2x18 manifold box
Forum Name: Feedback Forum
Forum Description: How Your Projects Perform
URL: https://forum.speakerplans.com/forum_posts.asp?TID=1976
Printed Date: 20 April 2024 at 10:37am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: 2x18 manifold box
Posted By: ronmaio
Subject: 2x18 manifold box
Date Posted: 04 June 2005 at 12:51am
what is the usable frequency of the 2x18manifoldbox .what speakers are recommended to suit these cabs
Posted By: norty303
Date Posted: 04 June 2005 at 7:20am
Which one?
There's afew manifold boxes out there
------------- My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
Posted By: ronmaio
Date Posted: 05 June 2005 at 6:35am
the 2x18 manifold on the speakerstore site by Niki Van Den Bosch. what others are there down to 30hz
Posted By: norty303
Date Posted: 05 June 2005 at 2:22pm
In my experience you'll truggle to get a manifold box good to 30hz without it becoming really huge. EV's were only good to 60hz or so. My Beyma one starts rolling off at about 70hz but it is very small
Posted By: simo69
Date Posted: 17 January 2006 at 4:29pm
what do 2x18manifoldbox look like
Posted By: login4
Date Posted: 17 May 2006 at 1:39am
Looks like a nice powerfull compact design but i haven't had any experance with them
------------- CELTIC SUBSONIC SOUND SYSTEMS
Posted By: ceharden
Date Posted: 17 May 2006 at 5:22am
Looks like a EV Deltamax sub. They work quite well.
Posted By: w-man
Date Posted: 19 May 2006 at 12:12pm
The dml subs work great, IF you have the factory prossesor to run them as they were intended to be used. Ive had alot of experience with deltamax and love the stuff. Having said that, its my belife that these boxes will not preform very well at all without EV specific drivers and prossesors!
------------- Keep conventional cabinets alive!
Posted By: minaximal
Date Posted: 19 May 2006 at 12:43pm
w-man wrote:
Having said that, its my belife that these boxes will not preform very well at all without EV specific drivers and prossesors! |
thats to sort out the shoddy frequency response to make these boxes usable.
dont you just love company/box specific processor settings...
------------- Subs + Barges = :)
http://www.metaacoustics.com" rel="nofollow - www.metaacoustics.com
Posted By: Pinheiro
Date Posted: 19 May 2006 at 3:15pm
Hi all
"Having said that, its my belife that these boxes will not preform very well at all without EV specific drivers and prossesors!"
dont worry on my case is the Deltamax clones from SSE will work well whiad DAS G45
but you must use some hi pass filter my case 24db oct set at 35hz and low pass 24db/oct 80hz
have fun
yours Vitor
Posted By: Calitri
Date Posted: 23 May 2006 at 10:18am
Those manifolds are EV MTL-2, which are also known as DML-models. They have used DL18MTs and EVX-180A/Bs as for drivers. Their frequency range goes from 45-200 Hz (-3dB) and they give a helluva lot of kick! So they're not 30 Hz cabinets, although their impedance graphs show, that the tuning is around 35-37 Hz but a friend of mine measured them and the cone excursion was about the same around 10 Hz region from 30-40 Hz, so 4th order HP from 30-35 Hz is enough. They can be used to about 30 Hz, when you apply around 6-10 dB of boost to around 30-35 Hz.
The idea, that it works only with EV's drivers and setups are totally wrong! The best results people have gotten from those MTL-2s is, when you use RCF L18P300 drivers in them or same kinds of drivers. The EV's drivers are quite lousy if you compare them to others. They have do sound better, if you stack them They will give quite low frequenys (<40 Hz) but you still need some EQing and guite powerful amp to drive them. They are nice cabinets and I'd like to have 4-8 of them too in stacks.
Have a look at the originals, with the EVX-180A drivers:
http://archives.telex.com/archives/EV/Speakers/EDS/MTL-2B%20 EDS.pdf
and here's the DL18MT version:
http://archives.telex.com/archives/EV/Speakers/EDS/MTL-2A%20 EDS.pdf
Posted By: mykey
Date Posted: 24 May 2006 at 3:58am
you should check out the GAE 2 x 18 cabs loaded with RCF 18p300's
great cab
sorry if some has mentioned these already only i havnt bothered reading the post's
------------- ......just all them hanging there like giant bananas.
Posted By: luc2366
Date Posted: 11 August 2006 at 9:52am
"the Deltamax clones from SSE will work well whiad DAS G45"
I'm very sorry: I heard them loaded with D.A.S and it sounded like sh*t...
"The idea, that it works only with EV's drivers and setups are totally wrong!"
Correct, I use Beyma-drivers and a DCX-2496 and my (8) cabs sound great
Here you can find some pics:
http://groups.msn.com/S-P-ESoundLight/bouwvannieuwesubjes.msnw - http://groups.msn.com/S-P-ESoundLight/bouwvannieuwesubjes.msnw
Bye the way, I know Nikki van den Bosch - he's also from Belgium. He's MTL-2's loaded with Eminence (and also using a DCX-2496) sound great!
Posted By: Hugo Biermann
Date Posted: 30 September 2006 at 11:14am
Have used OEM, eminence and p-audio loaded MTL2's. With anything from
utradrives, Driveracks to the ev processors. 40Hz - 80 / 85HZ without
EQ. Theyre loud and for some reason throw quite far outside. They take
plaster off walls in club setups too... f**k them with power though.
