 18 October 2008 at 11:50am
couple of Rasta's should do the trick...
------------- Sticks n Stones
Date Posted: 09 December 2008 at 10:35pm
thanks for all the advise guys
big thanks to Paul for the JEM ZR22...
great machine
http://img265.imageshack.us/img265/5531/dsc00149largeci2.jpg">
http://img48.imageshack.us/img48/504/dsc00150largewj7.jpg">
http://img48.imageshack.us/img48/928/dsc00151largelq8.jpg">
http://img48.imageshack.us/img48/1121/dsc00152largegw0.jpg">
http://img48.imageshack.us/img48/6272/dsc00153largecf1.jpg">
http://img48.imageshack.us/img48/7181/dsc00155largezf5.jpg">
http://img508.imageshack.us/img508/7426/dsc00154largejb9.jpg">
i am so impressed i want another one!
So if anyone else has a JEM-ZR22 + flightcase they want to sell please contact me!
Cheers
Date Posted: 09 December 2008 at 11:38pm
not sure that will be anywhere big enough for over 1000 people venues, but in reality you will unlikely get anything bigger than that so is all good.
Id have got a hazer personally, its much more functional, more venue friendly, and just generally more pleasant for all involved.
For reference, the internal heating element and pumping mech in my machine which you have seen is scrumped from a magnum 2000, the model twice the size of the ZR22.
Posted By: csg
Date Posted: 09 December 2008 at 11:43pm
well,with a good fan, the 22 will do haze for venues of 2000+ - i know, ive done it!
unless you can afford a proper oil cracker like a df50, then the best way to go is a decent smoke machine which you can run low continuously, and a really good fan
water based haze machines are only small moke machines with fans, and a big price tag
Date Posted: 10 December 2008 at 12:03am
i just want a nice fine covering of thin fog/haze not plumes of white smoke
if i dont find another zr22 i might get a magnum 2k
but i would have to research how reliable they are first
Date Posted: 10 December 2008 at 12:10am
Pat
i have done some reserch... are you sure the magnum 2k produces more smoke? looks quite close on paper.
explain yourself young man
ps. i hear JEM is a better brand and martin smoke machines werent that good
Posted By: csg
Date Posted: 10 December 2008 at 12:15am
same factory these days - spend your money on a proper blower, not a desk fan,
im covering a 100 by 25m marquee with my trusty effects company supersmoke 1000 running at 25% tonight - and thats a smaller machine than the 22
Posted By: Djdarch
Date Posted: 10 December 2008 at 12:18am
hi mate the magnum 2k is no better than the zr22 you have, i would say the zr22 was a better machine , reliabilty of the magnums may be an issue, a local hire company had 3 , all are now out of service.
Having said all that, i have a zr22 thats flightcased thats stopped working, it used to work a ok and really blast out the smoke, then got a bit hit and miss and would only heat when it wanted to. Now it doesnt work at all, i was thinking that it needs a new heater block or can they be repaired??
Posted By: H...
Date Posted: 10 December 2008 at 6:46am
Windy fans can be triggered by dmx me seems to remember
Posted By: pk1964
Date Posted: 10 December 2008 at 8:57pm
nice to see the machine as a good new home
Date Posted: 11 December 2008 at 3:12pm
take the lid off and have a good poke around. Its a very simple design inside, quite possibly just a contact filled with sticky glucocrud or something thats gotten a wee bit warm!
Date Posted: 11 December 2008 at 3:20pm
to HBL:
ive just found the magnum to be better than the zr22 - used to have one of each in our venue before we upgraded to haze machines. slightly better throw out the machine, and has a slightly larger heat block and element in, so can blat out smoke harder if needed, and the kinetic energy and element can keep up for ages.
i must say you cant beat the zr22's reliability however, better build and higher quality components. Had both the machines said on the workbench after they got decommisioned for a nosey (as i do with all equipment to make the nights pass faster). The magnum eventually fried its circuit board, so the venue decided to just get a nice hazer, and scrap the magnum. I nicked it, and transferred the internals to my crap chinese thing and rewired the circuitry.
seconded on the fan, the crome industrial ones with tilt stands are especially usefull and cheap on ebay. all the touring companies turn up with them. If you want to be posh, you can get a nice little DMX switchpack and remotely switch it, or depending on the motor type use a dimming pack and control it (unlikely as most will have small DC motors).
Posted By: Preacher
Date Posted: 10 January 2009 at 8:16pm
ZR22 was pretty much standard on all big west end musicals back in the 90s (I lost count of the ones I used as a stage LX on many shows). So a very decent machine, and Martin brought out Jem back then as well. Jem also used to do a Water-Cracker Haze machine, bloody loud bugger , so never took of in a big way (also think the DF50 came out soon after).
------------- It's all about the music & the vibe, so enjoy it while you can.
Posted By: Dj Maca Roots
Date Posted: 19 March 2009 at 11:20pm
That's what we do
------------- Can't Stop Jah Music
Date Posted: 23 April 2009 at 12:12pm
is that mailto:jasmineyin@msn.com - jasmineyin@msn.com ???
Posted By: biotec
Date Posted: 23 April 2009 at 1:41pm
haha! good job speakerplans isn't easily searchable on google!
------------- me so horny, me love you long throw.
Posted By: jonminns
Date Posted: 24 April 2009 at 8:56pm
The tour hazer in the flightcase is a look unique mk1, the look mk 2 is a brilliant machine
Obviously you're sorted now, but i would have said anyway the best method is a decent controllable fogger & a fan, that's all non oil based machines are anyway
ps use the proper martin fluid!
Jon
Posted By: BigOne
Date Posted: 21 August 2009 at 7:27pm
IF YOUR STILL INTERESTED THEN I HAVE A NEAR NEW JEM ZR 22 SMOKE MACHINE , USED 3 TIMES FROM NEW AND ONLY FOR A PHOTOSHOOT TO SHOW LIGHT BEAMS SO ITS IN MINT CONDITION .
------------- sm