Date Posted: 30 September 2006 at 11:17am
And I have seen a LOT of half MTL2's that rock parties into jail almost. With normal analogue x-overs. Theyre great boxes. Build them if you want. They can be heavy on yr back though...
Date Posted: 30 September 2006 at 11:34am
Heres the plan of the 'half MTL2' thats going around here. The get loaded with all sorts of 18's. the most common ones are: Eminence Omega 18's & Kappa 18's P-Audio C18-650's & E18-400s'
All depends on yr amplifiers and applications. They all sound gret too. Don't try to model them either. It doesnt work. f**k knows why, but the boxes work...
http://imageshack.us/?x=my6&myref=http://www.imageshack.us/">
Posted By: simo69
Date Posted: 02 October 2006 at 4:01am
Does anyone have a photograph of the finished item?
Is there another angle to this drawing??
Date Posted: 02 October 2006 at 5:12pm
Thats what I got off an emty cab with a tape-measure. Will try and ge a photo of 1 when I see 1 again.
If you want a different angle, turn the left-hand side square 90deg to the right and then u have the position the box is supposed to be in when you play it.
Posted By: simo69
Date Posted: 03 October 2006 at 4:43am
what is the overall 2x18" sizes.
Posted By: simo69
what is the 2x18 dimensions
Date Posted: 03 October 2006 at 3:47pm
go here:
http://www.speakerstore.nl/index.php?l=en&pg=11&c=7 - Manifold (2x 18")
Posted By: luc2366
Date Posted: 03 October 2006 at 4:30pm
...and here for the pictures:
Posted By: MARTYNJONHALL
Date Posted: 22 February 2007 at 4:07pm
these cabs look great anybody got some detailed plans for them??
Posted By: vertigo
Date Posted: 05 March 2007 at 2:23pm
I'm interested in building these too, any plans? The speakerstore link only has a picture.
Posted By: CHAMPION
Date Posted: 07 March 2007 at 7:31am
BEST driver for these cabs PD 186, or Orberton, heres what the Manufactures of Oberton have to say ........
We buy the paper cone for our speakers from the same company that supply Electrovoice. For our speakers 18XB700 we use the same cone like EVX 180A speaker.
EV use cone with weight 50g I order for our speakers 60g cone from the same Kevlar paper. Our voice coil is 25 mm. instead 20mm. of EVX180A.
We have cooling holes under the spider and under the voice coil to reduce power compression. Some customer told me on the Frankfurt fair Prolight+Sound where we have boot every year that when they change the EVX180 in Dynacord boxes with our speaker 18XB700 the sound is better.
Best regards
OBERTON Co.
------------- Sticks n Stones
Posted By: luc2366
Date Posted: 07 March 2007 at 8:03am
"BEST driver for these cabsis PD 186 or Orberton 18XB700"
... and this is based on what?
Here in Europe, none of these brands/types are used in the manifold cabs.
Of course I have the designs of the MT-2L but I'm not so willing to give them - I expect something in return: more specific the design of a 3-way topcabinet 15"+10+2"
Posted By: vertigo
Date Posted: 07 March 2007 at 11:06am
Luc2366, I'd be willing to pay for the plans. got paypal?
Posted By: luc2366
Date Posted: 07 March 2007 at 6:16pm
vertigo wrote:
got paypal? |
no, sorry...
Posted By: vertigo
Date Posted: 07 March 2007 at 9:19pm
I don't have any plans, let me know if theres another barter we can work out.
Posted By: Calitri
Date Posted: 09 March 2007 at 3:41am
I have say, that don't use the PD 186, it's not that good of a driver for the cabinet, too low EBP. The best driver in terms of price and quality is still the RCF L18P300, although I'd personally use (if you have the money) RCF LF18X400, that's the one with the Muller cone (the difference between X400 and G400) but the G400 works also the same, 'cause the T/S parameters are the same.
If you want to model it in WinISD, use this setup: 6th order BP, rear enclosure ~170-175 L, front ~80 L, 2 rear ports 14x23 cm by 70 cm in length and front 87x22 cm by 50 cm in length. This gives you a rough estimate of the bass response but upper end extends to about 150-170 Hz with a bit of rising and then cuts off. So with those values you can estimate the response with different drivers. I'd still recommend the RCF L18P300 as the easiest driver available and with a decent price. It's found out in practice that, it's a good drivers for that cabinet, a helluva lot better than the original ones!
Posted By: luc2366
Date Posted: 09 March 2007 at 5:10am
Hi all,
here in Belgium me and my collegues we tried the MT-2L's with several speakers. We had the best result with the RCF 18S800.
Will also do without cabinet-adjustements: RCF 18P300 and Eminence Sigma Pro-18. For the Beyma 18G400 which I used, the ports should be slightly adjusted
Posted By: norty303
Date Posted: 12 March 2007 at 1:35pm
a 3-way topcabinet 15"+10+2" |
If you're going the route of a 10" mid then a 1.4" compression driver will be much sweeter than a 2" unless you spend some serious money.
Posted By: luc2366
Date Posted: 12 March 2007 at 2:33pm
... yes, that can be an option but I'll use the 2"ers first because I already have the mid-speakers (Beyma 10M250) and the drivers (Beyma CP-600TI on a Beyma TD-360 horn)
